chessdragon136 677 Posted May 18, 2014 Author Posted May 18, 2014 Ok ignore that (Been fixed now if you want to re-update) - when you run the app does it say v0.420 in the bottom right - thats the only one that matters
radeon 758 Posted May 18, 2014 Posted May 18, 2014 OK cool, now when im in the smart hub and i hover the app, the version is the 0.420 but when i actually run the app, bottom right says v0.400
mbnwa 49 Posted May 18, 2014 Posted May 18, 2014 Mine now shows up as 0.420 and M4V's are working correctly Sent from my iPhone using Tapatalk 1
chessdragon136 677 Posted May 18, 2014 Author Posted May 18, 2014 OK cool, now when im in the smart hub and i hover the app, the version is the 0.420 but when i actually run the app, bottom right says v0.400 Ok that shouldn't be possible - What screen do you load into (The home screen, server ip settings or user login page?) Re-update the app again - perhaps uninstall the previous one first?
radeon 758 Posted May 18, 2014 Posted May 18, 2014 Server ip screen so I have to enter the IP details before i can see the version (only a 22" i bought for the spare room so i think the version number sits behind the on screen keyboard) Tried an update, also tried a uninstall/reinstall. just gona try a "turn it off and back on again" lol,
mbnwa 49 Posted May 18, 2014 Posted May 18, 2014 I had to uninstall - pull the power cord for 30sec's - plug back in - log in as develop - enter IP - Sync and it showed up as expected from that point.
radeon 758 Posted May 18, 2014 Posted May 18, 2014 ahh! the trusty off and back on again fixed it! how strange! :-/ didnt even have to reinstall the app, epic samsung!
CBers 7554 Posted May 18, 2014 Posted May 18, 2014 I'm unable to update. Getting "Unable to connect to the server. Please try again later" Also getting "ERROR_DEVELOPMENT 0002".
Yogi 367 Posted May 19, 2014 Posted May 19, 2014 (edited) Hey chess, Starting to look really good. Installed and nearly everything played correctly that I threw at it. Liike the config menu makes it easy to select DTS etc. The only thing that wasn't correct was a couple of movies I have are TrueHD and it only played them back as PCM. Oh 1 other thing it picks up DTS but not DTS HD-MA. Loving the app more and more everyday. Cheers Yogi Edited May 19, 2014 by Yogi 1
DaN 49 Posted May 20, 2014 Posted May 20, 2014 I'm unable to update. Getting "Unable to connect to the server. Please try again later" Also getting "ERROR_DEVELOPMENT 0002". Same is here Sent from my HTC Butterfly using Tapatalk
CBers 7554 Posted May 21, 2014 Posted May 21, 2014 Same is here Sent from my HTC Butterfly using Tapatalk I haven't been able to try the last 2 days, but will tomorrow.
CBers 7554 Posted May 21, 2014 Posted May 21, 2014 I haven't been able to try the last 2 days, but will tomorrow. Retried today and the app updated OK. Now running v0.420 Im still having yto change audio output on TV from PCM to DOLBY on first playback.
ABNParatrooper 6 Posted May 24, 2014 Posted May 24, 2014 I got this working, thanks for the hard work. Can't wait for the jump feature (press a letter and it goes to movies that match) and subtitle. Again, awesome app and thanks again.
