chessdragon136 677 Posted March 31, 2014 Author Posted March 31, 2014 (edited) New version - v0.340 released: @@c0m3r @@CBers Correct model number should show in dashboard Users can now enter a hostname instead of an IP -> For users who want to change the setting you need to run the app, and on the Users page press the BLUE button - this should quit the app, and you can relaunch it and re-enter your server settings. If it does not exit, you must manually exit the app - DO NOT LOG IN - PLEASE LET ME KNOW if the blue button does NOT exit the app.. Please note I have not done any design work for people using this app with a server that is NOT in the local area network. I do not know if it works, and there are no transcoding profiles so I can't imagine playback will be nice either... And before anyone asks, I CANNOT under any circumstances that I currently know of use a full qwerty keyboard. That is why, just like users passwords, they are saved so you only go through the initial pain once. sorry but it is the best I can do. Lost of caps there, sorry.. Edited March 31, 2014 by chessdragon136 3
CBers 7554 Posted March 31, 2014 Posted March 31, 2014 (edited) Not sure Genres are working correctly, at least for me. This is what is displayed for TV and Movies: I think the numbers (172, 192, 152) relate to the Movies in each Genre, as they appear in the Dashboard: So looks like just the images aren't being displayed. Edited March 31, 2014 by CBers
chessdragon136 677 Posted March 31, 2014 Author Posted March 31, 2014 (edited) Ok think I have the culprit - Re-update please and let me know -> Have added a reference screenshot Also, is your Main Menu bar always stuck to the bottom of the menu like that (compare to my screens for compare) Sorry Edited March 31, 2014 by chessdragon136
c0m3r 95 Posted March 31, 2014 Posted March 31, 2014 (edited) Are you connecting to a server outside your local area network then? Must admit I haven't tested that this would work - If not just assign the local ip address of the server.. And yes I can try create a toggle between ip and URI entry but I don't know how Javascript handles external connections (usually blocks them) All of the ones in my home are local obviously but I have been playing with getting it set up for my brother. Working quite well in main apps and wanted to give it a go with this. EDIT - thanks for the update, will give it a whirl. Edited March 31, 2014 by c0m3r
CBers 7554 Posted March 31, 2014 Posted March 31, 2014 Genre images showing now, thanks. What do you mean about the menu?
chessdragon136 677 Posted March 31, 2014 Author Posted March 31, 2014 (edited) Another New Version - v0.350 Genre views are now implemented (And it contains my first attempt at a graphic! Go check it out lol)Enjoy Edited March 31, 2014 by chessdragon136 1
chessdragon136 677 Posted March 31, 2014 Author Posted March 31, 2014 Ok Thanks And look at the below - Your menu items are rooted to the bottom of the menu bar area where mine hover vertically centrally Is it like that on all your pages?
CBers 7554 Posted March 31, 2014 Posted March 31, 2014 I see what you mean. Yes, always been like that I believe.
coolspot 22 Posted April 1, 2014 Posted April 1, 2014 I got this installed and it worked well in the quick test I did of video playback. I had a couple initial problems during setup. The first has already been solved after reading through the rest of the posts, but I had to go into the Tools menu to find the Developer menu as my blue D button didn't do anything. No biggie. I did have some problems with password entry, and I'm not sure if this is more of a samsung problem or what. I had problems using the default password entry as I would push a "7" for "r". A list of letters and words appeared across the top and I would push the "enter" button "between the four arrow keys to select "r" and it just started back over. Not choosing the "r". I ended up finding I could change my password entry to use the old cellphone text method of pushing the 7 four times to get the "r" and got my password entered correctly" Hope I explained that well enough.
ginjaninja 605 Posted April 1, 2014 Posted April 1, 2014 @@chessdragon136 Great to see you are developing a samsung client, thank you. I will test it out this weekend if the developer install works on my 2012 e series. If not, could be the reason I need to splash out on evolution kit. For all our sakes I wish you all the best on this project. Made my week this has. And its only tuesday! Sent from my GT-I9505 using Tapatalk
Smaky 131 Posted April 1, 2014 Posted April 1, 2014 Testing latest alpha... so long so good! No biggies.
