mike689 0 Posted June 2, 2018 Posted June 2, 2018 Hey all, New to the forums, but no to Emby. Glad this forum is here! So I have a headless Ubuntu 17.10 (artful) used for automation of grabbing media and as my main media center on my nVidia Shield. I've been using Plex but I'm tired of it. Anyway, every single time I try to install Emby, probably 30 seconds or less after I click "finish" on the final step of the pre-setup on the web interface, it loses connection. I've tried 3.4.1.0, 3.4.1.10, 3.4.0.0, and 3.3.1.0 (as well as a couple beta's but they did the same). Every single install, after install Emby web interface works fine for setup, once I finish the initial quick setup it has about ~30 seconds before it drops it's connection. I've already got UPnP enabled on my router, and I even set the port in there manually myself. Any ideas? Maybe an older stabler version. Maybe I'm doing something wrong? I've spent hours in the depths of google trying to sort this buy have come up pretty empty unfortunately. I'll get a log for you when I get back home in a couple hours. Thanks!
Luke 42246 Posted June 2, 2018 Posted June 2, 2018 Hi, yes please attach the information requested in how to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
mike689 0 Posted June 3, 2018 Author Posted June 3, 2018 Sorry for the delay, here's my embyserver.txt log pt 1 2018-06-02 18:47:54.860 Info Main: Application path: /opt/emby-server/system/EmbyServer.dll 2018-06-02 18:47:54.884 Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system 2018-06-02 18:47:55.121 Info App: Application version: 3.4.1.0 2018-06-02 18:47:55.124 Info App: Loading assemblies 2018-06-02 18:47:55.156 Info App: Loading IMVDb, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/IMVDb.dll 2018-06-02 18:47:55.156 Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Server.CinemaMode.dll 2018-06-02 18:47:55.156 Info App: Loading OpenSubtitles, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/OpenSubtitles.dll 2018-06-02 18:47:55.156 Info App: Loading MediaBrowser.Api, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading MediaBrowser.WebDashboard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading MediaBrowser.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading MediaBrowser.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading MediaBrowser.Controller, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading MediaBrowser.Providers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading Emby.Photos, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading Emby.Server.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading MediaBrowser.LocalMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading MediaBrowser.XbmcMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.156 Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 18:47:55.340 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-br.txt 2018-06-02 18:47:55.342 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-ca.txt 2018-06-02 18:47:55.342 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-co.txt 2018-06-02 18:47:55.342 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-dk.txt 2018-06-02 18:47:55.342 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-es.txt 2018-06-02 18:47:55.342 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-fr.txt 2018-06-02 18:47:55.342 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-gb.txt 2018-06-02 18:47:55.342 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-ie.txt 2018-06-02 18:47:55.342 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-jp.txt 2018-06-02 18:47:55.342 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-kz.txt 2018-06-02 18:47:55.342 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-mx.txt 2018-06-02 18:47:55.343 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-nl.txt 2018-06-02 18:47:55.343 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-nz.txt 2018-06-02 18:47:55.343 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-ro.txt 2018-06-02 18:47:55.343 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-uk.txt 2018-06-02 18:47:55.343 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-us.txt 2018-06-02 18:47:55.358 Info SqliteUserRepository: Sqlite version: 3.23.1 2018-06-02 18:47:55.360 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2018-06-02 18:47:55.393 Info SqliteUserRepository: Default journal_mode for /var/lib/emby/data/users.db is delete 2018-06-02 18:47:55.440 Info SqliteUserRepository: PRAGMA synchronous=1 2018-06-02 18:47:55.485 Info AuthenticationRepository: Default journal_mode for /var/lib/emby/data/authentication.db is delete 2018-06-02 18:47:55.514 Info AuthenticationRepository: PRAGMA synchronous=1 2018-06-02 18:47:55.632 Info DeviceManager: Default journal_mode for /var/lib/emby/data/devices.db is delete 2018-06-02 18:47:55.646 Info DeviceManager: PRAGMA synchronous=1 2018-06-02 18:47:55.701 Info ActivityRepository: Default journal_mode for /var/lib/emby/data/activitylog.db is delete 2018-06-02 18:47:55.713 Info ActivityRepository: PRAGMA synchronous=1 2018-06-02 18:47:55.731 Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/lib/emby/data/displaypreferences.db is delete 2018-06-02 18:47:55.749 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 2018-06-02 18:47:55.764 Info SqliteItemRepository: Default journal_mode for /var/lib/emby/data/library.db is delete 2018-06-02 18:47:55.791 Info SqliteItemRepository: PRAGMA synchronous=1 2018-06-02 18:47:55.833 Info SqliteNotificationsRepository: Default journal_mode for /var/lib/emby/data/notifications.db is delete 2018-06-02 18:47:55.866 Info SqliteNotificationsRepository: PRAGMA synchronous=1 2018-06-02 18:47:56.066 Info App: Requesting administrative access to authorize http server 2018-06-02 18:47:56.068 Info ServerConfigurationManager: Saving system configuration 2018-06-02 18:47:56.257 Info HttpServer: Calling ServiceStack AppHost.Init 2018-06-02 18:47:56.965 Info ServerManager: Loading Http Server 2018-06-02 18:47:56.971 Info HttpServer: Adding HttpListener prefix http://+:8096/ 2018-06-02 18:47:56.972 Info HttpServer: Adding HttpListener prefix https://+:8920/ 2018-06-02 18:47:57.243 Info Skia: SkiaSharp version: 1.58.0.0 2018-06-02 18:47:57.279 Info TaskManager: Daily trigger for Chapter image extraction set to fire at 6/3/18 2:00:00 AM, which is 432.045337781667 minutes from now. 2018-06-02 18:47:57.287 Info TaskManager: Daily trigger for Rotate log file set to fire at 6/3/18 12:00:00 AM, which is 312.045201208333 minutes from now. 2018-06-02 18:47:57.297 Info MediaEncoder: FFMpeg: /opt/emby-server/bin/ffmpeg 2018-06-02 18:47:57.298 Info MediaEncoder: FFProbe: /opt/emby-server/bin/ffprobe 2018-06-02 18:47:57.298 Info MediaEncoder: Validating media encoder at /opt/emby-server/bin/ffmpeg 2018-06-02 18:47:57.302 Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -decoders 2018-06-02 18:47:57.346 Info MediaEncoder: Decoder available: mpeg2video 2018-06-02 18:47:57.354 Info MediaEncoder: Decoder available: h264_cuvid 2018-06-02 18:47:57.354 Info MediaEncoder: Decoder available: hevc_cuvid 2018-06-02 18:47:57.355 Info MediaEncoder: Decoder available: mpeg2_cuvid 2018-06-02 18:47:57.355 Info MediaEncoder: Decoder available: mpeg4_cuvid 2018-06-02 18:47:57.356 Info MediaEncoder: Decoder available: vc1_cuvid 2018-06-02 18:47:57.357 Info MediaEncoder: Decoder available: vp8_cuvid 2018-06-02 18:47:57.358 Info MediaEncoder: Decoder available: vp9_cuvid 2018-06-02 18:47:57.368 Info MediaEncoder: Decoder available: ac3 2018-06-02 18:47:57.369 Info MediaEncoder: Decoder available: aac 2018-06-02 18:47:57.370 Info MediaEncoder: Decoder available: mp3 2018-06-02 18:47:57.370 Info MediaEncoder: Decoder available: h264 2018-06-02 18:47:57.371 Info MediaEncoder: Decoder available: hevc 2018-06-02 18:47:57.382 Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -encoders 2018-06-02 18:47:57.423 Info MediaEncoder: Encoder available: libx264 2018-06-02 18:47:57.424 Info MediaEncoder: Encoder available: mpeg4 2018-06-02 18:47:57.424 Info MediaEncoder: Encoder available: msmpeg4 2018-06-02 18:47:57.426 Info MediaEncoder: Encoder available: aac 2018-06-02 18:47:57.427 Info MediaEncoder: Encoder available: libmp3lame 2018-06-02 18:47:57.427 Info MediaEncoder: Encoder available: libopus 2018-06-02 18:47:57.428 Info MediaEncoder: Encoder available: libvorbis 2018-06-02 18:47:57.429 Info MediaEncoder: Encoder available: srt 2018-06-02 18:47:57.429 Info MediaEncoder: Encoder available: h264_nvenc 2018-06-02 18:47:57.429 Info MediaEncoder: Encoder available: hevc_nvenc 2018-06-02 18:47:57.434 Info MediaEncoder: Encoder available: h264_vaapi 2018-06-02 18:47:57.434 Info MediaEncoder: Encoder available: hevc_vaapi 2018-06-02 18:47:57.435 Info MediaEncoder: Encoder available: h264_v4l2m2m 2018-06-02 18:47:57.435 Info MediaEncoder: Encoder available: libwebp 2018-06-02 18:47:57.435 Info MediaEncoder: Encoder available: ac3 2018-06-02 18:47:57.436 Info MediaEncoder: Encoder validation complete 2018-06-02 18:47:57.439 Info App: ServerId: 76182be185fb47a0858a8b33694b7384 2018-06-02 18:47:57.486 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint 2018-06-02 18:47:57.487 Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.0009838 seconds 2018-06-02 18:47:57.487 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2018-06-02 18:47:57.723 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.2360741 seconds 2018-06-02 18:47:57.723 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2018-06-02 18:47:57.725 Info App: Loading data from /var/lib/emby/data/connect.txt 2018-06-02 18:47:57.727 Info App: Loading data from /var/lib/emby/data/wan.dat 2018-06-02 18:47:57.727 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0038523 seconds 2018-06-02 18:47:57.727 Info App: Core startup complete 2018-06-02 18:47:57.727 Info App: Post-init migrations complete 2018-06-02 18:47:57.727 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-06-02 18:47:57.727 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0.000115 seconds 2018-06-02 18:47:57.727 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2018-06-02 18:47:57.728 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0003648 seconds 2018-06-02 18:47:57.728 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2018-06-02 18:47:57.728 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 6.27E-05 seconds 2018-06-02 18:47:57.728 Info App: Starting entry point Emby.Server.Implementations.Notifications.Notifications 2018-06-02 18:47:57.735 Info App: Entry point completed: Emby.Server.Implementations.Notifications.Notifications. Duration: 0.0067965 seconds 2018-06-02 18:47:57.735 Info App: Starting entry point Emby.Server.Implementations.Notifications.WebSocketNotifier 2018-06-02 18:47:57.736 Info App: Entry point completed: Emby.Server.Implementations.Notifications.WebSocketNotifier. Duration: 0.0017409 seconds 2018-06-02 18:47:57.736 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2018-06-02 18:47:57.737 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0005438 seconds 2018-06-02 18:47:57.737 Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint 2018-06-02 18:47:57.743 Info App: Loading live tv data from /var/lib/emby/data/livetv/timers 2018-06-02 18:47:57.892 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 192.168.1.145 2018-06-02 18:47:57.911 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.1741575 seconds 2018-06-02 18:47:57.911 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2018-06-02 18:47:57.912 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0008848 seconds 2018-06-02 18:47:57.912 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2018-06-02 18:47:57.925 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:47:57.929 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 10.8.0.1 2018-06-02 18:47:57.932 Info HttpServer: HTTP GET http://10.8.0.1:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:47:57.933 