CBers 7554 Posted July 24, 2014 Posted July 24, 2014 (edited) I've answered that before - i have no idea OK. I thought it might be listed in the Samsung SDK somewhere. I tried googling it, but nothing definitive - seems like a generic error message. Edited July 24, 2014 by CBers
chessdragon136 677 Posted July 24, 2014 Author Posted July 24, 2014 Ok re-released v0.482 but without background image - that is much more difficult than originally thought due to trying to support css2 and 3.
CBers 7554 Posted July 24, 2014 Posted July 24, 2014 (edited) Ok re-released v0.482 but without background image - that is much more difficult than originally thought due to trying to support css2 and 3.Music looks OK now. Thanks. Shame about the background images. Could you change the grey static background to a black one in the interim ? Anything specific you need testing? Edited July 24, 2014 by CBers 1
DaN 49 Posted July 25, 2014 Posted July 25, 2014 (edited) Ok re-released v0.482 but without background image - that is much more difficult than originally thought due to trying to support css2 and 3.Like the new library layout with plenty of movie information; butPlay doesn't work in anything but TV shows, also what's meant by css2 and 3? DaN Edited July 25, 2014 by DaN
CBers 7554 Posted July 25, 2014 Posted July 25, 2014 (edited) Like the new library layout with plenty of movie information; but Play doesn't work in anything but TV shows, also what's meant by css2 and 3? DaN Don't say that, I haven't tried movies yet. I had the same problem a few weeks ago, which turned out to be a problem with MBS. Which level of MBS are you running? CSS is Cascading Style Sheets. They're used to format the layout of HTML etc. CSS2 and 3 are the different versions of it. . Edited July 25, 2014 by CBers
DaN 49 Posted July 25, 2014 Posted July 25, 2014 Don't say that, I haven't tried movies yet. I had the same problem a few weeks ago, which turned out to be a problem with MBS. Which level of MBS are you running? CSS is Cascading Style Sheets. They're used to format the layout of HTML etc. CSS2 and 3 are the different versions of it. . Movie chapters section works, if l select any scene it plays, bout play doesn't respond, I'm not sure about server version, I'll check it when I'm homeAnd thanks for the info on Css, I assume the layout will be smarter and better designed DaN
CBers 7554 Posted July 25, 2014 Posted July 25, 2014 @@DaN - I'll have a play with movies a bit later and report back.
DaN 49 Posted July 25, 2014 Posted July 25, 2014 Thanks @@CBers I'm on MBS version # 3.0.5309.26857 Which is the latest beta I think DaN
klave7 0 Posted July 25, 2014 Posted July 25, 2014 (edited) Like the new library layout with plenty of movie information; but Play doesn't work in anything but TV shows, also what's meant by css2 and 3? DaN I can also confirm that Play does not work in Movies, neither does resume, though selecting a chapter does. Edited July 25, 2014 by klave7
DaN 49 Posted July 25, 2014 Posted July 25, 2014 I can also confirm that Play does not work in Movies, neither does resume, though selecting a chapter does.Could you please mention your MBS version #? DaN
chessdragon136 677 Posted July 25, 2014 Author Posted July 25, 2014 It's probably mu messup after removing the code for backdrops - did it in a rush to get a decent version out and made a hash of it. I'm not at my pc, stuck waiting for trains so will look at it when i can Sorry guys! As for CSS its the markup language for html. Basically newer tv's use html 5 and css3 but older ones use html4 and css2. Samsung changed their rendering engine which causes problems. But hey ho. 1
DaN 49 Posted July 25, 2014 Posted July 25, 2014 Ok v0.482a released to fix issue where movies were broken.I'm check out when home, thanks @@chessdragon136 DaN
CBers 7554 Posted July 25, 2014 Posted July 25, 2014 It's probably mu messup after removing the code for backdrops - did it in a rush to get a decent version out and made a hash of it. I'm not at my pc, stuck waiting for trains so will look at it when i can Sorry guys! No worries
Smaky 131 Posted July 26, 2014 Posted July 26, 2014 (edited) I have just installed the app in my UN60D6450 TV. Installation worked just fine. However, whenever I launch the application I get the screen asking for the Server IP address and port or the web addres. I am unable to enter the addrres using my remote. Regardless of the setting for keypad I select (Green button) I always get characters and although I could cycle until a digit is shown, that does not happen for the zero digit (which enters a space). Do I need to do something to have the remote input just numbers? Edit: Nevermind, I figured it out... pressing "Shift" changes between input modes. Edited July 26, 2014 by Smaky 2
chessdragon136 677 Posted July 26, 2014 Author Posted July 26, 2014 Ok v0.482a released to fix issue where movies were broken. 2
CBers 7554 Posted July 26, 2014 Posted July 26, 2014 Ok v0.482a released to fix issue where movies were broken. That's all working now, thanks
c0m3r 95 Posted July 26, 2014 Posted July 26, 2014 Can someone please find me some suitable open source icons and I'll happily implement them - Im not an artist and can't make my own. Have a look at the link below Chess. There doesnt appear to be any claim to the icons and they are pretty simple. Should do just fine unless someone with graphical experience makes some better ones. http://mediabrowser.tv/community/index.php?/topic/8151-mediainfo-icons/
chessdragon136 677 Posted July 26, 2014 Author Posted July 26, 2014 Ok Collections question - Can collections only be of one type? Using the web interface I can only seem to add movies to collections? Are collections essentially just movie boxsets now? Does anyone know?
CBers 7554 Posted July 26, 2014 Posted July 26, 2014 I think @@ebr or @@Luke will confirm, but I believe you can add TV shows, music and movies into a collection in the Dashboard, but they do differ from BoxSets. I personally use the Auto-BoxSets plugin to group my movies into collections, but don't group TV so, music and movies together. I think that's right, but I could be completely wrong
DaN 49 Posted July 26, 2014 Posted July 26, 2014 Ok Collections question - Can collections only be of one type? Using the web interface I can only seem to add movies to collections? Are collections essentially just movie boxsets now? Does anyone know? I have some collections, you just add movies to a folder that is named as boxset, and the MBS will recognize as a collection DaN
CBers 7554 Posted July 26, 2014 Posted July 26, 2014 I have some collections, you just add movies to a folder that is named as boxset, and the MBS will recognize as a collection DaN Do you not use the Auto-BoxSets plugin? It'll do it all for you.
Bohemi 3 Posted July 27, 2014 Posted July 27, 2014 Hi, I installed v0.482a successfully with the installation steps from this topic. My TV is a Samsung UE40EH5300. I can connect to the server but in the next screen where you can select the user, it stops. I can only change the server or go to smart Hub main page. Did I mis a step? rgrds
chessdragon136 677 Posted July 27, 2014 Author Posted July 27, 2014 (edited) Hmm sorry @Bohemi When you say it stops what do you mean? Does the page load fully (take a picture of the users page if you can) Can you see your user? and what happens when you select it? And what buttons are responsive on that page (it sounds like you can navigate away from the page once its stopped. Edited July 27, 2014 by chessdragon136
