nobody01 89 Posted June 7, 2018 Posted June 7, 2018 (edited) 2018-06-07 13:25:37.212 Info App: /bin/ffmpeg -analyzeduration 3000000 -user_agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.85 Safari/537.36" -fflags +igndts -i "http://****613.m3u8" -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 20000000 -bufsize 40000000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=0:-1:0,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -vsync -1 -codec:a:0 libmp3lame -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/81b903a757e164a8838ac709ed6c5dee/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/config/transcoding-temp/81b903a757e164a8838ac709ed6c5dee.m3u8" -y "/config/transcoding-temp/81b903a757e164a8838ac709ed6c5dee%d.ts" 2018-06-07 13:25:37.505 Error HttpServer: Error processing request *** Error Report *** Version: 3.4.1.12 Command line: /system/EmbyServer.dll -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.9.0.6 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: /config Application directory: /system System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, EncodingOptions encodingOptions, CancellationTokenSource cancellationTokenSource, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, EncodingOptions encodingOptions, CancellationTokenSource cancellationTokenSource, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IHttpRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) System.Exception at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, EncodingOptions encodingOptions, CancellationTokenSource cancellationTokenSource, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, EncodingOptions encodingOptions, CancellationTokenSource cancellationTokenSource, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IHttpRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) 2018-06-07 13:25:37.505 Info HttpServer: HTTP Response 500 to 90.255.44.248. Time: 952ms. ******8096/videos/e3b98ca29694552b1fb1c738d0742aa7/live.m3u8?DeviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTNfNCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY1LjAuMzMyNS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3NjkxNTE0NjAx&MediaSourceId=483a6e65702fc09e0c1b0ae521ac0e83&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=-1&VideoBitrate=119808000&AudioBitrate=192000&PlaySessionId=c422c928dfb34318ae09b9ecc0d2a20e&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_483a6e65702fc09e0c1b0ae521ac0e83&TranscodingMaxAudioChannels=2&RequireAvc=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported Edited June 7, 2018 by jaketame
nobody01 89 Posted June 7, 2018 Author Posted June 7, 2018 Most likely a bad url URL is ok, I can stream in VLC ok without issues.
