jglazer63 23 Posted June 14, 2018 Posted June 14, 2018 There are two TV series: Justice League Justice League Unlimited These are both animated from 2001-2005. Try as I might I cannot get emby to recognize the unlimited series. It keeps wanting to create it as just "Justice League" and then season 1 and season 2 clash. How can I tell it which series it is? Maybe by IMDB number or something?
Luke 42210 Posted June 14, 2018 Posted June 14, 2018 Hi, you currently can't other than making sure the files to be organized are named justice league unlimited instead of justice league. if that's not possible then you may not want to expose these particular files to auto organize. Edit: Actually the smart match feature might be able to help you, however this is all community contributed and I don't know too much about how it works. @@softworkz or @@PoppyPop might be able to help. Thanks.
jglazer63 23 Posted June 14, 2018 Author Posted June 14, 2018 Hi, you currently can't other than making sure the files to be organized are named justice league unlimited instead of justice league. if that's not possible then you may not want to expose these particular files to auto organize. Edit: Actually the smart match feature might be able to help you, however this is all community contributed and I don't know too much about how it works. @@softworkz or @@PoppyPop might be able to help. Thanks. I have a folder under TV called "Justice League" and one called "Justice League - Unlimited". In the Auto Organize folder selection for series it shows two "Justice League" entries. Might be nice if the developer could read a text file or something to get the series IMDB name or proper information. No way to do that right?
Luke 42210 Posted June 14, 2018 Posted June 14, 2018 Well there isn't currently a way. What I'm referring to is the file name of the videos to be organized. if they contain "justice league - unlimited", then i would think it should go to the right series.
jglazer63 23 Posted June 14, 2018 Author Posted June 14, 2018 Yea but part of what the organizer does is skim information about the series. If it chooses the wrong series the info will be wrong.
Luke 42210 Posted June 14, 2018 Posted June 14, 2018 Actually i'm pretty sure all it does is look at the file name, and try and use that to figure out what series it belongs to. This is where I think the smart match feature is intended to be a manual override.
rhodges 49 Posted June 14, 2018 Posted June 14, 2018 See my post here. Maybe this is the cause: https://emby.media/community/index.php?/topic/59910-folders-joining-on-emby-server/&do=findComment&comment=588076
