tchirou 23 Posted June 23, 2018 Posted June 23, 2018 Hi Angelblue05 I have Emby server 3.4.1.0 on a synology NAS, Kodi Krypton 17.6 on a Nvidia Shield TV. The emby Kodi add-on is 3.0.31. I just saw that most of my movies have disappeared from the Kodi movie list (29 are there instead of 384). Nothing is wrong with the TV shows though. Everything is good server side, both for movies and tv shows. When I try to reset the Kodi database, I have a "Emby error check log" The log says : 19:38:54.355 T:138963838032 NOTICE: EMBY.default -> plugin.video.emby started 19:38:54.364 T:138963838032 NOTICE: EMBY.default -> Parameter string: ?mode=reset params: {'mode': ['reset']} 19:38:56.277 T:138963838032 NOTICE: EMBY.default -> ERROR:: 'ascii' codec can't decode byte 0xc3 in position 12: ordinal not in range(128) Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/default.py", line 179, in <module> Main() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/default.py", line 66, in __init__ elif not self._modes(mode, params): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/default.py", line 142, in _modes action() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/database.py", line 173, in db_reset Playlist().delete_playlists() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/views.py", line 445, in delete_playlists self._delete_playlist(os.path.join(path, file)) File "/home/jenkins/workspace/Android-ARM64/tools/depends/xbmc-depends/aarch64-linux-android-android-21/lib/python2.7/posixpath.py", line 71, in join UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 12: ordinal not in range(128) 19:38:56.278 T:138963838032 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.UnicodeDecodeError'> Error Contents: 'ascii' codec can't decode byte 0xc3 in position 12: ordinal not in range(128) Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/default.py", line 179, in <module> Main() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/default.py", line 66, in __init__ elif not self._modes(mode, params): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/default.py", line 142, in _modes action() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/database.py", line 173, in db_reset Playlist().delete_playlists() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/views.py", line 445, in delete_playlists self._delete_playlist(os.path.join(path, file)) File "/home/jenkins/workspace/Android-ARM64/tools/depends/xbmc-depends/aarch64-linux-android-android-21/lib/python2.7/posixpath.py", line 71, in join UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 12: ordinal not in range(128) -->End of Python script error report<-- 19:38:56.507 T:138963838032 WARNING: CPythonInvoker(53, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/default.py): the python script "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon9xbmcaddon5AddonE I forced a new update of the addon, rebooted the server and the shield, but no luck. Would you have an idea ? Merci !
Angelblue05 4132 Posted June 23, 2018 Posted June 23, 2018 Do you have a library with special characters in it?
tchirou 23 Posted June 23, 2018 Author Posted June 23, 2018 Nope I just have “films” and “films 3D” as movies libraries It has worked this way for weeks Maybe it went wrong with one of the couple last updates of the add on, I just realized tonight though 1
Angelblue05 4132 Posted June 23, 2018 Posted June 23, 2018 Can you check from your webclient. Is there an Emby generated library that has a special character?
Angelblue05 4132 Posted June 23, 2018 Posted June 23, 2018 (edited) "Series" "francais" contains a special char. Hm I haven't changed anything in that part of the code in a long while, the bug must have always existed. It only relates to deleting playlists. . Can you test this build and let me know if it helps any? plugin.video.emby-3.0.31a.zip Edited June 23, 2018 by Angelblue05
tchirou 23 Posted June 23, 2018 Author Posted June 23, 2018 Strange because my library has been this way since day 1 I am going to try asap Thanks
