Hyp3rD 10 Posted June 18, 2018 Posted June 18, 2018 Hello, I would like to point out some small things to fix for a future update. The first, when the band "next episode" appears, some of the text is found below the buttons. Secondly, when we leave a reading of the episode, we should make sure that there is a refresh of the screen so that the next episode is not the one just heard and that the number of the pastille be updated. Finally, I do not know why, the sound of the theme continues to play sometimes in the background when you leave the application using the Home button. So, thank you for this great AndroidTV app, I love the design!
ebr 16337 Posted June 19, 2018 Posted June 19, 2018 The first, when the band "next episode" appears, some of the text is found below the buttons. The buttons are on the right side of the screen, correct? Can you capture a screen shot of what you mean here? Secondly, when we leave a reading of the episode, we should make sure that there is a refresh of the screen so that the next episode is not the one just heard and that the number of the pastille be updated. Sorry, not sure exactly what you are referring to here... Do you mean after playback? The detail screen is actually refreshed after playback and it should show you the episode that just played.
ebr 16337 Posted June 19, 2018 Posted June 19, 2018 Finally, I do not know why, the sound of the theme continues to play sometimes in the background when you leave the application using the Home button. So, thank you for this great AndroidTV app, I love the design! If you press the home button, it should stop. What type of device? What remote? Does this always happen or only sometimes?
Hyp3rD 10 Posted June 21, 2018 Author Posted June 21, 2018 Sorry if I'm not precise, English is not my first language, but I'm working on it. For the buttons, they are a bit too wide, which overlaps the description of the next episode slightly. It's probably due to the French language, I think the words in the buttons longer than the English ones. Regarding the theme of the series that seems to continue after pressing the Home button, it does not seem to do it systematically. It's as if the OS would consider the theme as music and continue to play in the background ... All on a Sony 2017 with the remote and the home symbol shown as on a standard Android device.
ebr 16337 Posted June 21, 2018 Posted June 21, 2018 It's probably due to the French language, I think the words in the buttons longer than the English ones. Ah, yes, that's probably it. Thanks.
okEric 2 Posted July 17, 2018 Posted July 17, 2018 I think I'm having the same issue with the tiles getting cut off. You can see here that the bottom row is cut off when the tile is selected. Not sure if there's actually more content below that line.
ebr 16337 Posted July 19, 2018 Posted July 19, 2018 I think I'm having the same issue with the tiles getting cut off. You can see here that the bottom row is cut off when the tile is selected. Not sure if there's actually more content below that line. Hi. This is a completely different issue from this topic. What version of the app are you running? 1
okEric 2 Posted July 19, 2018 Posted July 19, 2018 Hi ebr, I'm on version 1.6.08g. I believe this is the beta version. I had this issue prior to joining beta, was just curious to see if it made any difference.
ebr 16337 Posted July 20, 2018 Posted July 20, 2018 Hi ebr, I'm on version 1.6.08g. I believe this is the beta version. I had this issue prior to joining beta, was just curious to see if it made any difference. This should be fixed in 1.6.09. Thanks. 1
okEric 2 Posted July 21, 2018 Posted July 21, 2018 This should be fixed in 1.6.09. Thanks. Thanks ebr, mine just updated and I can confirm that the issue is fixed.
