chessdragon136 677 Posted July 22, 2014 Author Posted July 22, 2014 What do you see instead? Screenshot if possible please
Jasin 11 Posted July 22, 2014 Posted July 22, 2014 What do you see instead? Screenshot if possible please Just the normal view that was there before. Whats the best way to take a shot on a Samsung? (besides snapping a photo with my phone)
chessdragon136 677 Posted July 22, 2014 Author Posted July 22, 2014 Ok and in the settings page there should be a setting called portrait mode? Is that true... And yes that is the only way i'm afraid but that isn't necessary now
Jasin 11 Posted July 22, 2014 Posted July 22, 2014 (edited) Ok and in the settings page there should be a setting called portrait mode? Is that true... And yes that is the only way i'm afraid but that isn't necessary now I went to go look and take pictures but I see the posters and the option now. Those weren't there yesterday after the update. Maybe having the tv turn off and on helped? Edit - Thanks for the quick response. Edited July 21, 2014 by Jasin
chessdragon136 677 Posted July 22, 2014 Author Posted July 22, 2014 Yes I really should put this in the opening page = basically uninstall old version, reboot tv and then update to new is the best way to install. Glad it woks - shame i'm pushing another update out in a bit and you'll have to do it all over again 2
Jasin 11 Posted July 22, 2014 Posted July 22, 2014 Yes I really should put this in the opening page = basically uninstall old version, reboot tv and then update to new is the best way to install. Glad it woks - shame i'm pushing another update out in a bit and you'll have to do it all over again No worries, good to know. Seems like something Samsung should address, doesn't seem to handle updates well. Everytime Plex updates on there as well you have to reconnect to your account.
DaN 49 Posted July 22, 2014 Posted July 22, 2014 3D playback has been looked into - i can make it work on select tv's but not others, so it was removed. if you mean that 3D auto switching works on certain models, I assume the code will through an error on unsupported models, right? Can you add supported models to your code to avoid that error? DaN
CBers 7554 Posted July 22, 2014 Posted July 22, 2014 Check to see if your friend TV is able to access other "Internet" items. Check IP settings on it. Just cover the basics of connectivity. I'm sure you've done it but always good to go over twice incase something was missed. Larry Yes I did all that I've been using this app since the very early releases so I know what to do, but for the life of me, I couldn't figure it out. All other Internet-based apps on the TV (75E6500) work fine.
CBers 7554 Posted July 22, 2014 Posted July 22, 2014 @@chessdragon136 - can't seem to connect to your IP address (from 1st post) to re-install the app. I'm getting ERROR_DEVELOPMENT_002.
above1 45 Posted July 22, 2014 Posted July 22, 2014 Yes I did all that I've been using this app since the very early releases so I know what to do, but for the life of me, I couldn't figure it out. All other Internet-based apps on the TV (75E6500) work fine. I figured you would have.. I'll give it a try once I get home and report back. I will likely have the same result you did. no issues. 1
CBers 7554 Posted July 22, 2014 Posted July 22, 2014 I figured you would have.. I'll give it a try once I get home and report back. I will likely have the same result you did. no issues. Thanks above1.
chessdragon136 677 Posted July 22, 2014 Author Posted July 22, 2014 3D playback has been looked into - i can make it work on select tv's but not others, so it was removed. Fast forward was never implemented - only the 30 second skip. Samsung doesnt natively support fast seeking (doesnt work on my twonky DLNA) I think the allshare can do it but you have to set loads of http headers and its a mess. I will get a proper interface in so you can select a point in the file to skip to.
CBers 7554 Posted July 23, 2014 Posted July 23, 2014 (edited) @@chessdragon136 - can't seem to connect to your IP address (from 1st post) to re-install the app. I'm getting ERROR_DEVELOPMENT_002. A bit more information. The above was on my friend's Samsung TV which has v0.460e into. I couldn't update to v0.480, which I run, due to the above error. On returning home, I can update (nothing to actually update) OK on my TV. Any idea why my friend's TV was getting that error please? Should I get him to uninstall and install it and try again? He can't use it currently, as all that is displayed is MediaBrowser3 and the version number. MBS is running, as MBC can see it OK. Thanks. Edited July 22, 2014 by CBers
klave7 0 Posted July 23, 2014 Posted July 23, 2014 3D playback has been looked into - i can make it work on select tv's but not others, so it was removed. Fast forward was never implemented - only the 30 second skip. Samsung doesnt natively support fast seeking (doesnt work on my twonky DLNA) I think the allshare can do it but you have to set loads of http headers and its a mess. I will get a proper interface in so you can select a point in the file to skip to. Thanks for the info. Skipping to the part of the file would be perfect. I look forward to when it's implemented.