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on fe80::3ed9:2bff:fe79:bded%2 2018-06-02 18:47:57.934 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on fe80::19ff:ed13:3a9c:8943%3 2018-06-02 18:47:57.943 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:47:57.989 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 46ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:47:57.990 Info HttpServer: HTTP Response 200 to 192.168.1.145. Time: 68ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:47:57.990 Info HttpServer: HTTP Response 200 to 10.8.0.1. Time: 60ms. http://10.8.0.1:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:47:58.033 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:47:58.037 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 3ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:47:58.066 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.153936 seconds 2018-06-02 18:47:58.066 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2018-06-02 18:47:58.067 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0006533 seconds 2018-06-02 18:47:58.067 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding 2018-06-02 18:47:58.079 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.01149 seconds 2018-06-02 18:47:58.079 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2018-06-02 18:47:58.079 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0003995 seconds 2018-06-02 18:47:58.079 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2018-06-02 18:47:58.082 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.003127 seconds 2018-06-02 18:47:58.082 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier 2018-06-02 18:47:58.085 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.0030985 seconds 2018-06-02 18:47:58.085 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2018-06-02 18:47:58.089 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0037044 seconds 2018-06-02 18:47:58.089 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2018-06-02 18:47:58.090 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0011608 seconds 2018-06-02 18:47:58.091 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2018-06-02 18:47:58.091 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0008119 seconds 2018-06-02 18:47:58.091 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint 2018-06-02 18:47:58.094 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0026662 seconds 2018-06-02 18:47:58.094 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint 2018-06-02 18:47:58.097 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.0024833 seconds 2018-06-02 18:47:58.097 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2018-06-02 18:47:58.098 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0008783 seconds 2018-06-02 18:47:58.098 Info App: Starting entry point Emby.Server.Implementations.Devices.DeviceManagerEntryPoint 2018-06-02 18:47:58.100 Info App: Entry point completed: Emby.Server.Implementations.Devices.DeviceManagerEntryPoint. Duration: 0.0019328 seconds 2018-06-02 18:47:58.100 Info App: Starting entry point Emby.Server.Implementations.Collections.CollectionManagerEntryPoint 2018-06-02 18:47:58.102 Info App: Entry point completed: Emby.Server.Implementations.Collections.CollectionManagerEntryPoint. Duration: 0.0022323 seconds 2018-06-02 18:47:58.102 Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint 2018-06-02 18:47:58.105 Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0030087 seconds 2018-06-02 18:47:58.105 Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint 2018-06-02 18:47:58.106 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.0013104 seconds 2018-06-02 18:47:58.106 Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint 2018-06-02 18:47:58.107 Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.0003471 seconds 2018-06-02 18:47:58.107 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-06-02 18:47:58.107 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 5.95E-05 seconds 2018-06-02 18:47:58.107 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2018-06-02 18:47:58.115 Info App: Sqlite version: 3.23.1 2018-06-02 18:47:58.115 Info App: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2018-06-02 18:47:58.116 Info App: Default journal_mode for /var/lib/emby/data/sync14.db is delete 2018-06-02 18:47:58.134 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:47:58.135 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:47:58.153 Info App: PRAGMA synchronous=1 2018-06-02 18:47:58.184 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0768561 seconds 2018-06-02 18:47:58.184 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2018-06-02 18:47:58.186 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0018753 seconds 2018-06-02 18:47:58.186 Info App: All entry points have started 2018-06-02 18:47:58.251 Info HttpClient: GET https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2018-06-02 18:47:58.422 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-06-02 18:47:58.424 Info HttpServer: HTTP Response 200 to 192.168.1.145. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:47:58.525 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-06-02 18:47:58.549 Info HttpServer: HTTP Response 200 to 192.168.1.145. Time: 24ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/contentdirectory/contentdirectory.xml 2018-06-02 18:47:58.550 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-06-02 18:47:58.562 Info HttpServer: HTTP Response 200 to 192.168.1.145. Time: 13ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/connectionmanager/connectionmanager.xml 2018-06-02 18:48:00.288 Info TaskManager: StartupTrigger fired for task: Check for plugin updates 2018-06-02 18:48:00.288 Info TaskManager: StartupTrigger fired for task: Check for application updates 2018-06-02 18:48:00.290 Info TaskManager: Queueing task PluginUpdateTask 2018-06-02 18:48:00.290 Info TaskManager: Queueing task SystemUpdateTask 2018-06-02 18:48:00.300 Info TaskManager: Executing Check for application updates 2018-06-02 18:48:00.300 Info TaskManager: Executing Check for plugin updates 2018-06-02 18:48:00.321 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2018-06-02 18:48:00.321 Info HttpClient: GET https://api.github.com/repos/MediaBrowser/Emby.Releases/releases 2018-06-02 18:48:00.806 Info HttpClient: GetTempFileResponse url: http://embydata.com/admin/service/packageFiles/OpenSubtitles.dll_1.0.2.exe 2018-06-02 18:48:00.908 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds 2018-06-02 18:48:00.928 Info TaskManager: ExecuteQueuedTasks 2018-06-02 18:48:00.970 Info InstallationManager: New plugin installed: OpenSubtitles 1.0.2 Release 2018-06-02 18:48:00.993 Info App: App needs to be restarted. 2018-06-02 18:48:00.994 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2018-06-02 18:48:00.994 Info TaskManager: ExecuteQueuedTasks 2018-06-02 18:48:03.066 Info HttpClient: POST https://connect.emby.media/service/Servers 2018-06-02 18:48:12.462 Info HttpServer: HTTP GET http://71.45.99.229:8096/. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:12.464 Info HttpServer: HTTP Response 302 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/ 2018-06-02 18:48:15.554 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/strings/en-US.json?v=1527983295652. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:15.565 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527983295652. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:15.566 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527983295652 2018-06-02 18:48:15.576 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/favicon.ico. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:15.578 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/favicon.ico 2018-06-02 18:48:16.021 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 468ms. http://71.45.99.229:8096/web/strings/en-US.json?v=1527983295652 2018-06-02 18:48:17.974 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:17.994 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 20ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 18:48:18.930 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/strings/en-US.json?v=1527983299031. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:18.931 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/strings/en-US.json?v=1527983299031 2018-06-02 18:48:18.940 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527983299031. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:18.941 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527983299031 2018-06-02 18:48:20.570 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:20.571 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 18:48:20.875 Info HttpResultFactory: Setting range response values for /opt/emby-server/system/dashboard-ui/bower_components/jquery/dist/jquery.slim.min.js. RangeRequest: bytes=5083-5083 Content-Length: 1, Content-Range: bytes 5083-5083/69917 2018-06-02 18:48:20.933 Info HttpResultFactory: Setting range response values for /opt/emby-server/system/dashboard-ui/bower_components/jquery/dist/jquery.slim.min.js. RangeRequest: bytes=5083-69916 Content-Length: 64834, Content-Range: bytes 5083-69916/69917 2018-06-02 18:48:21.945 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:21.951 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/Options. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:22.093 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 148ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 18:48:22.098 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 147ms. http://71.45.99.229:8096/emby/Localization/Options 2018-06-02 18:48:22.099 Info App: App Activity: app: Emby Mobile, version: 3.4.1.0, deviceId: TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5, deviceName: Chrome 2018-06-02 18:48:22.099 Info App: App Activity: app: Emby Mobile, version: 3.4.1.0, deviceId: TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5, deviceName: Chrome 2018-06-02 18:48:22.219 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:48:22.221 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2018-06-02 18:48:27.962 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:48:27.963 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:48:28.176 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:48:28.178 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 2ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:50:27.961 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:50:27.961 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:50:28.172 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:50:28.174 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 2ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:51:27.959 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:51:27.960 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:51:28.185 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:51:28.186 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:51:28.244 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:51:28.246 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:52:27.965 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:52:27.966 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 2ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:52:28.380 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:52:28.381 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:52:28.449 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:52:28.450 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:53:05.695 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:05.696 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 18:53:06.218 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:06.227 Info ServerConfigurationManager: Saving system configuration 2018-06-02 18:53:06.228 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 10ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 18:53:10.299 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/User. