FingerlessGlovs 8 Posted June 4, 2018 Posted June 4, 2018 (edited) Hi all, I upgraded to 3.4.1 and now realtime folder monitoring won't stay enabled. Also getting this error when manual scan. Apart from the library not updating no issues. See screenshots below. http://imgur.com/QBd9mqu http://imgur.com/iZt1Egm I also noticed /var/lib/emby-server is now /var/lib/emby Ubuntu 16.04 Edited June 4, 2018 by MrJonny
Luke 42246 Posted June 4, 2018 Posted June 4, 2018 It looks like you may have switched from our legacy install package to our new install package. This unfortunately is not currently supported. You might be able to correct this by symlinking the old data path to the new one.
FingerlessGlovs 8 Posted June 4, 2018 Author Posted June 4, 2018 (edited) No Worries I'll roll back to 3.3, good job I run ZFS for my containers. When will I know I can go to 3.4 without problems? Edited June 4, 2018 by MrJonny
Luke 42246 Posted June 4, 2018 Posted June 4, 2018 Since you're on the legacy install package, you can do a manual update by reading the instructions in posts #3 and #4 here: https://emby.media/community/index.php?/topic/58613-question-about-my-32-bit-upgrade/?p=574032 Thanks.
FingerlessGlovs 8 Posted June 4, 2018 Author Posted June 4, 2018 Thanks for your Help Luke. Is that my only way? Or should I wait for a official upgrade path?
Luke 42246 Posted June 4, 2018 Posted June 4, 2018 That could take some time due to differences between the two. Currently the only way to move to the new install package is a completely fresh installation.
FingerlessGlovs 8 Posted June 4, 2018 Author Posted June 4, 2018 (edited) When will we know we can move to the new Install package? EDIT: I've done that method of updating it for now. Edited June 4, 2018 by MrJonny
Luke 42246 Posted June 5, 2018 Posted June 5, 2018 Right now there are some compatibility problems with the older installations that is making this difficult, so it could be a little while. We may also just to have users on the legacy package update manually. It really just depends on a number of factors. Thanks.
FingerlessGlovs 8 Posted June 5, 2018 Author Posted June 5, 2018 Hi, I'll update it manually for now. Hopefully you can workout a upgrade mechanism in the near future. Thanks for the Support as always Luke.
FingerlessGlovs 8 Posted February 21, 2019 Author Posted February 21, 2019 Thanks for the feedback. Hi Luke, Any news on how to update to the new folder path? Currently have the following to folders symlinked, which allows the old and new paths to work. 17 drwxr-xr-x 18 emby emby 19 Oct 30 20:38 emby 1 lrwxrwxrwx 1 root root 13 Oct 30 20:42 emby-server -> /var/lib/emby
Luke 42246 Posted February 21, 2019 Posted February 21, 2019 What do you mean update? Are you having a problem?
FingerlessGlovs 8 Posted February 21, 2019 Author Posted February 21, 2019 Since Emby is now on version 4, was there any update mechanisms to change old library paths from /var/lib/emby-server to /var/lib/emby. Currently I have them symlinked to fix issues with database referencing old path.
Luke 42246 Posted February 22, 2019 Posted February 22, 2019 No, I would just continue with the symlinks for now.
