thekingswolf 48 Posted June 7, 2018 Posted June 7, 2018 What is this? I can't see the file path for whatever it is or any information, and I can't delete it? Anyone seen this before?
Happy2Play 9806 Posted June 7, 2018 Posted June 7, 2018 What do the IMDB, TheTVDB, and Trakt links point to? But the overview obviously point to something from TheTVDB. Basically TVDB saying your Series is not a true series Example from their forum https://forums.thetvdb.com/viewtopic.php?t=21946
Luke 42217 Posted June 7, 2018 Posted June 7, 2018 That's interesting. You would think they would just not have it in their database rather than sending back that junk data.
kevinp 2 Posted July 16, 2018 Posted July 16, 2018 So, my question is, how do I get rid of the " ** 403: Series Not Permitted ** " ? I've got the Looney Tunes Golden Collection, which used to be allowed at theTVdb. I've edited the metadata and changed the title on the main page, but each of my Seasons still show ** 403: Series Not Permitted ** as the title and I can't see a way to get rid of it.
Luke 42217 Posted July 16, 2018 Posted July 16, 2018 I don't know why tvdb would send that kind of data back instead of just deleting their database entry if they don't want it. I think you can try using the identify feature to correct this but there might be some manual editing required.
Happy2Play 9806 Posted July 17, 2018 Posted July 17, 2018 (edited) If I remember correctly they were merged. What tvdbid do you have? https://www.thetvdb.com/series/looney-tunes I think your only option is to delete the TVDBid and lock the metadata. Or your have to break them out as movies as listed on TMDB. https://www.themoviedb.org/movie/465022-looney-tunes-golden-collection-vol-1?language=en-US Edited July 17, 2018 by Happy2Play
Luke 42217 Posted April 19, 2019 Posted April 19, 2019 Does anyone have a tvdb id that causes this problem? I can update the tvdb plugin to basically ignore it and treat it as if no metadata is found. This will at least prevent the display of the junk data they're sending back. Thanks. @@Happy2Play
Happy2Play 9806 Posted April 19, 2019 Posted April 19, 2019 (edited) Does anyone have a tvdb id that causes this problem? I can update the tvdb plugin to basically ignore it and treat it as if no metadata is found. This will at least prevent the display of the junk data they're sending back. Thanks. @@Happy2Play Well I used the example above "Looney Tunes Golden Collection". Look at the Alias list. Not sure how it would apply to the ones listed in the other topic. https://www.thetvdb.com/api/GetSeries.php?seriesname=Looney+Tunes+Golden+Collection&language=en or directly from their site https://www.thetvdb.com/series/403-series-not-permitted Edited April 19, 2019 by Happy2Play
Luke 42217 Posted April 19, 2019 Posted April 19, 2019 Ok so what i can do is look for that in the series name and then just ignore the data. 1
pwhodges 2028 Posted April 19, 2019 Posted April 19, 2019 (edited) An example of a series that gives this message is 337269 (which I expected to be blocked, frankly, as it's NSFW) which Emby finds as 313081, which gives the message above instead of proper information. Edited April 19, 2019 by pwhodges 1
Luke 42217 Posted April 19, 2019 Posted April 19, 2019 I've pushed an update to the tvdb plugin for this. Thanks guys.