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:10.306 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 7ms. http://71.45.99.229:8096/emby/Startup/User 2018-06-02 18:53:18.889 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/User. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:18.919 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 30ms. http://71.45.99.229:8096/emby/Startup/User 2018-06-02 18:53:21.538 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:21.566 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 28ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 18:53:27.972 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:53:27.973 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:53:28.167 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:53:28.168 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:53:29.727 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/cultures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:29.735 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/countries. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:29.738 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 11ms. http://71.45.99.229:8096/emby/Localization/cultures 2018-06-02 18:53:29.744 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 10ms. http://71.45.99.229:8096/emby/Localization/countries 2018-06-02 18:53:30.290 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/cultures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:30.291 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Localization/cultures 2018-06-02 18:53:30.370 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/countries. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:30.371 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Localization/countries 2018-06-02 18:53:30.612 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:53:30.613 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:53:31.335 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:31.344 Error HttpServer: Access token is required. 2018-06-02 18:53:31.347 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 13ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 18:53:31.414 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:31.415 Error HttpServer: Access token is required. 2018-06-02 18:53:31.415 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 18:53:32.236 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:32.236 Error HttpServer: Access token is required. 2018-06-02 18:53:32.237 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 18:53:32.477 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:32.479 Error HttpServer: Access token is required. 2018-06-02 18:53:32.480 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 18:53:35.378 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?LibraryContentType=movies&IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:35.379 Error HttpServer: Access token is required. 2018-06-02 18:53:35.379 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?LibraryContentType=movies&IsNewLibrary=true 2018-06-02 18:53:42.184 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info/Public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:42.186 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Info/Public 2018-06-02 18:53:42.190 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:42.197 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 7ms. http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser 2018-06-02 18:53:42.305 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/Drives. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:42.327 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 22ms. http://71.45.99.229:8096/emby/Environment/Drives 2018-06-02 18:53:44.809 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%5Cmnt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:44.815 Info HttpServer: HTTP Response 404 to 97.85.21.21. Time: 9ms. http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%5Cmnt 2018-06-02 18:53:44.815 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/ParentPath?path=%5Cmnt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:53:44.819 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Environment/ParentPath?path=%5Cmnt 2018-06-02 18:54:01.812 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%5Cmnt%5CHDD%5Ccomplete%5Cmovies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:01.814 Info HttpServer: HTTP Response 404 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%5Cmnt%5CHDD%5Ccomplete%5Cmovies 2018-06-02 18:54:01.839 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/ParentPath?path=%5Cmnt%5CHDD%5Ccomplete%5Cmovies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:01.839 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/ParentPath?path=%5Cmnt%5CHDD%5Ccomplete%5Cmovies 2018-06-02 18:54:01.906 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Environment/ValidatePath. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:01.910 Info HttpServer: HTTP Response 404 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/Environment/ValidatePath 2018-06-02 18:54:12.369 Info HttpServer: HTTP GET http://71.45.99.229:8096/. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:12.369 Info HttpServer: HTTP Response 302 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/ 2018-06-02 18:54:14.119 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/strings/en-US.json?v=1527983654211. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:14.126 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527983654211. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:14.128 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527983654211 2018-06-02 18:54:14.617 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 498ms. http://71.45.99.229:8096/web/strings/en-US.json?v=1527983654211 2018-06-02 18:54:16.188 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:16.189 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 18:54:17.051 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:17.052 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 18:54:17.065 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/Options. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:17.066 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Localization/Options 2018-06-02 18:54:17.488 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:17.489 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2018-06-02 18:54:18.912 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:18.913 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 18:54:18.979 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:18.980 Info ServerConfigurationManager: Saving system configuration 2018-06-02 18:54:18.980 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 18:54:19.584 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/User. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:19.585 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Startup/User 2018-06-02 18:54:22.332 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/User. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:22.334 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Startup/User 2018-06-02 18:54:22.756 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:22.757 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 18:54:25.416 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/cultures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:25.417 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Localization/cultures 2018-06-02 18:54:25.419 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/countries. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:25.422 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Localization/countries 2018-06-02 18:54:25.625 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:25.626 Error HttpServer: Access token is required. 2018-06-02 18:54:25.626 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 18:54:25.715 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:25.716 Error HttpServer: Access token is required. 2018-06-02 18:54:25.716 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 18:54:28.565 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?LibraryContentType=movies&IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:28.565 Error HttpServer: Access token is required. 2018-06-02 18:54:28.566 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?LibraryContentType=movies&IsNewLibrary=true 2018-06-02 18:54:30.977 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info/Public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:30.978 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Info/Public 2018-06-02 18:54:30.982 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:30.982 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser 2018-06-02 18:54:31.061 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/Drives. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:31.062 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/Drives 2018-06-02 18:54:35.813 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Fmovies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:35.817 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Fmovies 2018-06-02 18:54:35.821 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Fmovies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:35.822 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Fmovies 2018-06-02 18:54:37.452 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Environment/ValidatePath. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:37.453 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/ValidatePath 2018-06-02 18:54:39.528 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:39.529 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser 2018-06-02 18:54:39.609 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/Drives. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:39.611 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Environment/Drives 2018-06-02 18:54:43.260 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Fmovies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:43.261 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Fmovies 2018-06-02 18:54:43.266 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Fmovies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:43.266 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Fmovies 2018-06-02 18:54:44.726 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Environment/ValidatePath. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:44.727 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/ValidatePath 2018-06-02 18:54:46.980 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Library/VirtualFolders?collectionType=movies&refreshLibrary=false&name=Movies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:48.058 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 1078ms (slow). http://71.45.99.229:8096/emby/Library/VirtualFolders?collectionType=movies&refreshLibrary=false&name=Movies 2018-06-02 18:54:48.319 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:48.330 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 11ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 18:54:50.913 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/cultures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:50.914 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Localization/cultures 2018-06-02 18:54:50.921 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/countries. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:50.923 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Localization/countries 2018-06-02 18:54:51.177 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:51.177 Error HttpServer: Access token is required. 