AndyNichs 1 Posted July 2, 2014 Posted July 2, 2014 Sorry, still comes up with "undefined Connection error"...
chessdragon136 677 Posted July 2, 2014 Author Posted July 2, 2014 (edited) Hmm ok it sounds like the Samsung doesn't play nice with m2ts natively - probably needs a transcode of some sort (and my transcode settings are very early in development) I could really do with a sample video for testing purposes - are you able to provide a small one? Also, if you play it via dlna can you see if the server is transcoding it? Edited July 1, 2014 by chessdragon136
AndyNichs 1 Posted July 2, 2014 Posted July 2, 2014 Yeah if I play it through DLNA it plays fine, not sure how I find out if the server is transcoding it though. Sorry...
CBers 7554 Posted July 2, 2014 Posted July 2, 2014 Yeah if I play it through DLNA it plays fine, not sure how I find out if the server is transcoding it though. Sorry... Check the servers log folder and see if a transcoding/ffmpeg file is there. Also, check if ffmpeg is running.
AndyNichs 1 Posted July 2, 2014 Posted July 2, 2014 Yeah looks like it... ffmpeg version N-63911-g3a1c895 Copyright © 2000-2014 the FFmpeg developers built on Jun 11 2014 22:01:49 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib libavutil 52. 89.100 / 52. 89.100 libavcodec 55. 66.100 / 55. 66.100 libavformat 55. 43.100 / 55. 43.100 libavdevice 55. 13.101 / 55. 13.101 libavfilter 4. 8.100 / 4. 8.100 libswscale 2. 6.100 / 2. 6.100 libswresample 0. 19.100 / 0. 19.100 libpostproc 52. 3.100 / 52. 3.100 Input #0, mpegts, from 'file:B:\VIDEO\Movies (New)\Back To The Future.m2ts': Duration: 01:56:00.96, start: 11.692700, bitrate: 4796 kb/s Program 1 Stream #0:0[0x1011]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709), 1920x1040, 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc Stream #0:1[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 448 kb/s Output #0, mpegts, to 'C:\Media Browser\6d11b5c0-0257-74ca-362a-3b1f3b9cf78a.ts': Metadata: encoder : Lavf55.43.100 Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), yuv420p, 1920x1040, q=2-31, 128 kb/s, 23.98 fps, 90k tbn, 23.98 tbc Stream #0:1: Audio: ac3, 48000 Hz, 5.1, fltp, 128 kb/s Metadata: encoder : Lavc55.66.100 ac3 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (ac3 (native) -> ac3 (native)) Press [q] to stop, [?] for help 1
Luke 42241 Posted July 2, 2014 Posted July 2, 2014 you can also find out transcoding status from the dashboard active devices 1
chessdragon136 677 Posted July 2, 2014 Author Posted July 2, 2014 Thanks - I'm still concerned why it's throwing a connection error though, thats a samsung error message rather than my own.. Try send me a test file and i can properly diagnose. 1
chessdragon136 677 Posted July 2, 2014 Author Posted July 2, 2014 Upload it wherever you can, though I doubt the forums will let you load it here.. Send me a pm when its up somewhere
chessdragon136 677 Posted July 2, 2014 Author Posted July 2, 2014 Ok v0.460c pushed out to try fix @@AndyNichs - Don't expect it to work but the above screenshot showed enough that I know my transcode wasn't working properly... The Stream.m is wrong, all transcoded content should be stream.ts... Try and let me know but this is my last update until tomorrow now. Enjoy
sornis 0 Posted July 2, 2014 Posted July 2, 2014 Enabling experimental mode in the menu may let you play it but in truth i haven't had the time to really get this sorted.. Sorry experimental is always on
AndyNichs 1 Posted July 2, 2014 Posted July 2, 2014 Ok, I get the following message now... CONNECTION ERROR http://192.168.1.83:8096/mediabrows static=true&MediaSourceId=7079e Hope this helps...
chessdragon136 677 Posted July 2, 2014 Author Posted July 2, 2014 The above seems yo have cut off a load of the middle part..
sornis 0 Posted July 2, 2014 Posted July 2, 2014 Ok v0.460c pushed out to try fix @@AndyNichs - Don't expect it to work but the above screenshot showed enough that I know my transcode wasn't working properly... The Stream.m is wrong, all transcoded content should be stream.ts... Try and let me know but this is my last update until tomorrow now. Enjoy in .460b i tried it and i had the same problem as @@AndyNichs after update to.460c problem solved
AndyNichs 1 Posted July 2, 2014 Posted July 2, 2014 Brilliant it worked, thank you.... Tried it on several films and all play without any issues
chessdragon136 677 Posted July 2, 2014 Author Posted July 2, 2014 Ok new build v0.460b out for @@AndyNichs to test - Fixed a transcoding bug which i think was the cause of your issue.
chessdragon136 677 Posted July 3, 2014 Author Posted July 3, 2014 Ok update again and try now - it will look ugly but hopefully it'l show you the entire URL - I can't believe how much of an arse this is becoming!
AndyNichs 1 Posted July 3, 2014 Posted July 3, 2014 Yeah sorry about this, I can't believe I'm the only one that has this problem though?
chessdragon136 677 Posted July 3, 2014 Author Posted July 3, 2014 Haha don't worry about it - you're just the first to report thats all... Let me know how it goes
sornis 0 Posted July 3, 2014 Posted July 3, 2014 silly question... i'm having the same problem with adult collection as I have with music videos... all playable as movie but when I classify them as music video or adult then its a no go.. not implemented yet right?
chessdragon136 677 Posted July 3, 2014 Author Posted July 3, 2014 Enabling experimental mode in the menu may let you play it but in truth i haven't had the time to really get this sorted.. Sorry
sornis 0 Posted July 3, 2014 Posted July 3, 2014 Yeah sorry about this, I can't believe I'm the only one that has this problem though? I don't use that format but I will download a sample to see if I have the same problem with my tv
AndyNichs 1 Posted July 3, 2014 Posted July 3, 2014 LOL You're not going to believe this but the screen isn't big enough now
above1 45 Posted July 3, 2014 Posted July 3, 2014 Brilliant it worked, thank you.... Tried it on several films and all play without any issues I too am using the Samsung app on my es8000 55in'er. I'll download 460c and test as I was having the connection error issue as well with some TV shows and Movies. Thanks for all you hard work and dedication to this. Larry
