Trekster 10 Posted June 23, 2018 Posted June 23, 2018 Hi guys, I have a quick question. I have experience with tvheadend and Kodi frontend. The Kodi box would cache guide data locally and the data would be instantaneous on the box. On emby, if I press a guide point it will say null. If I choose it by scrolling, wait for a sec or two and then press it, it will show a description. It seems data is not cached locally, is that true? Is it possible to cache 1-3 days worth of data locally on the client? Sent from my SM-G965F using Tapatalk 1
ebr 16337 Posted June 23, 2018 Posted June 23, 2018 Hi. I don't think we need to manage a cache for this on the app. Can you please explain exactly what you mean by "when I press a guide point" and then exactly what you see? Thanks.
Trekster 10 Posted June 23, 2018 Author Posted June 23, 2018 1. Open emby 2. Open guide 3. Now press on any item, it will show "null" 4. If I choose something and wait a sec or two before opening to see a description, it will be ok. This is on an nVidia shield TV. I'll post a video of this tomorrow when I get home. Sent from my SM-G965F using Tapatalk
Trekster 10 Posted June 24, 2018 Author Posted June 24, 2018 Hi @@ebr These two images are from the guide. First I browse to a item press it - no description or just "null" Then I go back and present it again - now full description. Sent from my SM-G965F using Tapatalk
ebr 16337 Posted June 25, 2018 Posted June 25, 2018 What happens if you wait just a few seconds before bringing it up the first time?
Trekster 10 Posted June 26, 2018 Author Posted June 26, 2018 What happens if you wait just a few seconds before bringing it up the first time?If I wait 2 seconds then it will be ok. But that is not the behaviour of our household. We would browse and then choose to see a description, not pause and then choose. That's why the Kodi solution worked as it was cached data for the next 24 hours. Sent from my SM-G965F using Tapatalk
Trekster 10 Posted June 26, 2018 Author Posted June 26, 2018 (edited) Is your server on your local network or remote? The server is hosted in a docker container on my DS3617xs. Locally, it is wired to my network with 1Ggbit and the Shield is on AC-WiFi connected with 866mbit. The docker container along with the config folder is on pure Intel DC3610 SSD storage(RAID10), so there shouldn't be any bottlenecks. Edited June 26, 2018 by Trekster
okEric 2 Posted July 17, 2018 Posted July 17, 2018 I'm noticing the same issue. It's if I select an item then push select quickly it'll show as null and if I close and then reopen it shows the information. If I pause like was mentioned before selecting it doesn't seem to have the issue.