Tanamur 53 Posted May 24, 2014 Posted May 24, 2014 Samsung SMART Media Player (GX-SM530CF) - This device looks like it could extend the Samsung app to any tv as well as providing a cable card slot (if you live in a part of the world that supports it). Is the testing at a point to where anyone would estimate when it might be in the Samsung app store? Thanks, Tanamur
chessdragon136 677 Posted May 24, 2014 Author Posted May 24, 2014 I got this working, thanks for the hard work. Can't wait for the jump feature (press a letter and it goes to movies that match) and subtitle. Again, awesome app and thanks again. Hi there @@abnranger67 In many pages which have 1 set of items (like listing all movies) it is possible to press the Red button and it will skip through all the letters of the alphabet (so press it once for numbers, press again for A, then B and so on...) There is no visual element for which letter you are on except what it jumps to (its a feature in progress but required for us with lots of content) Hope that helps @@Yogi @@CBers - All audio switching was disabled in the latest build as Samsung have identified a critical bug with it.. So it shouldn't work @@Tanamur - There is no ETA and it will be a long time off - the process to get the app on the market is a long one and thus i don't want to start it until I have all elements in my alpha code so I only have to do it once! (Sure there will probably be updates but they will be minor) 1
CBers 7554 Posted May 24, 2014 Posted May 24, 2014 @@Yogi @@CBers - All audio switching was disabled in the latest build as Samsung have identified a critical bug with it.. So it shouldn't work Latest build of your app ?? Have you submitted it to Samsung then ?? TIA.
chessdragon136 677 Posted May 24, 2014 Author Posted May 24, 2014 Latest build of your app ?? Have you submitted it to Samsung then ?? TIA. Sorry no I havent made a submission - I am just using the developer tools available to me to check my code is valid.. This particular problem flagged as an issue (I knew i was doing it wrong)
CBers 7554 Posted May 24, 2014 Posted May 24, 2014 OK, thanks chess. As long as I can still manually switch to Dolby, I can live with it until a fix is available.
TolkienBard 58 Posted May 25, 2014 Posted May 25, 2014 So I downloaded this last night and all the menus and such seem to be working properly. However, whenever I select a title and then select play, I get "Undefined connection error". The app has obviously been able to connect to my PC in the other room though, as it is seeing the library. I get the art, the titles, the actor crossties, etc. I tried selecting a chapter to play instead of just using the "play" button. When I do this, the screen goes black and the only way to recover is to press "exit", leaving the app.
chessdragon136 677 Posted May 26, 2014 Author Posted May 26, 2014 So I downloaded this last night and all the menus and such seem to be working properly. However, whenever I select a title and then select play, I get "Undefined connection error". The app has obviously been able to connect to my PC in the other room though, as it is seeing the library. I get the art, the titles, the actor crossties, etc. I tried selecting a chapter to play instead of just using the "play" button. When I do this, the screen goes black and the only way to recover is to press "exit", leaving the app. Ok that's odd -> Can you provide me with as much detail as you can please (File details of the file from the web interface, tv model, server build) and I can look into it. Thanks
DaN 49 Posted May 26, 2014 Posted May 26, 2014 Is it the same IP? I'm still getting the same error Sent from my HTC Butterfly using Tapatalk
TolkienBard 58 Posted May 27, 2014 Posted May 27, 2014 (edited) Ok that's odd -> Can you provide me with as much detail as you can please (File details of the file from the web interface, tv model, server build) and I can look into it. Thanks Here's what I have so far: Media Browser Server: Version 3.0.5238.39498 Samsung Plasma TV: PN60E550 App Version: .420 (downloaded late night on May 24th) The rest of my file paths should all be default. Cache: C:\Users\James\AppData\Roaming\MediaBrowser-Server\cache Images by name: C:\Users\James\AppData\Roaming\MediaBrowser-Server\ImagesByName Logs: C:\Users\James\AppData\Roaming\MediaBrowser-Server\logs Metadata: C:\Users\James\AppData\Roaming\MediaBrowser-Server\data\metadata Transcoding temporary files: C:\Users\James\AppData\Roaming\MediaBrowser-Server\transcoding-temp After getting some guidance, I have attached my server log from the most recent attempt to make this function on my home network. Server Log.txt Edited May 26, 2014 by TolkienBard
CBers 7554 Posted May 27, 2014 Posted May 27, 2014 If I can figure out how to attach a file to a post, I can upload my server log for my latest attempt to get this working. Have a read of How to Report a Problem. 1
TolkienBard 58 Posted May 27, 2014 Posted May 27, 2014 Have a read of How to Report a Problem. I think I need glasses. I actually browsed through there, but somehow I missed the "More Reply Options" part of the post. Ugh. Thanks. 1
