linds1234 19 Posted June 21, 2018 Posted June 21, 2018 Hi All, Has anyone else experienced an issue with the screen saver setting going back to "none" ? I found this thread suggesting it could be happening from a corrupt "guisettings.xml" file: https://forum.kodi.tv/showthread.php?tid=328242 After the setting gets reverted, If I create a new "guisettings.xml" file with the required screensaver info, it seems to work for a random amount of time then gets set back to "none" again. Could this previous Emby for Kodi bug possibly have cropped up again?: https://emby.media/community/index.php?/topic/40992-emby-disables-kodi-screensaver/ Thank you, Lindsay
feerlessleadr 173 Posted June 21, 2018 Posted June 21, 2018 damn, this has been happening to me for months on both Krypton and Leia (as well as on both my Shields and my Minix box). I just assumed it was a kodi bug, never knew it may be related to emby for kodi. It doesn't happen at a set interval, so I'm not sure how to pin down a log of it happening. 1
Angelblue05 4132 Posted June 21, 2018 Posted June 21, 2018 What screensaver are you using? Just disable the setting in the add-on > sync option > sync while screensaver is on.
linds1234 19 Posted June 22, 2018 Author Posted June 22, 2018 Hi @@Angelblue05, I'm using one of the built in screensavers that just Dims the screen after x minutes. The add-on setting that you have mentioned has always been turned off (by default), "sync when screensaver is deactivated" is the actual setting name. I've now *enabled* it to see if it helps? Cheers, Lindsay 1
Angelblue05 4132 Posted June 23, 2018 Posted June 23, 2018 Fixed with the latest 3.0.31 - The setting was broken, so make sure you disable it. 1
linds1234 19 Posted June 23, 2018 Author Posted June 23, 2018 Many thanks @@Angelblue05, I'll give it a shot today
abescalamis 88 Posted June 24, 2018 Posted June 24, 2018 The visualization on Android Kodi Leia doesn't work, and is not related to the Addon, and it works on other versions, Mac and Windows seem to work. 1
linds1234 19 Posted June 28, 2018 Author Posted June 28, 2018 Just reporting back to confirm that the screensaver setting looks to be sticking now. Many thanks @@Angelblue05 1
