l0fL 0 Posted June 13, 2018 Posted June 13, 2018 Hello everybody, I've a selfmade NAS (xpenology) with an Intel Pentium Gold G4620 Kaby Lake CPU und 4GB Ram. DSM & Emby are up to date. I used the "normal" emby from this repo https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586 . When I want to transcode a movie my cpu is about 80% workload. If i reduce the Quality i've round about 55%. It doesnt matter which settings i use (QuickSync, VAAPI...)-, it's always the same. Actually my cpu would have to decode in hardware, but it doesnt seem that way. How can i transcode in Hardware and yes the hook on hardware encoding is set. Thank you!
Luke 42241 Posted June 13, 2018 Posted June 13, 2018 Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
l0fL 0 Posted June 13, 2018 Author Posted June 13, 2018 (edited) My workload The small slope in the beginning was transcode at 1080p 60 Mbit/s and the increase was 480p. The file is a native 1080p file. I have the same result if i choice Quick Sync. my settings and my log https://paste2.org/aYAGfHsB Edited June 13, 2018 by l0fL
l0fL 0 Posted June 13, 2018 Author Posted June 13, 2018 (edited) But why is my CPU on 80%? If it were Hardware Decoding it schould be at 5-10%. Edited June 13, 2018 by l0fL
l0fL 0 Posted June 14, 2018 Author Posted June 14, 2018 What is the right attitude then? Are my settings correct? That's why I bought a Kaby Lake CPU.
Luke 42241 Posted June 15, 2018 Posted June 15, 2018 Have you added user emby to the video group on the Synology? Beyond that we'll see what @@solabc16 thinks. Thanks !
solabc16 379 Posted June 25, 2018 Posted June 25, 2018 Hello @@l0fL Which XPEnology setup are you using and what DSM version? Best - James
eevv 0 Posted July 28, 2018 Posted July 28, 2018 Hi Luke I've just been setting up Emby on a DS415Play Evansport the last few days. I installed from package center, and after did the SSH procedure of changing ffmpeg version or whatever it was. Can you explain a bit more what you mean by what you say here ? I have no user "emby", but package installed created user "embysrvr". It is by default only a member of the "users" group, one of the three default groups (others are "administrators" and "http (system default group for web services)". So should there be a user called emby and or a user group called video after package install ? Or do you just mean that the embysrvr user must be gives read/write access to the video shared folder ? Thanks for your help. Have you added user emby to the video group on the Synology? Beyond that we'll see what @@solabc16 thinks. Thanks !
Luke 42241 Posted July 28, 2018 Posted July 28, 2018 @@solabc16 will know the answer to this, thanks !
solabc16 379 Posted July 30, 2018 Posted July 30, 2018 Hello @@eevv You don't need to make any further changes within DSM, other than setting up your library permissions as detailed on the Wiki here : https://github.com/MediaBrowser/Wiki/wiki/Synology-:-Setting-Up-Your-Media-Library-Share Let's continue on the other thread if necessary, as this one relates to XPEnology based systems : https://emby.media/community/index.php?/topic/43282-hw-transcoding-on-evansport-ds415playds214play-machines/?p=603485 Best - James
l0fL 0 Posted July 31, 2018 Author Posted July 31, 2018 Hello @@solabc16 my xpenology setup Intel Pentium G4620 H270N-WIFI Motherboard 4GB Ram 500GB 860 Evo SSD for the DSM 5x 6TB WD Red DSM Version 6.1.7 - 15284 June Loader 1.02b xs3615+
solabc16 379 Posted July 31, 2018 Posted July 31, 2018 Hello @@l0fL The problem we can see from the log is... [AVHWDeviceContext @ 0x869c00] No VA display found for device: /dev/dri/renderD128. Device creation failed: -22. Failed to set value '/dev/dri/renderD128' for option 'vaapi_device': Invalid argument Error parsing global options: Invalid argument ...from other reports, getting GPU support working seem to be a little hit and miss with XPEnology; at the moment at the least. From an SSH session can you run the below and post the output here:- cd /var/packages/EmbyServer/target/ffmpeg/bin sudo ./vainfo Best - James
l0fL 0 Posted August 1, 2018 Author Posted August 1, 2018 @@solabc16 This is my output error: failed to initialize display I've no display at my NAS station. But in BIOS iGPU is on AUTO. Is that my mistake? From an SSH session can you run the below and post the output here:- cd /var/packages/EmbyServer/target/ffmpeg/bin sudo ./vainfo
solabc16 379 Posted August 2, 2018 Posted August 2, 2018 Thanks @@l0fL Mentioning @@Joly0 here, who has reported similar findings with getting their XPEnology setup. Primarily, this is an XPEnology 'issue', and I don't mean that in the sense of it being a fault or bug. Have you tried the DS916+ or DS918+ loaders, which target h/w that does natively have GPU support? I don't believe the DS3615xs kernel includes the necessary device drivers, as although the CPU might be capable of supporting h/w transcoding, this model was targeted at 'business' users and hence they were not included. Best - James
erikblues 4 Posted November 23, 2018 Posted November 23, 2018 (edited) Is this procedure still required or is this done automatically in new versions? I am on the DS415play, what would be the correct setting for me? Model: DS415play CPU: Intel Atom CE5335 Cores: Dual Core Threads: 4 FPU: Yes Package Arch: Evansport RAM: DDR3 1 GB Edited November 23, 2018 by erikblues
Luke 42241 Posted November 23, 2018 Posted November 23, 2018 It will be more automatic with the next release. Thanks. 1
solabc16 379 Posted November 23, 2018 Posted November 23, 2018 (edited) Hello @@erikblues There is no native h/w transcoding support available with 'evansport' based systems, there's a couple of posts kicking around on the subject which provide some background. e.g. https://emby.media/community/index.php?/topic/64770-error-in-screen-grabber-extracting-images/?p=648088 https://emby.media/community/index.php?/topic/43282-hw-transcoding-on-evansport-ds415playds214play-machines/?p=603858 https://emby.media/community/index.php?/topic/43282-hw-transcoding-on-evansport-ds415playds214play-machines/?p=443715 Best - James Edited November 23, 2018 by solabc16 1