2018-06-02 18:54:51.178 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 18:54:51.230 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:51.231 Error HttpServer: Access token is required. 2018-06-02 18:54:51.231 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 18:54:53.620 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?LibraryContentType=tvshows&IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:53.621 Error HttpServer: Access token is required. 2018-06-02 18:54:53.621 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?LibraryContentType=tvshows&IsNewLibrary=true 2018-06-02 18:54:57.527 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:57.528 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser 2018-06-02 18:54:57.610 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/Drives. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:54:57.612 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Environment/Drives 2018-06-02 18:55:08.412 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Ftv. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:08.415 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Ftv 2018-06-02 18:55:08.420 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Ftv. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:08.421 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Ftv 2018-06-02 18:55:10.336 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Environment/ValidatePath. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:10.338 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Environment/ValidatePath 2018-06-02 18:55:12.533 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:12.534 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser 2018-06-02 18:55:12.610 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/Drives. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:12.611 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Environment/Drives 2018-06-02 18:55:21.993 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Ftv. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:21.999 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Ftv. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:21.999 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Ftv 2018-06-02 18:55:22.019 Error HttpServer: Error processing request *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/tv' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Api.EnvironmentService.GetFileSystemEntries(GetDirectoryContents request) at MediaBrowser.Api.EnvironmentService.Get(GetDirectoryContents request) at Emby.Server.Implementations.Services.ServiceExecGeneral.Execute(Type serviceType, IRequest request, Object instance, Object requestDto, String requestName) at Emby.Server.Implementations.Services.ServiceController.Execute(HttpListenerHost appHost, Object requestDto, IRequest req) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__13.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__70.MoveNext() System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Api.EnvironmentService.GetFileSystemEntries(GetDirectoryContents request) at MediaBrowser.Api.EnvironmentService.Get(GetDirectoryContents request) at Emby.Server.Implementations.Services.ServiceExecGeneral.Execute(Type serviceType, IRequest request, Object instance, Object requestDto, String requestName) at Emby.Server.Implementations.Services.ServiceController.Execute(HttpListenerHost appHost, Object requestDto, IRequest req) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__13.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__70.MoveNext() InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:22.019 Info HttpServer: HTTP Response 500 to 97.85.21.21. Time: 26ms. http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Ftv 2018-06-02 18:55:23.453 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Environment/ValidatePath. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:23.454 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/ValidatePath 2018-06-02 18:55:27.280 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Library/VirtualFolders?collectionType=tvshows&refreshLibrary=false&name=TV%20Shows. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:27.963 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:55:27.965 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:55:28.196 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml. UserAgent: 2018-06-02 18:55:28.201 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 4ms. http://192.168.1.145:8096/dlna/76182be185fb47a0858a8b33694b7384/description.xml 2018-06-02 18:55:28.286 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 1006ms (slow). http://71.45.99.229:8096/emby/Library/VirtualFolders?collectionType=tvshows&refreshLibrary=false&name=TV%20Shows 2018-06-02 18:55:28.560 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:28.562 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 18:55:36.800 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:36.801 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 18:55:36.801 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/cultures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:36.803 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Localization/cultures 2018-06-02 18:55:36.807 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/countries. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:36.810 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Localization/countries 2018-06-02 18:55:38.937 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:38.938 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 18:55:39.013 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:39.013 Info ServerConfigurationManager: Saving system configuration 2018-06-02 18:55:39.013 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 18:55:39.132 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:39.138 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 6ms. http://71.45.99.229:8096/emby/Startup/Info 2018-06-02 18:55:42.139 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/RemoteAccess. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:42.141 Info ServerConfigurationManager: Saving system configuration 2018-06-02 18:55:42.141 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Startup/RemoteAccess 2018-06-02 18:55:45.654 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/amazon.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:45.655 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/clients/amazon.png 2018-06-02 18:55:45.662 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/playstore.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:45.662 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/web/css/images/clients/playstore.png 2018-06-02 18:55:45.672 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/roku.jpg. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:45.672 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/ios.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:45.673 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms.
mike689 0 Posted June 3, 2018 Author Posted June 3, 2018 (edited) pt 2 (final) Sorry it's so large, there was many attempts hah http://71.45.99.229:8096/web/css/images/clients/roku.jpg 2018-06-02 18:55:45.673 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/web/css/images/clients/ios.png 2018-06-02 18:55:45.710 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/mbc.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:45.711 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/clients/mbc.png 2018-06-02 18:55:45.723 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/kodi.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:45.725 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/web/css/images/clients/kodi.png 2018-06-02 18:55:45.728 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/windowsphone.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:45.728 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/web/css/images/clients/windowsphone.png 2018-06-02 18:55:45.769 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/windowsrt.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:45.770 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/clients/windowsrt.png 2018-06-02 18:55:51.046 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/Complete. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:51.050 Info ServerConfigurationManager: Saving system configuration 2018-06-02 18:55:51.051 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 5ms. http://71.45.99.229:8096/emby/Startup/Complete 2018-06-02 18:55:51.058 Info TaskManager: Queueing task RefreshMediaLibraryTask 2018-06-02 18:55:51.058 Info TaskManager: Executing Scan media library 2018-06-02 18:55:51.067 Info App: Validating media library 2018-06-02 18:55:51.109 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:51.110 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 18:55:51.184 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/users/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:51.281 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 97ms. http://71.45.99.229:8096/emby/users/public 2018-06-02 18:55:51.323 Error App: Error in GetFilteredFileSystemEntries isPhysicalRoot: False IsVf: False *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/tv' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.384 Error BaseItem: Error refreshing owned items for /mnt/HDD/complete/torrents/tv *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/tv' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.BaseItem.<RefreshMetadata>d__347.MoveNext() System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.BaseItem.<RefreshMetadata>d__347.MoveNext() InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.387 Error App: Error validating images for /mnt/HDD/complete/torrents/tv *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/tv' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetFiles(BaseItem item, Boolean includeDirectories, IDirectoryService directoryService) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetImages(BaseItem item, IDirectoryService directoryService) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.Providers.Manager.ItemImageProvider.ValidateImages(BaseItem item, IEnumerable`1 providers, IDirectoryService directoryService) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__8.MoveNext() System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetFiles(BaseItem item, Boolean includeDirectories, IDirectoryService directoryService) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetImages(BaseItem item, IDirectoryService directoryService) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.Providers.Manager.ItemImageProvider.ValidateImages(BaseItem item, IEnumerable`1 providers, IDirectoryService directoryService) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__8.MoveNext() InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.479 Error App: Error validating images for /var/lib/emby/root/default/TV Shows *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/tv' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateFiles(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateFiles(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFiles(String path, String[] extensions, Boolean enableCaseSensitiveExtensions, Boolean recursive) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToArray() at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.OrderedEnumerable`1.