gillmacca 17 Posted April 1, 2014 Posted April 1, 2014 Having a problem with my password. My password contains a zero, but when i press zero on my remote, it just enters a space, no menu appears at the top for zero
Rowlett 9 Posted April 1, 2014 Posted April 1, 2014 (edited) Having a problem with my password. My password contains a zero, but when i press zero on my remote, it just enters a space, no menu appears at the top for zero you have to press TTX/MIX to change input type to numeric @chessdragon - excellent editions to the app! it's coming on nicely!!! :-D Edited April 1, 2014 by Rowlett
chessdragon136 677 Posted April 1, 2014 Author Posted April 1, 2014 I did have some problems with password entry, and I'm not sure if this is more of a samsung problem or what. I had problems using the default password entry as I would push a "7" for "r". A list of letters and words appeared across the top and I would push the "enter" button "between the four arrow keys to select "r" and it just started back over. Not choosing the "r". I ended up finding I could change my password entry to use the old cellphone text method of pushing the 7 four times to get the "r" and got my password entered correctly" Hope I explained that well enough. Honestly, I'm still a bit confused -> Any chance of a photo or two showing this please? It sounds like a Samsung problem but I'm not 100% sure
Yogi 367 Posted April 1, 2014 Posted April 1, 2014 Ok Thanks And look at the below - Your menu items are rooted to the bottom of the menu bar area where mine hover vertically centrally Is it like that on all your pages? The placement of the menu on mine is the same as CBers,at the bottom. All files are playing fine but I presume you cannot get DTS audio playing through the app. 1
DaN 49 Posted April 1, 2014 Posted April 1, 2014 All files are playing fine but I presume you cannot get DTS audio playing through the app. I think that info display should be better utilized to show played content information, such as bitrate, and output audio type Sent from my HTC Butterfly using Tapatalk
chessdragon136 677 Posted April 1, 2014 Author Posted April 1, 2014 DTS Audio - what currently happens, does the file play with no audio or not play at all or something else? Can you also provide me the Audio Codec Specs from the web interface please.
CBers 7554 Posted April 1, 2014 Posted April 1, 2014 All files are playing fine but I presume you cannot get DTS audio playing through the app. I have DTS playing through the app. I think the TV just converts it to stereo though, as that's what my Sonos PlayBar sees it as.
Yogi 367 Posted April 1, 2014 Posted April 1, 2014 (edited) DTS Audio - what currently happens, does the file play with no audio or not play at all or something else? Can you also provide me the Audio Codec Specs from the web interface please. Yes DTS plays with the audio coming through as only 2 channel pcm Audio Info: Language engCodec DCA Profile DTS Layout 5.1 Bitrate 1536 kbps Sample Rate 48000 khz Default Yes Dolby Digital 5.1 comes through ok. Edited April 1, 2014 by Yogi
CBers 7554 Posted April 1, 2014 Posted April 1, 2014 @@chessdragon136 - just noticed that I don't get the green circles with the number count in, as per your genre image - should I? Also, there's no WATCHED indicator - will that come in time?
chessdragon136 677 Posted April 1, 2014 Author Posted April 1, 2014 @@Yogi - That is good. I have just tried to implement DTS and sadly I have no idea if it works. Can you update the app and play the file, then whilst playing hit info. I need to know all that is there please - Thank you @@CBers -> Yes you should see it.. Are the numbers anywhere on the screen (they were in your previous screenshots when the background image wasnt working..)
CBers 7554 Posted April 1, 2014 Posted April 1, 2014 @@CBers -> Yes you should see it.. Are the numbers anywhere on the screen (they were in your previous screenshots when the background image wasnt working..) Yes, the numbers are in the genre display, but no green circle background. What about WATCHED status?
chessdragon136 677 Posted April 1, 2014 Author Posted April 1, 2014 Are the numbers in the right place - top right? - New version pushed out so try that, but i'm doubtful it will work. And watched isn't in yet, nor any other indicators - not much point if I cant make this one work!
CBers 7554 Posted April 1, 2014 Posted April 1, 2014 Updated - still v0.350? Numbers are top right, but no green circle.
chessdragon136 677 Posted April 1, 2014 Author Posted April 1, 2014 Ok is now fixed for the next release
