wilnel 0 Posted June 9, 2018 Posted June 9, 2018 I was wondering if emby premier works for hauppauge dcr-2560, live tv and dvr on windows 10.Is there a way I can test this instead of buying this product?
Luke 42244 Posted June 9, 2018 Posted June 9, 2018 Hi, yes you can set everything up. You'll only be prompted for premiere when you try to play or record. Thanks.
wilnel 0 Posted June 9, 2018 Author Posted June 9, 2018 well that is the main thing I need to check if it records and plays...geez. lol I guess I will try 1 month.