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetImages(BaseItem item, IEnumerable`1 paths, Boolean arePathsInMediaFolders, IDirectoryService directoryService) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.Providers.Manager.ItemImageProvider.ValidateImages(BaseItem item, IEnumerable`1 providers, IDirectoryService directoryService) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__8.MoveNext() System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateFiles(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateFiles(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFiles(String path, String[] extensions, Boolean enableCaseSensitiveExtensions, Boolean recursive) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToArray() at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.OrderedEnumerable`1.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetImages(BaseItem item, IEnumerable`1 paths, Boolean arePathsInMediaFolders, IDirectoryService directoryService) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.Providers.Manager.ItemImageProvider.ValidateImages(BaseItem item, IEnumerable`1 providers, IDirectoryService directoryService) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__8.MoveNext() InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.506 Error App: Error validating images for /var/lib/emby/root/default/TV Shows *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/tv' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateFiles(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateFiles(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFiles(String path, String[] extensions, Boolean enableCaseSensitiveExtensions, Boolean recursive) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToArray() at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.OrderedEnumerable`1.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetImages(BaseItem item, IEnumerable`1 paths, Boolean arePathsInMediaFolders, IDirectoryService directoryService) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.Providers.Manager.ItemImageProvider.ValidateImages(BaseItem item, IEnumerable`1 providers, IDirectoryService directoryService) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__8.MoveNext() System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateFiles(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateFiles(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFiles(String path, String[] extensions, Boolean enableCaseSensitiveExtensions, Boolean recursive) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToArray() at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.OrderedEnumerable`1.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetImages(BaseItem item, IEnumerable`1 paths, Boolean arePathsInMediaFolders, IDirectoryService directoryService) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.Providers.Manager.ItemImageProvider.ValidateImages(BaseItem item, IEnumerable`1 providers, IDirectoryService directoryService) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__8.MoveNext() InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.517 Error App: Error in GetFilteredFileSystemEntries isPhysicalRoot: False IsVf: False *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/tv' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.546 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/users/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:51.547 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/users/public 2018-06-02 18:55:51.554 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Branding/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:51.559 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 6ms. http://71.45.99.229:8096/emby/Branding/Configuration 2018-06-02 18:55:51.581 Error App: Error resolving path /mnt/HDD/complete/torrents/movies/Annihilation.2018.1080p.BluRay.x264.Atmos.TrueHD7.1-HDChina *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/Annihilation.2018.1080p.BluRay.x264.Atmos.TrueHD7.1-HDChina' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.582 Error App: Error resolving path /mnt/HDD/complete/torrents/movies/A.Quiet.Place.2018.720p.HC.HDRip.X264.AC3-EVO *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/A.Quiet.Place.2018.720p.HC.HDRip.X264.AC3-EVO' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.584 Error App: Error resolving path /mnt/HDD/complete/torrents/movies/Avengers.Infinity.War.2018.NEW.720p.HD-TS.X264-CPG *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/Avengers.Infinity.War.2018.NEW.720p.HD-TS.X264-CPG' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.585 Error App: Error resolving path /mnt/HDD/complete/torrents/movies/Deadpool.2.2018.720p.TS.ENG.X264.1xbit *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/Deadpool.2.2018.720p.TS.ENG.X264.1xbit' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.587 Error App: Error resolving path /mnt/HDD/complete/torrents/movies/Tomb Raider 2018 1080p WEB-DL DD5 1 H264-CMRG *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/Tomb Raider 2018 1080p WEB-DL DD5 1 H264-CMRG' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 18:55:51.635 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Users/authenticatebyname. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:51.670 Info UserManager: Authentication request for mike has succeeded. 2018-06-02 18:55:51.686 Info SessionManager: Creating new access token for user ad68974553944d809029932a5e27692d 2018-06-02 18:55:51.829 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 195ms. http://71.45.99.229:8096/emby/Users/authenticatebyname 2018-06-02 18:55:51.888 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:51.892 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=ad68974553944d809029932a5e27692d&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:51.927 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 34ms. http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=ad68974553944d809029932a5e27692d&client=emby 2018-06-02 18:55:51.940 Info HttpServer: WS ws://71.45.99.229:8096/embywebsocket?api_key=7e7985f26c374aa0a314a399e8839a85&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:51.997 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:52.000 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 112ms. http://71.45.99.229:8096/emby/Sessions/Capabilities/Full 2018-06-02 18:55:52.001 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d 2018-06-02 18:55:52.300 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:52.559 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 258ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Views 2018-06-02 18:55:52.951 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:52.953 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Views 2018-06-02 18:55:53.037 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=ad68974553944d809029932a5e27692d&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:53.112 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 76ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=ad68974553944d809029932a5e27692d&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 18:55:53.216 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:53.216 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:53.222 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=ad68974553944d809029932a5e27692d&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:53.228 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:53.237 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=767bffe4f11c93ef34b805451a696a4e. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:53.239 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 22ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 18:55:53.243 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 26ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 18:55:53.307 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 70ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=767bffe4f11c93ef34b805451a696a4e 2018-06-02 18:55:53.312 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 84ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2018-06-02 18:55:53.315 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 93ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=ad68974553944d809029932a5e27692d&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 18:55:54.492 Info HttpClient: GET https://api.themoviedb.org/3/configuration?api_key=f6bd687ffa63cd282b6ff2c6877f2669 2018-06-02 18:55:54.685 Info App: MovieDbProvider: Finding id for item: Gringo 2018-06-02 18:55:54.792 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Gringo&language=en 2018-06-02 18:55:55.092 Info HttpClient: GET https://api.themoviedb.org/3/movie/340022?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:55:55.307 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt3721964&plot=short&tomatoes=true&r=json 2018-06-02 18:55:55.499 Info HttpClient: GET https://api.themoviedb.org/3/movie/340022?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:55:55.583 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/340022?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:55:56.368 Info App: MovieDbProvider: Finding id for item: 12.Strong 2018-06-02 18:55:56.368 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=12.Strong&language=en 2018-06-02 18:55:56.668 Info HttpClient: GET https://api.themoviedb.org/3/movie/429351?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:55:56.755 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1413492&plot=short&tomatoes=true&r=json 2018-06-02 18:55:56.968 Info HttpClient: GET https://api.themoviedb.org/3/movie/429351?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:55:57.086 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/429351?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:55:57.597 Info App: MovieDbProvider: Finding id for item: A.Wrinkle.in.Time 2018-06-02 18:55:57.597 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=A.Wrinkle.in.Time&language=en 2018-06-02 18:55:57.898 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=A+Wrinkle+in+Time&language=en 2018-06-02 18:55:58.005 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:58.015 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 9ms. http://71.45.99.229:8096/emby/System/Endpoint 2018-06-02 18:55:58.079 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:58.200 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:58.200 Info HttpClient: GET https://api.themoviedb.org/3/movie/407451?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:55:58.262 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:55:58.263 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1620680&plot=short&tomatoes=true&r=json 2018-06-02 18:55:58.500 Info HttpClient: GET https://api.themoviedb.org/3/movie/407451?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:55:58.568 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/407451?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:55:58.964 Info App: MovieDbProvider: Finding id for item: Animal.House 2018-06-02 18:55:58.964 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Animal.House&language=en 2018-06-02 18:55:59.258 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Animal+House&language=en 2018-06-02 18:55:59.561 Info HttpClient: GET https://api.themoviedb.org/3/movie/8469?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:55:59.632 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt0077975&plot=short&tomatoes=true&r=json 2018-06-02 18:55:59.861 Info HttpClient: GET https://api.themoviedb.org/3/movie/8469?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:56:00.016 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/8469?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:56:00.466 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Notifications/ad68974553944d809029932a5e27692d/Summary. