Luke 42241 Posted June 9, 2018 Posted June 9, 2018 Did you click save after entering the configuration for each user? You need to click save before changing the user in the dropdown.
in10se 3 Posted June 9, 2018 Author Posted June 9, 2018 (edited) deleted Edited August 20, 2018 by in10se
in10se 3 Posted June 12, 2018 Author Posted June 12, 2018 (edited) deleted Edited August 20, 2018 by in10se
J2ghz 11 Posted June 12, 2018 Posted June 12, 2018 I'm currently looking through the code of the plugin to see if there could be any problem there. I think I will need to improve the logging of the plugin (it does not log which users is being processed), which I where I think the problem might be, because the log only includes failed items (those with wrong info), but the correct ones are missing, without any error.
J2ghz 11 Posted June 12, 2018 Posted June 12, 2018 If you are willing to test build that would be a huge help. I'll just make one that dumps everything into logs and see where exactly the problem is. I'll let you know when it's ready.
otarie 2 Posted June 24, 2018 Posted June 24, 2018 just works for me once, after i put in the pin - trakt also says "Each PIN is one time use." - So how do i fix that?
