TastyPomme 7 Posted June 4, 2018 Posted June 4, 2018 Afternoon, Have a few issues with this plugin It only seems to be working if I set to 1 the "Create BoxSets only if I have at least this many of its movies:" option But then I have all sets available even if I only have 1 movie I tried several times to delete the collections folder (can't find the XML file though) but I always have the same issue (nothing happens unless I change this figure to 1)
ebr 16346 Posted June 4, 2018 Posted June 4, 2018 Hi. Can you please be sure your server is set to debug logging (may need to restart after changing that setting) then change the setting in the plug-in back to what you want it to be, run an auto box sets refresh and then post the server log. Thanks. How to Report a Problem
TastyPomme 7 Posted June 4, 2018 Author Posted June 4, 2018 Here is the log file I deleted the collection folder at 15:40 one set was automatically created Have launched a refresh box sets at 15:41 with a minimum of 3 movies And still only that initial set of movies is available If I would run it on 1 movie required, I would get about 150 sets
ebr 16346 Posted June 4, 2018 Posted June 4, 2018 Hi. It looks like you forgot to turn on Debug logging in the server...
Luke 42255 Posted June 4, 2018 Posted June 4, 2018 Did you also check that all of your movies have a TmdbCollectionId value? You can do this in the metadata editor. This is what the Autoboxsets plugin uses to identify what to create.
TastyPomme 7 Posted June 4, 2018 Author Posted June 4, 2018 @@ebr I really thought it was done. Anyway, while I was setting up the debug logging and refresh box sets (3+ movies) And it worked Not sure what was the issue, could there be some latency because of a scan in progress?
ebr 16346 Posted June 4, 2018 Posted June 4, 2018 Not sure what was the issue, could there be some latency because of a scan in progress? Yes, because perhaps not all of your movies had the proper tmdb IDs yet...
stefan1983 4 Posted June 5, 2018 Posted June 5, 2018 Hello everyone, I have another issue with this plugin. I installed the plugin and activated the "Group movies into collections" option in the library settings as well. And all worked fine so far. Then I changed the plugin setting for minimum amount of movies to be grouped to 1 which worked as well. But now I have the problem that after changing it back to "2" all single movie group sets are still shown. No matter what I configure or change. I already deleted the plugin and reinstalled it, deselected the library group setting again, rebooted the server several times... I just can't get back to only have group sets with at least 2 movies shown again. Anyone there to help out? I guess this can be very easily reproduced Thanks Stefan
Happy2Play 9814 Posted June 5, 2018 Posted June 5, 2018 (edited) Have you deleted the collections created in "\Emby-Server\programdata\data\collections"? Location may vary slightly depending on your install. Edited June 5, 2018 by Happy2Play
Happy2Play 9814 Posted June 5, 2018 Posted June 5, 2018 I did it from the web gui - isn't that enough? No because that is where the collections metadata is stored. I believe that library will just regenerate itself over time. The grouping is done from the database and all the information is still there when you remove the plugin or remove the library. So you need to remove the existing metadata in that collection folder.
Happy2Play 9814 Posted June 5, 2018 Posted June 5, 2018 @@Luke Should there be a "Remove" option for the Collection library as it is a required location for collections?
stefan1983 4 Posted June 5, 2018 Posted June 5, 2018 (edited) Seems to have worked, after deleting the files emby didn't look for group sets. But after scanning the movie library (instead of the group library) and with a reboot it now worked well. Thank you! Edited June 5, 2018 by stefan1983
Luke 42255 Posted June 5, 2018 Posted June 5, 2018 @@Luke Should there be a "Remove" option for the Collection library as it is a required location for collections? Well I'm not sure. I suppose it is a quick way to remove all boxsets, but it will come back the next time you create a collection.
TastyPomme 7 Posted June 5, 2018 Author Posted June 5, 2018 Yes, because perhaps not all of your movies had the proper tmdb IDs yet... Sorry no, they all had a collection ID And it was working when set to 1 movie only
Luke 42255 Posted June 5, 2018 Posted June 5, 2018 Did you check that the movies of each boxset had the same collection id? maybe they had different ones and that's why you didn't get any boxsets created when you set the minimum to 2.
zetatec 1 Posted October 24, 2018 Posted October 24, 2018 Collections do not carry me. My Library is all in STRM with the information in NFO. The collection tag Ember Media Manager generated on the NFO was <tmdbcolid>
Luke 42255 Posted October 24, 2018 Posted October 24, 2018 Collections do not carry me. My Library is all in STRM with the information in NFO. The collection tag Ember Media Manager generated on the NFO was Hi there, can you please describe your issue in more detail? Thanks !
Happy2Play 9814 Posted October 24, 2018 Posted October 24, 2018 Collections do not carry me. My Library is all in STRM with the information in NFO. The collection tag Ember Media Manager generated on the NFO was <tmdbcolid> My guess would be the plugin doesn't read that tag. I know my xmls contain <CollectionNumber> and <TMDbCollectionId>. Emby creates <CollectionNumber> in nfo for collectionid.
Luke 42255 Posted October 24, 2018 Posted October 24, 2018 We support two different places: <TmdbCollection> Or <set tmdbcolid="xxx">
zetatec 1 Posted October 24, 2018 Posted October 24, 2018 I have about 500 movies, I use Ember Media Manager to search the information and place them inside the NFO. The movie folder looks like this: and NFO: https://pastebin.com/raw/kC7keDUY Everything works fine, just the collection that does not. I'll change the tag generated by Ember Media Managar (<tmdbcolid> 131295 </ tmdbcolid> by example), by <set tmdbcolid = "xxx"> or <TmdbCollection>
zetatec 1 Posted October 24, 2018 Posted October 24, 2018 When editing the metadata, I saw Emby read the <tmdbcolid> tag. But the collections do not appear in the tab "collections".
Happy2Play 9814 Posted October 24, 2018 Posted October 24, 2018 If edit info is seeing the collectionid then you should be good. What happens if you open the plugin and Refresh Boxsets?