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:00.491 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 25ms. http://71.45.99.229:8096/emby/Notifications/ad68974553944d809029932a5e27692d/Summary 2018-06-02 18:56:00.506 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:00.539 Info App: MovieDbProvider: Finding id for item: Batman.Ninja 2018-06-02 18:56:00.541 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:00.541 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:00.541 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Batman.Ninja&language=en 2018-06-02 18:56:00.543 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 37ms. http://71.45.99.229:8096/emby/Sessions 2018-06-02 18:56:00.586 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:00.606 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 21ms. http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4 2018-06-02 18:56:00.607 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 66ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 18:56:00.613 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 72ms. http://71.45.99.229:8096/emby/ScheduledTasks 2018-06-02 18:56:00.668 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=ad68974553944d809029932a5e27692d&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:00.668 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-01T23%3A56%3A00.604Z. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:00.687 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 19ms. http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=ad68974553944d809029932a5e27692d&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2018-06-02 18:56:00.697 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 29ms. http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-01T23%3A56%3A00.604Z 2018-06-02 18:56:00.739 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:00.745 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:00.754 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2018-06-02 18:56:00.769 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 30ms. http://71.45.99.229:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true 2018-06-02 18:56:00.843 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Batman+Ninja&language=en 2018-06-02 18:56:01.143 Info HttpClient: GET https://api.themoviedb.org/3/movie/485942?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:56:01.160 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/logoblack.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:01.161 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/logoblack.png 2018-06-02 18:56:01.206 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt7451284&plot=short&tomatoes=true&r=json 2018-06-02 18:56:01.244 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 499ms. http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled 2018-06-02 18:56:01.444 Info HttpClient: GET https://api.themoviedb.org/3/movie/485942?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:56:01.513 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/485942?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:56:01.917 Info App: MovieDbProvider: Finding id for item: Black.Panther 2018-06-02 18:56:01.917 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Black.Panther&language=en 2018-06-02 18:56:02.217 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Black+Panther&language=en 2018-06-02 18:56:02.517 Info HttpClient: GET https://api.themoviedb.org/3/movie/284054?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:56:02.676 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1825683&plot=short&tomatoes=true&r=json 2018-06-02 18:56:02.709 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4630ms (slow). http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000 2018-06-02 18:56:02.817 Info HttpClient: GET https://api.themoviedb.org/3/movie/284054?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:56:03.007 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/284054?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:56:03.695 Info App: MovieDbProvider: Finding id for item: Dear.Dictator 2018-06-02 18:56:03.695 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Dear.Dictator&language=en 2018-06-02 18:56:03.997 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Dear+Dictator&language=en 2018-06-02 18:56:04.297 Info HttpClient: GET https://api.themoviedb.org/3/movie/418667?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:56:04.404 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt5779540&plot=short&tomatoes=true&r=json 2018-06-02 18:56:04.597 Info HttpClient: GET https://api.themoviedb.org/3/movie/418667?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:56:04.732 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/418667?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:56:05.223 Info App: MovieDbProvider: Finding id for item: den.of.thieves 2018-06-02 18:56:05.223 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=den.of.thieves&language=en 2018-06-02 18:56:05.523 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=den+of+thieves&language=en 2018-06-02 18:56:05.826 Info HttpClient: GET https://api.themoviedb.org/3/movie/449443?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:56:05.827 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:05.833 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:05.838 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 5ms. http://71.45.99.229:8096/emby/ScheduledTasks?IsEnabled=true 2018-06-02 18:56:05.839 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 13ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 18:56:06.050 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1259528&plot=short&tomatoes=true&r=json 2018-06-02 18:56:06.127 Info HttpClient: GET https://api.themoviedb.org/3/movie/449443?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:56:06.203 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/449443?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:56:06.356 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 8156ms (slow). http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000 2018-06-02 18:56:06.566 Info App: MovieDbProvider: Finding id for item: Future.World 2018-06-02 18:56:06.566 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Future.World&language=en 2018-06-02 18:56:06.865 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Future+World&language=en 2018-06-02 18:56:07.165 Info HttpClient: GET https://api.themoviedb.org/3/movie/411135?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:56:07.224 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt5737536&plot=short&tomatoes=true&r=json 2018-06-02 18:56:07.465 Info HttpClient: GET https://api.themoviedb.org/3/movie/411135?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:56:07.544 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/411135?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:56:07.867 Info App: MovieDbProvider: Finding id for item: Game.Night 2018-06-02 18:56:07.867 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Game.Night&language=en 2018-06-02 18:56:08.167 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Game+Night&language=en 2018-06-02 18:56:08.283 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:08.285 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Sessions 2018-06-02 18:56:08.293 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:08.294 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/ScheduledTasks 2018-06-02 18:56:08.301 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:08.302 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 18:56:08.307 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:08.309 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4 2018-06-02 18:56:08.313 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-01T23%3A56%3A08.389Z. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:08.315 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-01T23%3A56%3A08.389Z 2018-06-02 18:56:08.334 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=ad68974553944d809029932a5e27692d&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:08.335 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=ad68974553944d809029932a5e27692d&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2018-06-02 18:56:08.397 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:08.430 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 33ms. http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled 2018-06-02 18:56:08.467 Info HttpClient: GET https://api.themoviedb.org/3/movie/445571?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:56:08.524 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt2704998&plot=short&tomatoes=true&r=json 2018-06-02 18:56:08.769 Info HttpClient: GET https://api.themoviedb.org/3/movie/445571?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:56:08.856 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/445571?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:56:09.285 Info App: MovieDbProvider: Finding id for item: The.15.17.to.Paris 2018-06-02 18:56:09.285 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The.15.17.to.Paris&language=en 2018-06-02 18:56:09.585 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The+15+17+to+Paris&language=en 2018-06-02 18:56:09.889 Info HttpClient: GET https://api.themoviedb.org/3/movie/453201?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:56:09.970 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt6802308&plot=short&tomatoes=true&r=json 2018-06-02 18:56:10.189 Info HttpClient: GET https://api.themoviedb.org/3/movie/453201?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 18:56:10.246 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/453201?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 18:56:10.645 Info App: MovieDbProvider: Finding id for item: The.Greatest.Showman 2018-06-02 18:56:10.645 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The.Greatest.Showman&language=en 2018-06-02 18:56:10.809 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:10.811 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Views 2018-06-02 18:56:10.868 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:10.870 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Views 2018-06-02 18:56:10.933 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=ad68974553944d809029932a5e27692d&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:10.936 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=ad68974553944d809029932a5e27692d&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 18:56:10.944 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The+Greatest+Showman&language=en 2018-06-02 18:56:10.988 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:10.992 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 18:56:10.996 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=ad68974553944d809029932a5e27692d&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:10.997 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:11.002 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 5ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 18:56:11.003 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:11.005 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=767bffe4f11c93ef34b805451a696a4e. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:11.023 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 18ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=767bffe4f11c93ef34b805451a696a4e 2018-06-02 18:56:11.023 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 27ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=ad68974553944d809029932a5e27692d&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 18:56:11.035 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 32ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2018-06-02 18:56:11.194 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/aabc51cf4e6b61668f61b4a91347e1b5/Images/Primary?maxHeight=630&maxWidth=420&tag=aed5bb9579b04ce5bd5a71e5d32ecf45&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:11.194 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/ff501ac8db77da112ca03ce033b9fd9e/Images/Primary?maxHeight=630&maxWidth=420&tag=2418c66d3a741da16ce88aedbb6579ef&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:11.200 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/b14fd96419081f5b9b78d879839074bf/Images/Primary?maxHeight=630&maxWidth=420&tag=399b920c8611bfe9350b397551e29d51&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:11.237 Info HttpClient: GET https://image.tmdb.org/t/p/original/qxJQ0VBCuJkJhJmuWzxI408ngwd.jpg 2018-06-02 18:56:11.237 Info HttpClient: GET https://image.tmdb.org/t/p/original/85R8LMyn9f2Lev2YPBF8Nughrkv.jpg 2018-06-02 18:56:11.237 Info HttpClient: GET https://image.tmdb.org/t/p/original/uxzzxijgPIY7slzFvMotPv8wjKA.jpg 2018-06-02 18:56:11.245 Info HttpClient: GET https://api.themoviedb.org/3/movie/316029?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 18:56:11.354 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/6ca1e757cf2920fc2ec8647606847cc1/Images/Primary?maxHeight=630&maxWidth=420&tag=abe1250c08f45c41554800edbfdef89b&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:11.360 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/66ad8a997cd270f6f3400b15e3f9655c/Images/Primary?maxHeight=630&maxWidth=420&tag=1169a776ee1b937784d698e58c2d30b0&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 18:56:11.361 Info HttpClient: GET https://image.tmdb.org/t/p/original/kMA0IalnEEa0PaHRUzzjpTu5xXQ.jpg Edited June 3, 2018 by mike689
