pappaq 8 Posted June 9, 2018 Posted June 9, 2018 Hello there, I've got the following issue. For 2 of 10 users the transcoding of all tested movies work, but for the other 8 some movies doesn't. The server transcodes via software, so no hardware transcoding and for the two working users it runs like a charm. The problem accures in the intranet and over the https connection. Logs are attached. Any ideas? cheers
ebr 16310 Posted June 9, 2018 Posted June 9, 2018 Hi. What does "doesn't work" mean? What app(s) are the different users using?
pappaq 8 Posted June 9, 2018 Author Posted June 9, 2018 I've tried it with every user on emby theater. Doesn't work means, that some movies, are not getting transcoded on 8 of the 10 users. But the remaining two work well with all movies.
Luke 42210 Posted June 9, 2018 Posted June 9, 2018 What do you mean by not getting transcoded? I'm uncertain about what the problem is. Thanks.
pappaq 8 Posted June 9, 2018 Author Posted June 9, 2018 Ok. When I log in with one of the working users, the playback with transcoding works for every movie. But that only works with 2 of 10 users. When I log in with one of the 8 other users, the exact same movie won't play, if it needs transcoding. The spinning circle just does its thing and nothing happens. With the working users, the transcode starts in a matter of one second and the playback begins.
Happy2Play 9802 Posted June 10, 2018 Posted June 10, 2018 Have you changed the Transcoding options at all? Dashboard-Transcoding
pappaq 8 Posted June 10, 2018 Author Posted June 10, 2018 Can you try a different video? I have an some work and some don't, as I mentioned above. Do you need the logs of another attempt with a different movie?
pappaq 8 Posted June 10, 2018 Author Posted June 10, 2018 Have you changed the Transcoding options at all? Dashboard-Transcoding I don't thinks so. I've changed the temp folder location from default. But that was my first thought trying to solve it. I wondered if it had anything to do with permissions in windows and changed it but the problem persists.
pappaq 8 Posted June 11, 2018 Author Posted June 11, 2018 I've found the failure. The subtitle option was set to standard in the 8 not working profiles. I've set it to "no subtitles" now and it works like a charm. Thank you guys anyways. cheers
