thor2002ro 5 Posted June 15, 2018 Posted June 15, 2018 (edited) windows server running latest beta with live tv and dvb viewer plugin live tv works but there are no options to switch audio stream or enable subtitles ffmpeg is listing all the streams in log Program 656 Metadata: service_name : HBO2 HD service_provider: DIGI TV Stream #0:0[0x19a1]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x19a2](rum): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:2[0x19a6](rum): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:3[0x19a7](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:4[0x19a3](hun): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:5[0x19a4](eng): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, 5.1(side), fltp, 384 kb/s Log.txt Edited June 15, 2018 by thor2002ro
Luke 42244 Posted June 15, 2018 Posted June 15, 2018 Can you please attach the corresponding emby server log as well? thanks.
pünktchen 1411 Posted June 24, 2018 Posted June 24, 2018 @@pünktchen are you able to reproduce? thanks. Yes, no chance to switch audio tracks or to enable subtitles for live tv with external tv plugins in browsers and both android apps. This problem exists since you've implemented caching of the live tv probe.
thor2002ro 5 Posted June 26, 2018 Author Posted June 26, 2018 and.... can we do anything about it? seams a pretty big thing to be omitted since emby's focus is not supporting tv tuners directly with decoding and all.... so most of the time a 3rd party server will be used....
pünktchen 1411 Posted June 27, 2018 Posted June 27, 2018 Are you setting the MediaSource.Id value?Yes, but it changes with every play attempt!
pünktchen 1411 Posted June 27, 2018 Posted June 27, 2018 What do you mean by that?I mean every time a live tv stream is requested i set a new unique mediasource id in the plugin. Otherwise this would happen: User 1 starts streaming channel A, after that user 2 also starts streaming channel A. If user 1 now stops streaming channel A, it would also stop the stream for user 2.
Luke 42244 Posted June 29, 2018 Posted June 29, 2018 Ok. I'm not sure if this will resolve it yet, but please try the next beta server. Thanks.
Luke 42244 Posted July 11, 2018 Posted July 11, 2018 Ok i have this working for the next release, but only if the MediaSource coming out of the plugin is using the http protocol. I'll look at more protocols later but this is all i can test with next pvr. @@pünktchen, do either of your plugins return a file based media source? if so then we can work together and get that sorted out. It's basically running through the same mechanisms as our native tuner support, so going forward that will make this quite a bit more reliable.
pünktchen 1411 Posted July 12, 2018 Posted July 12, 2018 Works in browsers and both Android apps. Great job!