Luke 42246 Posted June 3, 2018 Posted June 3, 2018 Can you describe what happened? it looks like you were trying to create a library, no?
mike689 0 Posted June 3, 2018 Author Posted June 3, 2018 Yeah, basically I go through the first setup. Create my TV and Movies library and add the necessary folders. And at some point when it's loading all that the interface just craps out. I'll try and set it up without creating a library initially and see what happens.
mike689 0 Posted June 3, 2018 Author Posted June 3, 2018 (edited) Interesting, without the media setup initially it does appear to be staying stable. I'm going to add the Movie media first and see what happens from here. EDIT: I added the first movie folder and it synced everything ok and remained stable. I then added my second movie folder, with more data in it, and the interface unfortunately dropped out again shortly after it started to sync again. Log pt 1 of 3 2018-06-02 21:31:23.690 Info Main: Application path: /opt/emby-server/system/EmbyServer.dll 2018-06-02 21:31:23.715 Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system 2018-06-02 21:31:23.936 Info App: Application version: 3.4.1.0 2018-06-02 21:31:23.939 Info App: Loading assemblies 2018-06-02 21:31:23.960 Info App: Loading IMVDb, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/IMVDb.dll 2018-06-02 21:31:23.960 Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Server.CinemaMode.dll 2018-06-02 21:31:23.960 Info App: Loading OpenSubtitles, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/OpenSubtitles.dll 2018-06-02 21:31:23.960 Info App: Loading MediaBrowser.Api, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading MediaBrowser.WebDashboard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading MediaBrowser.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading MediaBrowser.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading MediaBrowser.Controller, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading MediaBrowser.Providers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading Emby.Photos, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading Emby.Server.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading MediaBrowser.LocalMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading MediaBrowser.XbmcMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:23.960 Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-06-02 21:31:24.150 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-br.txt 2018-06-02 21:31:24.152 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-ca.txt 2018-06-02 21:31:24.152 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-co.txt 2018-06-02 21:31:24.152 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-dk.txt 2018-06-02 21:31:24.152 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-es.txt 2018-06-02 21:31:24.152 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-fr.txt 2018-06-02 21:31:24.152 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-gb.txt 2018-06-02 21:31:24.152 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-ie.txt 2018-06-02 21:31:24.152 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-jp.txt 2018-06-02 21:31:24.152 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-kz.txt 2018-06-02 21:31:24.153 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-mx.txt 2018-06-02 21:31:24.153 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-nl.txt 2018-06-02 21:31:24.153 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-nz.txt 2018-06-02 21:31:24.153 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-ro.txt 2018-06-02 21:31:24.153 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-uk.txt 2018-06-02 21:31:24.153 Info LocalizationManager: Extracting ratings to /var/lib/emby/localization/ratings-us.txt 2018-06-02 21:31:24.169 Info SqliteUserRepository: Sqlite version: 3.23.1 2018-06-02 21:31:24.170 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2018-06-02 21:31:24.204 Info SqliteUserRepository: Default journal_mode for /var/lib/emby/data/users.db is delete 2018-06-02 21:31:24.235 Info SqliteUserRepository: PRAGMA synchronous=1 2018-06-02 21:31:24.282 Info AuthenticationRepository: Default journal_mode for /var/lib/emby/data/authentication.db is delete 2018-06-02 21:31:24.311 Info AuthenticationRepository: PRAGMA synchronous=1 2018-06-02 21:31:24.434 Info DeviceManager: Default journal_mode for /var/lib/emby/data/devices.db is delete 2018-06-02 21:31:24.451 Info DeviceManager: PRAGMA synchronous=1 2018-06-02 21:31:24.506 Info ActivityRepository: Default journal_mode for /var/lib/emby/data/activitylog.db is delete 2018-06-02 21:31:24.517 Info ActivityRepository: PRAGMA synchronous=1 2018-06-02 21:31:24.530 Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/lib/emby/data/displaypreferences.db is delete 2018-06-02 21:31:24.550 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 2018-06-02 21:31:24.565 Info SqliteItemRepository: Default journal_mode for /var/lib/emby/data/library.db is delete 2018-06-02 21:31:24.590 Info SqliteItemRepository: PRAGMA synchronous=1 2018-06-02 21:31:24.635 Info SqliteNotificationsRepository: Default journal_mode for /var/lib/emby/data/notifications.db is delete 2018-06-02 21:31:24.667 Info SqliteNotificationsRepository: PRAGMA synchronous=1 2018-06-02 21:31:24.863 Info App: Requesting administrative access to authorize http server 2018-06-02 21:31:24.865 Info ServerConfigurationManager: Saving system configuration 2018-06-02 21:31:25.054 Info HttpServer: Calling ServiceStack AppHost.Init 2018-06-02 21:31:25.747 Info ServerManager: Loading Http Server 2018-06-02 21:31:25.754 Info HttpServer: Adding HttpListener prefix http://+:8096/ 2018-06-02 21:31:25.754 Info HttpServer: Adding HttpListener prefix https://+:8920/ 2018-06-02 21:31:26.017 Info Skia: SkiaSharp version: 1.58.0.0 2018-06-02 21:31:26.055 Info TaskManager: Daily trigger for Chapter image extraction set to fire at 6/3/18 2:00:00 AM, which is 268.565750098333 minutes from now. 2018-06-02 21:31:26.063 Info TaskManager: Daily trigger for Rotate log file set to fire at 6/3/18 12:00:00 AM, which is 148.565612533333 minutes from now. 2018-06-02 21:31:26.073 Info MediaEncoder: FFMpeg: /opt/emby-server/bin/ffmpeg 2018-06-02 21:31:26.073 Info MediaEncoder: FFProbe: /opt/emby-server/bin/ffprobe 2018-06-02 21:31:26.074 Info MediaEncoder: Validating media encoder at /opt/emby-server/bin/ffmpeg 2018-06-02 21:31:26.077 Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -decoders 2018-06-02 21:31:26.120 Info MediaEncoder: Decoder available: mpeg2video 2018-06-02 21:31:26.129 Info MediaEncoder: Decoder available: h264_cuvid 2018-06-02 21:31:26.130 Info MediaEncoder: Decoder available: hevc_cuvid 2018-06-02 21:31:26.130 Info MediaEncoder: Decoder available: mpeg2_cuvid 2018-06-02 21:31:26.131 Info MediaEncoder: Decoder available: mpeg4_cuvid 2018-06-02 21:31:26.132 Info MediaEncoder: Decoder available: vc1_cuvid 2018-06-02 21:31:26.133 Info MediaEncoder: Decoder available: vp8_cuvid 2018-06-02 21:31:26.134 Info MediaEncoder: Decoder available: vp9_cuvid 2018-06-02 21:31:26.144 Info MediaEncoder: Decoder available: ac3 2018-06-02 21:31:26.145 Info MediaEncoder: Decoder available: aac 2018-06-02 21:31:26.147 Info MediaEncoder: Decoder available: mp3 2018-06-02 21:31:26.147 Info MediaEncoder: Decoder available: h264 2018-06-02 21:31:26.147 Info MediaEncoder: Decoder available: hevc 2018-06-02 21:31:26.160 Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -encoders 2018-06-02 21:31:26.195 Info MediaEncoder: Encoder available: libx264 2018-06-02 21:31:26.196 Info MediaEncoder: Encoder available: mpeg4 2018-06-02 21:31:26.196 Info MediaEncoder: Encoder available: msmpeg4 2018-06-02 21:31:26.198 Info MediaEncoder: Encoder available: aac 2018-06-02 21:31:26.198 Info MediaEncoder: Encoder available: libmp3lame 2018-06-02 21:31:26.198 Info MediaEncoder: Encoder available: libopus 2018-06-02 21:31:26.199 Info MediaEncoder: Encoder available: libvorbis 2018-06-02 21:31:26.200 Info MediaEncoder: Encoder available: srt 2018-06-02 21:31:26.200 Info MediaEncoder: Encoder available: h264_nvenc 2018-06-02 21:31:26.200 Info MediaEncoder: Encoder available: hevc_nvenc 2018-06-02 21:31:26.204 Info MediaEncoder: Encoder available: h264_vaapi 2018-06-02 21:31:26.204 Info MediaEncoder: Encoder available: hevc_vaapi 2018-06-02 21:31:26.204 Info MediaEncoder: Encoder available: h264_v4l2m2m 2018-06-02 21:31:26.205 Info MediaEncoder: Encoder available: libwebp 2018-06-02 21:31:26.205 Info MediaEncoder: Encoder available: ac3 2018-06-02 21:31:26.205 Info MediaEncoder: Encoder validation complete 2018-06-02 21:31:26.209 Info App: ServerId: e179ae65512e428783510cc8eca1629b 2018-06-02 21:31:26.257 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint 2018-06-02 21:31:26.258 Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.0010179 seconds 2018-06-02 21:31:26.258 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2018-06-02 21:31:26.518 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.2600765 seconds 2018-06-02 21:31:26.519 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2018-06-02 21:31:26.521 Info App: Loading data from /var/lib/emby/data/connect.txt 2018-06-02 21:31:26.522 Info App: Loading data from /var/lib/emby/data/wan.dat 2018-06-02 21:31:26.522 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0037314 seconds 2018-06-02 21:31:26.522 Info App: Core startup complete 2018-06-02 21:31:26.522 Info App: Post-init migrations complete 2018-06-02 21:31:26.522 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-06-02 21:31:26.523 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0.0001362 seconds 2018-06-02 21:31:26.523 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2018-06-02 21:31:26.523 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0003733 seconds 2018-06-02 21:31:26.523 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2018-06-02 21:31:26.523 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 6.55E-05 seconds 2018-06-02 21:31:26.523 Info App: Starting entry point Emby.Server.Implementations.Notifications.Notifications 2018-06-02 21:31:26.531 Info App: Entry point completed: Emby.Server.Implementations.Notifications.Notifications. Duration: 0.0074994 seconds 2018-06-02 21:31:26.531 Info App: Starting entry point Emby.Server.Implementations.Notifications.WebSocketNotifier 