Remote Control Bugs/Problems
dr_faulkner
In Emby Theater, holding the volume down button on the remote decreases volume (as expected) but when it reaches zero it jumps to full volume! This is not a desirable feature! I assume it is a bug.
Also, it would be nice if the Back button worked all the way back to the main menu - e.g.: if you are in music albums pressing Back would take you back to Music in the main menu - not to the first menu item
Thanks for the report. We'll take a look.
