thekingswolf 49 Posted June 3, 2018 Posted June 3, 2018 I have this setting checked, but it is not yet displaying missing episodes within a season. Would like to be able to filter all shows and only show episodes that are missing, or run some kind of task that gives a report of all shows that contain missing episodes, and what episodes are missing.
thekingswolf 49 Posted June 3, 2018 Author Posted June 3, 2018 awesome, ty i didn't have reports plug in installed
thekingswolf 49 Posted June 3, 2018 Author Posted June 3, 2018 hmm ok change request to add on to the reports a filter to filter out episodes from the report for episodes that have a release date that is after the current date (episodes that haven't aired yet are just clogging up my report)
levander 97 Posted June 7, 2018 Posted June 7, 2018 (edited) @@ebr Hi, Why my filter tab on the right looks like this and is hardly readable? (I'm using "Apple TV theme") Also, under filters there are limited Tag values - I can't see all of them... Edited June 7, 2018 by levander
Luke 42246 Posted June 7, 2018 Posted June 7, 2018 The reports plugin must have hard-coded a black background into the sidebar, which obviously doesn't look good on some of the themes. There are some updates in the pipeline for the reports plugin, however, I would just like to mention that the reports plugin is a community addition, and contributions are welcome. The source code can be found here: https://github.com/MediaBrowser/EmbyReports Thanks !
levander 97 Posted June 7, 2018 Posted June 7, 2018 The reports plugin must have hard-coded a black background into the sidebar, which obviously doesn't look good on some of the themes. There are some updates in the pipeline for the reports plugin, however, I would just like to mention that the reports plugin is a community addition, and contributions are welcome. The source code can be found here: https://github.com/MediaBrowser/EmbyReports Thanks ! Thanks.... I'm not much of a coder but I'll have a look. The issue of showing limited tags is also possible to fix in that code?
Luke 42246 Posted June 7, 2018 Posted June 7, 2018 Thanks.... I'm not much of a coder but I'll have a look. The issue of showing limited tags is also possible to fix in that code? Well yes i think you can, but it might overwhelm the UI if you put hundreds of tags there. I think it may just need a new design at this point.
levander 97 Posted June 7, 2018 Posted June 7, 2018 Well yes i think you can, but it might overwhelm the UI if you put hundreds of tags there. I think it may just need a new design at this point. Good. I will wait for tags support then. Thanks for reply.
thekingswolf 49 Posted July 14, 2018 Author Posted July 14, 2018 FYI to anyone interested in this same thing, the Statistics plug in is even better for this under the View user-based show progress section at the bottom. Easy to organize list of all shows and % of episodes collected/available
