villano666 0 Posted June 5, 2018 Posted June 5, 2018 (edited) Hi! I´ve installed emby and I´ve been already using trakt to save my watched movies/series status. I´ve installed the plugin in and run it apparently with no errors but all my previous watched movies and tv shows are not marked as watched in emby. This is my log 2018-06-05 16:08:35.843 Info TaskManager: Executing Import playstates from Trakt.tv 2018-06-05 16:08:35.845 Info HttpClient: GET https://api.trakt.tv/sync/watched/movies 2018-06-05 16:08:35.847 Info HttpServer: HTTP Response 204 to ::1. Time: 4ms. http://localhost:8096/emby/ScheduledTasks/Running/5e47e7d3542ace9c367691a65cb31e86 2018-06-05 16:08:35.859 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?isHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-05 16:08:35.882 Info HttpServer: HTTP Response 200 to ::1. Time: 23ms. http://localhost:8096/emby/ScheduledTasks?isHidden=false 2018-06-05 16:08:36.575 Info HttpClient: GET https://api.trakt.tv/sync/watched/shows 2018-06-05 16:08:36.955 Info Trakt: Trakt.tv watched Movies count = 417 2018-06-05 16:08:36.955 Info Trakt: Trakt.tv watched Shows count = 37 2018-06-05 16:08:37.597 Info TaskManager: Import playstates from Trakt.tv Completed after 0 minute(s) and 1 seconds 2018-06-05 16:08:37.598 Info ServerManager: Sending web socket message ScheduledTaskEnded Any ideas what´s wrong? Thanks Edited June 5, 2018 by villano666
Luke 42253 Posted June 5, 2018 Posted June 5, 2018 Hi there, can you please discuss some examples of content that didn't import data from trakt? Thanks.
Luke 42253 Posted June 5, 2018 Posted June 5, 2018 Hi there. Can you please discuss some specific examples? thanks.
villano666 0 Posted June 5, 2018 Author Posted June 5, 2018 Examples as which movie or series titles? Because as I said none was updated
villano666 0 Posted June 5, 2018 Author Posted June 5, 2018 Avatar foe movies, arrow for tv shows Enviado desde mi ONEPLUS A3000 mediante Tapatalk
Luke 42253 Posted June 5, 2018 Posted June 5, 2018 Have you checked in Emby to see that the metadata for Avatar has an imdb / moviedb id?
J2ghz 11 Posted June 6, 2018 Posted June 6, 2018 If Luke's message above doesn't help, Enable debug logging emby, enable debug logging in trakt plugin settings, reproduce the issue and send us your logs.
villano666 0 Posted June 6, 2018 Author Posted June 6, 2018 Have you checked in Emby to see that the metadata for Avatar has an imdb / moviedb id? Yes it does. I´ve checked a lot of items and they all have it. Check this screenshot: https://imgur.com/s9geDhK
villano666 0 Posted June 6, 2018 Author Posted June 6, 2018 (edited) Here´s a log after running scheduled task: 'Import playstates from Trakt.tv' https://pastebin.com/hibGi4cf Edited June 6, 2018 by villano666
villano666 0 Posted June 6, 2018 Author Posted June 6, 2018 I´m seeing these errors 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt2245988","tvdb":265720,"tvrage":34473}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0826760","tvdb":79689}} I don´t understand why as those ids exist.
villano666 0 Posted June 6, 2018 Author Posted June 6, 2018 Tried re-installing and also with a previous version. Nothing works.
villano666 0 Posted June 6, 2018 Author Posted June 6, 2018 (edited) Where does it exist? How did you verify that? I pick an id go to imdb and check which movie/tv show is. Then go to that tv show or movie > edit metadata and check if imdb id matches. Emby sends trakt information correctly when I mark something as watched but it is not marking as watched what comes from trakt. I´m planning on switching from Plex if this works, even pay for emby premiere but I need this to work Edited June 6, 2018 by villano666
villano666 0 Posted June 6, 2018 Author Posted June 6, 2018 We'll see what @@J2ghz thinks. Thanks. Great, thanks
J2ghz 11 Posted June 7, 2018 Posted June 7, 2018 (edited) The issue lies here: 2018-06-06 09:16:46.015 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.015 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.015 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":327417}} 2018-06-06 09:16:46.015 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":78224}} 2018-06-06 09:16:46.015 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":79689}} 2018-06-06 09:16:46.017 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0182576","tvdb":75978,"tvrage":3506}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.018 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098825","tvdb":79861,"tvrage":17544}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0161952","tvdb":72775}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt2930604","tvdb":283468,"tvrage":35995}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt2245988","tvdb":265720,"tvrage":34473}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt2245988","tvdb":265720,"tvrage":34473}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt2245988","tvdb":265720,"tvrage":34473}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt2245988","tvdb":265720,"tvrage":34473}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt2245988","tvdb":265720,"tvrage":34473}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0826760","tvdb":79689}} 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0826760","tvdb":79689}} I don't see any debug messages in the log though, I need to see those to see what is being sent to trakt. Are you sure you have enabled it in both places? See: https://i.imgur.com/cY5xdNx.png and https://i.imgur.com/NnQSBda.png Thanks Edited June 7, 2018 by J2ghz
villano666 0 Posted June 7, 2018 Author Posted June 7, 2018 (edited) Both debug options are on as you´ve shown. What I don´t understand is for example: 2018-06-06 09:16:46.019 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt2245988","tvdb":265720,"tvrage":34473}} That code tt0826760 is The Bible in imdb (a tv show). When I check for that show metadata in emby it shows that exact code. See images: Debug: https://imgur.com/5w6LTcG Debug: https://imgur.com/MDPtqHi The Bible on imdb doing a search by code: https://imgur.com/ZDN7pGQ Metadata from The Bible on emby: https://imgur.com/7oJjglm Besides that the are few errores than content in my server. I have more than 2TB of content in my media server. There are a lot of shows/movies not even on logs that are not being marked as watched. For what I see in the logs it downloads correctly the amount of movies/tv shows seen but it looks like it doesn´t perform any action: 2018-06-05 16:08:36.575 Info HttpClient: GET https://api.trakt.tv/sync/watched/shows2018-06-05 16:08:36.955 Info Trakt: Trakt.tv watched Movies count = 4172018-06-05 16:08:36.955 Info Trakt: Trakt.tv watched Shows count = 37 I hope this helps, I have a lot of content marked in trakt and I really wanna switch to emby. Another thing I´ve tried. I went to trakt and unchecked a watched show, when I sincronize it marked as watched on emby. It seems to have problems with items that where marked a long time ago. Edited June 7, 2018 by villano666
villano666 0 Posted June 7, 2018 Author Posted June 7, 2018 (edited) It´s working! I´ve deleted libraries on emby and then delete library.db, create a couple again and it worked with movies and tv shows! Many thanks for your efforts I believe it is wise to install the plug in before creating libraries if it´s a fresh install Edited June 7, 2018 by villano666
