Lomnar 0 Posted June 6, 2018 Posted June 6, 2018 my problem is a littlebit strange. i used a long time emby from asustor(mono based) and updated it manually. works fine for me a long time. Now i have no acces to my library, i always get the message, no compatible stream found. i tried everything what i found here on the forums, no one works. So i decided to make a clean cut. I uninstalled emby mono from asustor, and downloaded the apk file for Emby Server found here: https://github.com/MediaBrowser/Emby.Releases/releases/download/3.4.1.0/emby-server-asustor_3.4.1.0_x86-64.apk after manual install finished, i activate the app on asustor app central, wait a littlebit and tried to launch it. Website opened with this error text: Network Error (tcp_error) A communication error occurred: "Connection refused" The Web Server may be down, too busy, or experiencing other problems preventing it from responding to requests. You may wish to try again at a later time. i changed nothing, the port is the standard port 8096, the url ist http://serverip:8096. so could anybody help me to find out what's going wrong here?
Lomnar 0 Posted June 6, 2018 Author Posted June 6, 2018 I found out, in volume1 / home, the folder emby was missing, I created it anew and made via ssh the user emby to the owner of the folder. use chown for that