CBers 7554 Posted July 23, 2014 Posted July 23, 2014 (edited) Depending on the TV, it will automatically switch to 3D mode. Well, it does on my F8000, so I don't need anything adding to play 3D movies. . Edited July 22, 2014 by CBers
above1 45 Posted July 23, 2014 Posted July 23, 2014 Depending on the TV, it will automatically switch to 3D mode. Well, it does on my F8000, so I don't need anything adding to play 3D movies. . 3D playback has been looked into - i can make it work on select tv's but not others, so it was removed. Fast forward was never implemented - only the 30 second skip. Samsung doesnt natively support fast seeking (doesnt work on my twonky DLNA) I think the allshare can do it but you have to set loads of http headers and its a mess. I will get a proper interface in so you can select a point in the file to skip to. Hmm.. I have HSBS titles and on my ES8000 it does not automatically switch to 3D, wish it would. If I go into the 3D menu, HSBS is greyed out. I am unable to select it. Also, like DaN mentioned, yes, is it possible to add if...then "supported models" to the code to detect 3D capabilities? Thanks again. above1
above1 45 Posted July 23, 2014 Posted July 23, 2014 A bit more information. The above was on my friend's Samsung TV which has v0.460e into. I couldn't update to v0.480, which I run, due to the above error. On returning home, I can update (nothing to actually update) OK on my TV. Any idea why my friend's TV was getting that error please? Should I get him to uninstall uninstall it and try again? He can't use it currently, as all that is displayed is MediaBrowser3 and the version number. MBS is running, as MBC can see it OK. Thanks. Check to see if your friend TV is able to access other "Internet" items. Check IP settings on it. Just cover the basics of connectivity. I'm sure you've done it but always good to go over twice incase something was missed. Larry
above1 45 Posted July 23, 2014 Posted July 23, 2014 Thanks above1. So it goes to download but does nothing now. Seems like the server is not uploading the file. I guess @@chessdragon136 will have to look at it on his end. Above1
CBers 7554 Posted July 23, 2014 Posted July 23, 2014 So it goes to download but does nothing now. Seems like the server is not uploading the file. I guess @@chessdragon136 will have to look at it on his end. Above1 You don't get an error though?
c0m3r 95 Posted July 23, 2014 Posted July 23, 2014 Think the IP on the first page is wrong. He changed it later in the thread after his ISP changed his IP address. Have a search through and try the second one he gave.
CBers 7554 Posted July 23, 2014 Posted July 23, 2014 (edited) Think the IP on the first page is wrong. He changed it later in the thread after his ISP changed his IP address. Have a search through and try the second one he gave.No, he updated the first post with the new IP. As I said above, I can get a download to work OK on my TV, even if it is the same version, I just couldn't get access to it last night on my friend's Samsung TV. . Edited July 23, 2014 by CBers
above1 45 Posted July 24, 2014 Posted July 24, 2014 No, he updated the first post with the new IP. As I said above, I can get a download to work OK on my TV, even if it is the same version, I just couldn't get access to it last night on my friend's Samsung TV. . it worked now for me. Although it did go a lot slower that usual. above1 1
chessdragon136 677 Posted July 24, 2014 Author Posted July 24, 2014 3D playback - The supported models bit isnt if the tv supports 3d but that the code itself only works on certain models so i need to find a more universal code source. As for install issues, my server is ok.. Still the same ip as on the first page. Not sure what to suggest.
CBers 7554 Posted July 24, 2014 Posted July 24, 2014 @@chessdragon136 - what does ERROR_DEVELOPMENT_002 mean please?
chessdragon136 677 Posted July 24, 2014 Author Posted July 24, 2014 @@chessdragon136 - what does ERROR_DEVELOPMENT_002 mean please? I've answered that before - i have no idea
