hellothere 0 Posted June 19, 2018 Posted June 19, 2018 (edited) Hi there I am a big fan of Emby but unfortunately, the sync function has issues recently. This Problem has persisted over the last couple of versions, currently I'm running 3.4.1 Whenever I start a sync job (directly to a device or FolderSync), it straight out ignores whatever quality I choose and copies the video stream. I am running Emby in a Linux docker container without HW acceleration, transcoding works without issues (on the same files). Edit: I added a debug log output but didn't update the transcoding log, it is however identical. $ head -n 100 transcode-22c772cd-8bbd-4e7f-8891-b3db7e7ede0d.txt/bin/ffmpeg -f matroska,webm -i file:"/INPUTFILE.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 6 -ab 384000 -ar 44100 -y "/cache/997447703e724a9ca0d24cfa9ff90bcd/fc54258c307540b380a8af3015919a5f/aa37542ed82f443b9690af5c1d20067a.mp4"ffmpeg version 4.0 Copyright © 2000-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --cc=x86_64-pc-linux-gnu-gcc --cxx=x86_64-pc-linux-gnu-gcc --arch=x86_64 --prefix=/home/embybuilder/Buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-xlib --enable-fontconfig --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --extra-libs='-ldl -lexpat -lfreetype -lfribidi -lfontconfig -liconv -logg -lpng -luuid -lvorbis -lz -lgmp -lhogweed -lnettle -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static --enable-gnutls --enable-libsmbclient --enable-cuda --enable-cuvid --enable-nvenc --enable-vaapi libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100Input #0, matroska,webm, from 'file:/INPUTFILE.mkv': Metadata: encoder : libebml v1.3.0 + libmatroska v1.4.1 creation_time : 2014-07-28T07:51:13.000000Z Duration: 00:23:56.04, start: 0.000000, bitrate: 13066 kb/s Stream #0:0(eng): Video: h264 (High), yuv420p(progressive), 1920x1080, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Metadata: BPS : 11555109 BPS-eng : 11555109 DURATION : 00:23:56.018000000 DURATION-eng : 00:23:56.018000000 NUMBER_OF_FRAMES: 34430 NUMBER_OF_FRAMES-eng: 34430 NUMBER_OF_BYTES : 2074168070 NUMBER_OF_BYTES-eng: 2074168070 _STATISTICS_WRITING_APP: mkvmerge v7.0.0 ('Where We Going') 32bit built on Jun 9 2014 15:08:34 _STATISTICS_WRITING_APP-eng: mkvmerge v7.0.0 ('Where We Going') 32bit built on Jun 9 2014 15:08:34 _STATISTICS_WRITING_DATE_UTC: 2014-07-28 07:51:13 _STATISTICS_WRITING_DATE_UTC-eng: 2014-07-28 07:51:13 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default) Metadata: title : English BPS : 1509000 BPS-eng : 1509000 DURATION : 00:23:56.043000000 DURATION-eng : 00:23:56.043000000 NUMBER_OF_FRAMES: 134629 NUMBER_OF_FRAMES-eng: 134629 NUMBER_OF_BYTES : 270873636 NUMBER_OF_BYTES-eng: 270873636 _STATISTICS_WRITING_APP: mkvmerge v7.0.0 ('Where We Going') 32bit built on Jun 9 2014 15:08:34 _STATISTICS_WRITING_APP-eng: mkvmerge v7.0.0 ('Where We Going') 32bit built on Jun 9 2014 15:08:34 _STATISTICS_WRITING_DATE_UTC: 2014-07-28 07:51:13 _STATISTICS_WRITING_DATE_UTC-eng: 2014-07-28 07:51:13 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (dts (dca) -> aac (native)) Press [q] to stop, [?] for helpOutput #0, mp4, to '/cache/997447703e724a9ca0d24cfa9ff90bcd/fc54258c307540b380a8af3015919a5f/aa37542ed82f443b9690af5c1d20067a.mp4': Metadata: encoder : Lavf58.12.100 Stream #0:0: Video: h264 (High) (avc1 / 0x31637661), yuv420p(progressive), 1920x1080 [sAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 16k tbn, 1k tbc (default) Stream #0:1: Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, 5.1, fltp, 384 kb/s (default) Metadata: encoder : Lavc58.18.100 aac 2018-06-19 08:51:08.919 Info App: Profile: Cloud Sync, Path: /INPUTFILE.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True2018-06-19 08:51:08.935 Info App: Profile: Cloud Sync, No direct play profiles found for Path: /INPUTFILE.mkv2018-06-19 08:51:08.982 Info TaskManager: Queueing task SyncConvertScheduledTask2018-06-19 08:51:08.982 Info TaskManager: Executing Convert media2018-06-19 08:51:09.004 Info App: Profile: Cloud Sync, Path: /INPUTFILE.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True2018-06-19 08:51:09.004 Info App: Profile: Cloud Sync, No direct play profiles found for Path: /INPUTFILE.mkv2018-06-19 08:51:09.038 Info HttpServer: HTTP Response 200 to 192.168.1.177. Time: 426ms. http://192.168.1.55:8096/emby/Sync/Jobs2018-06-19 08:51:09.214 Info MediaSourceManager: Live tv media info probe took 0.1033189 seconds2018-06-19 08:51:09.290 Info MediaEncoder: /bin/ffmpeg -f matroska,webm -i file:"/INPUTFILE.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 6 -ab 384000 -ar 44100 -y "/cache/2e16f682d2d744918e4d6914bd022f4c/3f2ac2b195ca469888e8d3fcf8b3ab5f/86de6e52ca5941678ed527a836f0a11f.mp4" Any ideas what could cause this? Thanks Edited June 19, 2018 by hellothere
Luke 42210 Posted June 19, 2018 Posted June 19, 2018 Hi, I'm not able to reproduce this. I would suggest trying again with the next release as something may have been fixed along the way. Thanks !
