Animosity022 6 Posted June 6, 2018 Posted June 6, 2018 (edited) I can see in the logs that this is transcoding but I'm not sure why. Emby is telling me the Video Codec is not supported: TranscodeReasons=VideoCodecNotSupported Here is the mediainfo as well: [felix@[member="Gemini"] logs]$ mediainfo "/gmedia/Movies/Blade.Runner.(1982)/Blade.Runner.1982.mp4" General Complete name : /gmedia/Movies/Blade.Runner.(1982)/Blade.Runner.1982.mp4 Format : MPEG-4 Commercial name : HDR10 Format profile : Base Media Codec ID : isom (isom/iso2/mp41) File size : 41.4 GiB Duration : 1 h 57 min Overall bit rate : 50.4 Mb/s Movie name : Blade Runner 1982 The Final Cut 4K Writing application : Lavf58.12.100 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 1 h 57 min Bit rate : 50.0 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 23.976 (24000/1001) FPS Minimum frame rate : 23.188 FPS Maximum frame rate : 24.390 FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.251 Stream size : 41.0 GiB (99%) Writing library : ATEME Titan File 3.8.3 (4.8.3.0) Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Menus : 3 Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 1655 cd/m2 Maximum Frame-Average Light Level : 117 cd/m2 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : ac-3 Duration : 1 h 57 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 377 MiB (1%) Title : TrueHD Atmos 7.1 Language : English Service kind : Complete Main Default : Yes Alternate group : 1 Menus : 3 ffmpeg-transcode-1172402a-1a9f-43cc-8c0d-02326f21811f.txt Edited June 6, 2018 by Animosity022
Solution corey 317 Posted June 7, 2018 Solution Posted June 7, 2018 Apple TV is pretty limited in the formats it supports for 4K. In the media info above it says the codec ID is hev1 but the one Apple supports I believe is either hvc or hvc1. There’s a few other threads where folks have reported the same thing. With that said we’ll be bringing a new player to the app and hopefully this won’t be a problem any longer. 3
Everbrave 62 Posted June 8, 2018 Posted June 8, 2018 (edited) Apple TV is pretty limited in the formats it supports for 4K. In the media info above it says the codec ID is hev1 but the one Apple supports I believe is either hvc or hvc1. There’s a few other threads where folks have reported the same thing. With that said we’ll be bringing a new player to the app and hopefully this won’t be a problem any longer. Any ETA for the new (mpv based?) player? In fact, the limitations of Apple native player make both Plex and Emby clients on ATV almost useless without Transcoding especially for HEVC which in fact supported by iOS but only in one flavor. Edited June 8, 2018 by Everbrave
corey 317 Posted June 8, 2018 Posted June 8, 2018 Any ETA for the new (mpv based?) player? No ETA yet. We are working on it though. 1
Everbrave 62 Posted June 8, 2018 Posted June 8, 2018 No ETA yet. We are working on it though. If you have a TestFlight, I would be glad to help testing. Thanks
corey 317 Posted June 8, 2018 Posted June 8, 2018 @@ebr can reach out to you. We can always use more beta testers but we ask that you run the app through it’s paces for each beta release.
Everbrave 62 Posted June 8, 2018 Posted June 8, 2018 @@ebr can reach out to you. We can always use more beta testers but we ask that you run the app through it’s paces for each beta release. As a Univ. Developer and Beta tester for other three major tvOS/iOS player apps, I’m used to that
ebr 16332 Posted June 8, 2018 Posted June 8, 2018 If you wish to join the Emby testflight for Apple TV, PM me your Apple ID. However, we do not yet have a testflight version with the new player (hopefully soon though).
ginsengbomb 5 Posted August 23, 2018 Posted August 23, 2018 I just started trying to use Emby again (I like that Emby sync to Google Drive works whereas Plex's...doesn't at all work) and am seeing that 100% of my 4K/HDR videos transcode on AppleTV. They seem to all be HEVC. Am I right in determining from this thread that this is expected and that the new player should resolve it? (Because of this issue right now I'm basically using Emby to just do automated cloud sync to Google Drive and doing all my local/LAN viewing on Plex since it handles the same files fine w/ HDR)
Luke 42238 Posted August 23, 2018 Posted August 23, 2018 Hi, can we please look at an example? Thanks
ginsengbomb 5 Posted August 24, 2018 Posted August 24, 2018 Sure, here are a couple. They're both showing this in the stream mapping section: " Stream #0:0 -> #0:0 (hevc (native) -> h264 (h264_nvenc)) ". Plex plays both of these fine with HDR on my AppleTV 4k, Emby transcodes. I haven't tested Emby recently on another box but I'm pretty sure when I played these files on my old Roku, Emby direct streamed it (i.e. converted the container w/o touching the actual video) rather than transcoding. log1.txt log2.txt
Luke 42238 Posted August 24, 2018 Posted August 24, 2018 Ok thanks. In the beta version of the app we're testing a new video player and I think these will play better now. Thanks. 1
ginsengbomb 5 Posted August 24, 2018 Posted August 24, 2018 Awesome. Thank you Luke. I'm looking forward to it, and appreciate as always the fact that you guys actually respond to community questions and concerns!
Sizzlebox 2 Posted October 17, 2018 Posted October 17, 2018 Has the tvOS update arrived? I don’t see it yet...
Luke 42238 Posted October 22, 2025 Posted October 22, 2025 Hi, HDR playback has been improved in Emby for Apple TV 2.0.1. Thanks !
