nikc0069 2 Posted June 23, 2018 Posted June 23, 2018 Using tvheadend plugin with schedules direct free period and getting no images for TV shows. Is this o ly in the paid period or does it not work with tvheadend? I get the epg but no images.
Luke 42237 Posted June 23, 2018 Posted June 23, 2018 Hi, when you use TVHeadend, that's where the images will come from, so what you need to do is get images working in TVHeadEnd, and then Emby will pull them from there. Please let us know if this helps. Thanks !
nikc0069 2 Posted June 23, 2018 Author Posted June 23, 2018 Thank you. I'm not talking about logos but if I need to get Sd working in tvheadend for the program images I'll have a Google about thanks.
nikc0069 2 Posted June 23, 2018 Author Posted June 23, 2018 I've got schedules direct working in TVHeadend though I've set up logos in Emby Metadata editor anyway. Still can't see a way to get it to pull images for each episode though. Is @@Tolotos the man I need to talk to?
nikc0069 2 Posted June 23, 2018 Author Posted June 23, 2018 I don't but I will be honest it's the first time I've used it in a few years so not 100% sure where to be looking.
Luke 42237 Posted June 23, 2018 Posted June 23, 2018 Ok you'll want to get that setup first. What kind of tuner do you have?
nikc0069 2 Posted June 23, 2018 Author Posted June 23, 2018 I've got two dvbt2 tuners. I've configured the sd grabber and have pulled epg for all my channels but I can't see episode images anywhere.
nikc0069 2 Posted June 25, 2018 Author Posted June 25, 2018 I'd really appreciate any help. Do I need to blwo away the TVheadend EPG and use EPG123 to get SD date then send it in using tv_grab_file? I tried giving Emby the pure EPG123 output and still got no images, so guessing it really does need to happen ont he TVH side but I'll be damned if I can figure out how that works!
Luke 42237 Posted June 25, 2018 Posted June 25, 2018 Yes it needs to happen on the TVH side. @@Gerrit507 may have some advice. Thanks.
nikc0069 2 Posted June 26, 2018 Author Posted June 26, 2018 I've now got some episode and series numbers by switching to the sqlite sd grabber. Still no show images though just channel logos.
Gerrit507 24 Posted July 4, 2018 Posted July 4, 2018 Sorry for the late reply. As far as I know the tvheadend plugin currently doesn't pull any images for epg items from the server. Honestly I didn't even know that tvheadend supports that
