Problem playing next episode from AppleTV 'Top Level'
Victorious
When I select the next episode of a show as displayed at the 'top level' of the AppleTV menu, ie. not from within Emby, then the Emby logo displays briefly followed by the message:
"Oops, Something went wrong...
undefined is not an object"
Pressing 'menu' on the remote then takes me into the main Emby screen, from where I can play the episode successfully.
I have tried restarting the Emby app and the AppleTV, but the issue is still there.
Any help would be appreciated :-)
@@Victorious --
Thanks for reporting this. I just did a quick bit of testing on my setup and I was able to repeat this. We'll let you know when it's fixed.
  • Like 1
Victorious
Thank you corey for your very speedy response :-)
@@Victorious
We pushed out an update today. If you force close the app and restart it should be fixed.
  • Like 1
Victorious
@@Victorious
Thanks corey. I noticed late yesterday that there was an update, and now all is well :-) Thank you for addressing it so promptly.
Glad to hear it’s working!
