Guest asrequested Posted June 5, 2018 Posted June 5, 2018 I wonder if the brackets are causing an issue. In that log, the sub isn't present at all. Try removing the [anti-raws] and [bDRemux], from both files. Run a library scan, and try again.
blei 7 Posted June 5, 2018 Author Posted June 5, 2018 (edited) They're kinda big. The video in itself is over 300 MB. You're going to have to remove the .txt extension.\ (removed files) Edited June 6, 2018 by blei
blei 7 Posted June 5, 2018 Author Posted June 5, 2018 On an interesting note, I was able to play (on Emby Theater) a video with an external .srt subtitle file just fine.
Guest asrequested Posted June 6, 2018 Posted June 6, 2018 Ok, so it worked for me. Download the latest mpv build here, and unzip it to the theater mpv folder. Then try again
blei 7 Posted June 6, 2018 Author Posted June 6, 2018 I've placed the updater.bat and updater.ps1 into "C:\Users\blei\AppData\Roaming\Emby-Theater\system\x64\mpv", ran the updater.bat, and same issue. No subtitles. To confirm a newer mpv.exe was downlaoded, I renamed the mpv.exe to mpv2.exe, re-ran updater.bat, and saw that a new mpv.exe was created. I also just tried to run Emby Theater as an Admin, and that didn't do anything either. Attaching logs with newer mpv. [ 6.971][e][cplayer] Can not open external file http://192.168.1.128:8096/emby/Videos/8e88e3c51121839b8122250d771ee883/8e88e3c51121839b8122250d771ee883/Subtitles/2/0/Stream.ass?api_key=418175e267554156a46facf1807b6235. I mean, I tried opening that on Chrome incognito and it was fine. mpv.log
Guest asrequested Posted June 6, 2018 Posted June 6, 2018 Put the files on the same machine as Theater, double click the mpv.exe, and drop the video on it. Does it give you the subs?
Guest asrequested Posted June 6, 2018 Posted June 6, 2018 If that works, then repeat with the files from the original location.
blei 7 Posted June 6, 2018 Author Posted June 6, 2018 (edited) Here's something I just tried out; I ran mpv directly with params + the "-v" option and saw this: [cplayer] Opening done: http://192.168.1.128:8096/emby/Videos/8e88e3c51121839b8122250d771ee883/stream.mkv?Static=true&mediaSourceId=8e88e3c51121839b8122250d771ee883&deviceId=Fractal&api_key=418175e267554156a46facf1807b6235&Tag=d00d29a7256ddd9002abfe5a0d3a2ca8 [ffmpeg] Opening http://192.168.1.128:8096/emby/Videos/8e88e3c51121839b8122250d771ee883/8e88e3c51121839b8122250d771ee883/Subtitles/2/0/Stream.ass?api_key=418175e267554156a46facf1807b6235 [ffmpeg] Could not set AVOption tls_verify='0' [ffmpeg] Mime-type: 'text/x-ssa' [cache] no backbuffer needed [cache] Cache size set to 485 KiB (32 KiB backbuffer) [demux] Trying demuxers for level=normal. [cache] EOF reached. [lavf] No format found, try lowering probescore or forcing the format. [demux] Trying demuxers for level=unsafe. [lavf] No format found, try lowering probescore or forcing the format. [cache] Terminating cache... [cache] Cache exiting... [cplayer] Can not open external file http://192.168.1.128:8096/emby/Videos/8e88e3c51121839b8122250d771ee883/8e88e3c51121839b8122250d771ee883/Subtitles/2/0/Stream.ass?api_key=418175e267554156a46facf1807b6235. I manually downloaded those two files onto my PC, dragged and dropped it to mpv screen, and yes it did show the subtitles. Initially I thought this was new information, but seems like it actually isn't (it was already in logs). Edited June 6, 2018 by blei
blei 7 Posted June 6, 2018 Author Posted June 6, 2018 "If that works, then repeat with the files from the original location." - from the server? I only use my server for server stuff, not desktop stuff. No UI was setup for it.
blei 7 Posted June 6, 2018 Author Posted June 6, 2018 So they played over the network? I ran: mpv "http://192.168.1.128:8096/emby/Videos/8e88e3c51121839b8122250d771ee883/stream.mkv?Static=true&mediaSourceId=8e88e3c51121839b8122250d771ee883&deviceId=Fractal&api_key=418175e267554156a46facf1807b6235&Tag=d00d29a7256ddd9002abfe5a0d3a2ca8" -v --sub-files="http://192.168.1.128:8096/emby/Videos/8e88e3c51121839b8122250d771ee883/8e88e3c51121839b8122250d771ee883/Subtitles/2/0/Stream.ass?api_key=418175e267554156a46facf1807b6235" Yes the video could play, but the subtitles was still not loaded (as can tell by logs I pasted above).
Guest asrequested Posted June 6, 2018 Posted June 6, 2018 What I'm trying to rule out are network issues. If you copy the files to a local directory on the Theater machine, and drop them on mpv, what happens?
blei 7 Posted June 6, 2018 Author Posted June 6, 2018 Okay so: I downloaded the .ass from that URL, and tried: Launch MPV -> Opened Video -> Dragged downloaded subtitles to MPV -> no subtitles Renamed downloaded subtitles to be same name as video -> Open Video -> no subtitles Note: The file sizes between the original .ass file and the downloaded .ass file were different. Here's more logs mpv.log
blei 7 Posted June 6, 2018 Author Posted June 6, 2018 Attaching the subtitles file I downloaded. Stream.ass.txt
Guest asrequested Posted June 6, 2018 Posted June 6, 2018 The subs aren't in that log, anywhere. Why can't you copy your files over?
blei 7 Posted June 6, 2018 Author Posted June 6, 2018 Attached file explicitly tried to drag and drop Stream.ass (no subtitles still) mpv.log
Guest asrequested Posted June 6, 2018 Posted June 6, 2018 I honestly don't understand what you're trying.
blei 7 Posted June 6, 2018 Author Posted June 6, 2018 Well for the latest log file I provided, I opened MPV, dragged the video to MPV window, then dragged the Stream.ass to the MPV window. As you can tell, it still just gives the ambiguous message of: Can not open external file C:\Users\benle\Desktop\Stream.ass.
Guest asrequested Posted June 6, 2018 Posted June 6, 2018 So you're dragging two files on to mpv, separately?
blei 7 Posted June 6, 2018 Author Posted June 6, 2018 (edited) Yes. For the log attached to this post, I have tried together (Open mpv -> dragged both video + Stream.ass to MPV -> no subs) as I feel like that's your next suggestion. To further this point... the original .ass file is DIFFERENT from the one downloaded from Emby: mpv.log Edited June 6, 2018 by blei
Guest asrequested Posted June 6, 2018 Posted June 6, 2018 That won't work. Both the video and the sub need to be named, identically. Then you just drop the video on to mpv. The files need to be in the same location.
blei 7 Posted June 6, 2018 Author Posted June 6, 2018 Just to reiterate... Emby (for Docker) has done something to the original .ass: --------------------------------------- Ok so here's what I did: 1. Renamed Stream.ass to be the same name as the video file. 2. Opened mpv 3. Dragged the video and the subtitles to mpv window. Additionally when I play the video + drag the ORIGINAL subtitles to another player (MPC), the subtitles show. But if I play the video + drag the EMBY subtitles to another player (MPC), the subtitles don't show. It honestly does not look like an mpv problem. It's possible it's a Docker Emby server problem as it served a different file than the original. mpv.log
