nobody01 89 Posted June 22, 2018 Posted June 22, 2018 (edited) I can't seem to find anything relating to throttling transcoding / remux? Problem: 4K Transcoding / Remux - It uses a lot of space thus drives are filling up based on transcoding settings at the moment as Emby is transcoding the whole file, thus with a 4K remux / transcode this could be 60GB and multiple this if you have multiple users.Remuxing seems to cause problems event when its out remuxing audio / container as it will fill up the disk. Fix: Ability to throttle transcoding to be 5-10 minutes ahead of current time Edited June 22, 2018 by jaketame
nobody01 89 Posted June 28, 2018 Author Posted June 28, 2018 Anything on this or did I miss some history? Cheers
ebr 16338 Posted June 28, 2018 Posted June 28, 2018 The history is we used to try to do this and it didn't work very well. The tools we use for transcoding don't really provide any way to accomplish this goal. Always possible we can revisit it though. 1
nobody01 89 Posted June 29, 2018 Author Posted June 29, 2018 The history is we used to try to do this and it didn't work very well. The tools we use for transcoding don't really provide any way to accomplish this goal. Always possible we can revisit it though. Def think this should be a core future, especially in larger deployments of Emby and even more so with 4K content becoming more mainstream... Are there any workarounds? Filesystem hacks? I tried putting transcode into /dev/shm but this just causes system to halt.
Luke 42246 Posted June 29, 2018 Posted June 29, 2018 ffmpeg doesn't have any kind of api for this so it would require us to add these features to it ourselves.
nobody01 89 Posted June 29, 2018 Author Posted June 29, 2018 ffmpeg doesn't have any kind of api for this so it would require us to add these features to it ourselves. presuming thats a massive undertaking?
Luke 42246 Posted July 7, 2018 Posted July 7, 2018 It's doable but yes it would be a bit of an effort.
nobody01 89 Posted September 11, 2018 Author Posted September 11, 2018 This can be closed and awesome work thanks Luke! 1
