nebur 1 Posted June 13, 2018 Posted June 13, 2018 (edited) First sorry for my poor english. My emby server is 3.4.1.0 over ubuntu bionic with a ssl cert self signet without password. The client emby web has worked well ever but Emby for kodi since 3.0.27a (and up, I am not sure if someone earlier too) don't connect. I try with krypton, Leia, newer 3.029a, ... but the issue persists.I wan't to update server to beta. I attach kodi log and the error in the server. The problem solved installing version 2.3.63 from https://github.com/MediaBrowser/plugin.video.emby/releases. There are some older version newer? Can you tell if it's possible to update to the lastet version when was solved. Thanks Edited June 14, 2018 by nebur
nebur 1 Posted June 13, 2018 Author Posted June 13, 2018 I see this and I try in the past to turn off and turn on. I turn off now and the issue persist.
Angelblue05 4132 Posted June 13, 2018 Posted June 13, 2018 Can you provide a new Kodi log with the setting disabled? It should work as it was tested with a user with this same issue. Thank you.
nebur 1 Posted June 13, 2018 Author Posted June 13, 2018 (edited) Here you have. Thanks Edited June 14, 2018 by nebur
dcrdev 255 Posted June 13, 2018 Posted June 13, 2018 (edited) I have what seems like an ssl issue - A couple of days ago Emby for Kodi stopped starting up - no error or anything like that, just wouldn't start. I thought maybe it would be fixed by the updates you've been doing recently however now they have landed - I still faced the same issue. I removed the plugin directory and Kodi database and attempted to reconfigure - I'm being hit by an invalid credentials message. Emby for me goes via a reverse proxy that utilises a self signed cert on the internal domain (dns) and a valid cert on the external domain (cloudflare). Bypassing the proxy and connecting directly to Emby via http - works and I don't get the invalid credentials message. I don't have a log right now (need to figure out how to get one off an nvidia shield) , but if one's needed to diagnose the issue I can provide it. Edit: Oh forgot to mention verify ssl is disabled. Edited June 13, 2018 by dcrdev
Angelblue05 4132 Posted June 13, 2018 Posted June 13, 2018 (edited) I'm looking into it right now. Give me a few. Edited June 13, 2018 by Angelblue05
Angelblue05 4132 Posted June 13, 2018 Posted June 13, 2018 (edited) @@dcrdev I've checked nebur's logs and it doesn't look like the issue is coming from Emby for Kodi. If you can provide your own log, then I can confirm if your error is different. What I'm seeing is the setting verify ssl is passed correctly as False. But the connection is refused by the server. Then if you try to do anything, it will complain because your server is not connected. I have another user with a self signed cert and they say it's working for them... If you are able to provide your log, then I'll be able to investigate further. Thank you Edited June 13, 2018 by Angelblue05
nebur 1 Posted June 14, 2018 Author Posted June 14, 2018 Ok, but why all was working until now? and why with 2.3.63 works? Thanks
sualfred 677 Posted June 14, 2018 Posted June 14, 2018 I haven't looked into the logs but I can confirm that it's working with both common methods: A certificate directly stored and configured in the Emby server Nginx reverse proxy Both scenarios are using a cert which I created with certbot / letsencrypt To see if a SSL configuration is working correctly -> https://www.ssllabs.com/ssltest/ 1
Angelblue05 4132 Posted June 14, 2018 Posted June 14, 2018 (edited) @@nebur I sent you a message yesterday about your server info, you didn't reply. (Sorry I don't want to do this here because that'd expose your server info). But in your log what I saw is it didn't connect, then you try to play something and it doesn't work because your not connected to the server. I'll wait for your reply. Edited June 14, 2018 by Angelblue05
Angelblue05 4132 Posted June 15, 2018 Posted June 15, 2018 Ok, after some troubleshooting with nebur, we found the issue. I'm about to post a new build.
fattony 4 Posted June 15, 2018 Posted June 15, 2018 3.0.30 seems to have fixed the issue for me! Thanks 1
dcrdev 255 Posted June 17, 2018 Posted June 17, 2018 @@Angelblue05 the latest build seems to have got me further - now the first login dialogue seems to work, but a subsequent login dialogue still fails with "invalid password". I'm PM'ing you my log - as I noted it stores passwords in plain text (yikes) and I'm not 100% confident that everything got scrubbed as part of a find/replace.
Angelblue05 4132 Posted June 17, 2018 Posted June 17, 2018 (edited) @@dcrdev I think you forgot to attach your log in your pm. Also, the add-on doesn't log or save your password? The only time I've seen this happen is with the Kodi logging for keyboards. But I have no control over that. Edited June 17, 2018 by Angelblue05
dcrdev 255 Posted June 17, 2018 Posted June 17, 2018 @@dcrdev I think you forgot to attach your log in your pm. Also, the add-on doesn't log or save your password? The only time I've seen this happen is with the Kodi logging for keyboards. But I have no control over that. Yeah it's the keyboard logging that's spitting the password out in plain text - nonetheless the the plugin is spitting out the hashed password: 21:38:51.668 T:139190047824 NOTICE: EMBY.downloadutils -> DEBUG:: {'url': '{emby-server}/emby/Users/AuthenticateByName?format=json', 'json': {'username': 'Dominic', 'password': 'Replaced'}, 'params': None, 'timeout': 30} Not saying there's anything wrong with that per-se - just don't want it in a public post. Sent you a new PM.
Angelblue05 4132 Posted June 17, 2018 Posted June 17, 2018 Ah well yes, I'll give you that, in debug mode, which other than debugging purpose would not be enabled, it prints all requests. But at least the pass is hashed, it's not clear text as you said.
dcrdev 255 Posted June 17, 2018 Posted June 17, 2018 Sorted - the verify ssl setting had reverted to on after I wiped the addon data. 1