2018-06-02 21:31:26.532 Info App: Entry point completed: Emby.Server.Implementations.Notifications.WebSocketNotifier. Duration: 0.0016302 seconds 2018-06-02 21:31:26.533 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2018-06-02 21:31:26.536 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0029332 seconds 2018-06-02 21:31:26.536 Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint 2018-06-02 21:31:26.541 Info App: Loading live tv data from /var/lib/emby/data/livetv/timers 2018-06-02 21:31:26.701 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 192.168.1.145 2018-06-02 21:31:26.721 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.1852121 seconds 2018-06-02 21:31:26.721 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2018-06-02 21:31:26.722 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.001065 seconds 2018-06-02 21:31:26.722 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2018-06-02 21:31:26.739 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:31:26.742 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 10.8.0.1 2018-06-02 21:31:26.743 Info HttpServer: HTTP GET http://10.8.0.1:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:31:26.744 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on fe80::3ed9:2bff:fe79:bded%2 2018-06-02 21:31:26.744 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on fe80::1131:d508:9335:4181%3 2018-06-02 21:31:26.755 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:31:26.806 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 51ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:31:26.807 Info HttpServer: HTTP Response 200 to 192.168.1.145. Time: 72ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:31:26.807 Info HttpServer: HTTP Response 200 to 10.8.0.1. Time: 64ms. http://10.8.0.1:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:31:26.862 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:31:26.863 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:31:26.875 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.1532948 seconds 2018-06-02 21:31:26.875 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2018-06-02 21:31:26.876 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0007229 seconds 2018-06-02 21:31:26.876 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding 2018-06-02 21:31:26.888 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.01198 seconds 2018-06-02 21:31:26.888 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2018-06-02 21:31:26.889 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0004342 seconds 2018-06-02 21:31:26.889 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2018-06-02 21:31:26.891 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0024006 seconds 2018-06-02 21:31:26.891 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier 2018-06-02 21:31:26.893 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.0019674 seconds 2018-06-02 21:31:26.893 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2018-06-02 21:31:26.896 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0031652 seconds 2018-06-02 21:31:26.896 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2018-06-02 21:31:26.897 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0009413 seconds 2018-06-02 21:31:26.897 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2018-06-02 21:31:26.898 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0006616 seconds 2018-06-02 21:31:26.898 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint 2018-06-02 21:31:26.901 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0023453 seconds 2018-06-02 21:31:26.901 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint 2018-06-02 21:31:26.903 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.0025095 seconds 2018-06-02 21:31:26.903 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2018-06-02 21:31:26.904 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0008538 seconds 2018-06-02 21:31:26.904 Info App: Starting entry point Emby.Server.Implementations.Devices.DeviceManagerEntryPoint 2018-06-02 21:31:26.906 Info App: Entry point completed: Emby.Server.Implementations.Devices.DeviceManagerEntryPoint. Duration: 0.0019663 seconds 2018-06-02 21:31:26.906 Info App: Starting entry point Emby.Server.Implementations.Collections.CollectionManagerEntryPoint 2018-06-02 21:31:26.908 Info App: Entry point completed: Emby.Server.Implementations.Collections.CollectionManagerEntryPoint. Duration: 0.0022831 seconds 2018-06-02 21:31:26.908 Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint 2018-06-02 21:31:26.912 Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0030854 seconds 2018-06-02 21:31:26.912 Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint 2018-06-02 21:31:26.913 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.0013283 seconds 2018-06-02 21:31:26.913 Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint 2018-06-02 21:31:26.913 Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.0003981 seconds 2018-06-02 21:31:26.913 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-06-02 21:31:26.914 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 6.2E-05 seconds 2018-06-02 21:31:26.914 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2018-06-02 21:31:26.922 Info App: Sqlite version: 3.23.1 2018-06-02 21:31:26.922 Info App: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2018-06-02 21:31:26.923 Info App: Default journal_mode for /var/lib/emby/data/sync14.db is delete 2018-06-02 21:31:26.955 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:31:26.956 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:31:26.967 Info App: PRAGMA synchronous=1 2018-06-02 21:31:27.000 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0858408 seconds 2018-06-02 21:31:27.000 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2018-06-02 21:31:27.002 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0019232 seconds 2018-06-02 21:31:27.002 Info App: All entry points have started 2018-06-02 21:31:27.049 Info HttpClient: GET https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2018-06-02 21:31:27.236 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-06-02 21:31:27.236 Info HttpServer: HTTP Response 200 to 192.168.1.145. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:31:27.337 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-06-02 21:31:27.363 Info HttpServer: HTTP Response 200 to 192.168.1.145. Time: 25ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/contentdirectory/contentdirectory.xml 2018-06-02 21:31:27.364 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-06-02 21:31:27.375 Info HttpServer: HTTP Response 200 to 192.168.1.145. Time: 10ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/connectionmanager/connectionmanager.xml 2018-06-02 21:31:29.062 Info TaskManager: StartupTrigger fired for task: Check for plugin updates 2018-06-02 21:31:29.062 Info TaskManager: StartupTrigger fired for task: Check for application updates 2018-06-02 21:31:29.067 Info TaskManager: Queueing task SystemUpdateTask 2018-06-02 21:31:29.067 Info TaskManager: Queueing task PluginUpdateTask 2018-06-02 21:31:29.079 Info TaskManager: Executing Check for plugin updates 2018-06-02 21:31:29.079 Info TaskManager: Executing Check for application updates 2018-06-02 21:31:29.104 Info HttpClient: GET https://api.github.com/repos/MediaBrowser/Emby.Releases/releases 2018-06-02 21:31:29.104 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2018-06-02 21:31:29.544 Info HttpClient: GetTempFileResponse url: http://embydata.com/admin/service/packageFiles/OpenSubtitles.dll_1.0.2.exe 2018-06-02 21:31:29.670 Info InstallationManager: New plugin installed: OpenSubtitles 1.0.2 Release 2018-06-02 21:31:29.697 Info App: App needs to be restarted. 2018-06-02 21:31:29.699 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2018-06-02 21:31:29.724 Info TaskManager: ExecuteQueuedTasks 2018-06-02 21:31:29.808 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds 2018-06-02 21:31:29.808 Info TaskManager: ExecuteQueuedTasks 2018-06-02 21:31:31.716 Info HttpClient: POST https://connect.emby.media/service/Servers 2018-06-02 21:31:40.287 Info HttpServer: HTTP GET http://71.45.99.229:8096/. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:40.291 Info HttpServer: HTTP Response 302 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/ 2018-06-02 21:31:41.576 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/strings/en-US.json?v=1527993101601. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:41.584 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993101601. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:41.595 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 19ms. http://71.45.99.229:8096/web/strings/en-US.json?v=1527993101601 2018-06-02 21:31:41.596 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 13ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993101601 2018-06-02 21:31:42.876 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:42.896 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 20ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 21:31:43.486 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:43.488 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/Options. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:43.501 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:43.504 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:43.518 Error HttpServer: Access token is invalid or expired. 2018-06-02 21:31:43.523 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 22ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d 2018-06-02 21:31:43.550 Error HttpServer: Error processing request *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.ArgumentNullException: Value cannot be null. at MediaBrowser.Controller.Entities.Folder.GetChildren(User user, Boolean includeLinkedChildren) at Emby.Server.Implementations.Library.UserViewManager.GetUserViews(UserViewQuery query) at MediaBrowser.Api.UserLibrary.UserViewsService.Get(GetUserViews request) at Emby.Server.Implementations.Services.ServiceExecGeneral.Execute(Type serviceType, IRequest request, Object instance, Object requestDto, String requestName) at Emby.Server.Implementations.Services.ServiceController.Execute(HttpListenerHost appHost, Object requestDto, IRequest req) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__13.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__70.MoveNext() System.ArgumentNullException at MediaBrowser.Controller.Entities.Folder.GetChildren(User user, Boolean includeLinkedChildren) at Emby.Server.Implementations.Library.UserViewManager.GetUserViews(UserViewQuery query) at MediaBrowser.Api.UserLibrary.UserViewsService.Get(GetUserViews request) at Emby.Server.Implementations.Services.ServiceExecGeneral.Execute(Type serviceType, IRequest request, Object instance, Object requestDto, String requestName) at Emby.Server.Implementations.Services.ServiceController.Execute(HttpListenerHost appHost, Object requestDto, IRequest req) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__13.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__70.MoveNext() 2018-06-02 21:31:43.550 Info HttpServer: HTTP Response 400 to 97.85.21.21. Time: 46ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d/Views 2018-06-02 21:31:43.575 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:43.576 Error HttpServer: Access token is invalid or expired. 2018-06-02 21:31:43.577 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d 2018-06-02 21:31:43.578 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:43.579 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2018-06-02 21:31:43.694 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 208ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 21:31:43.694 Info App: App Activity: app: Emby Mobile, version: 3.4.1.0, deviceId: TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5, deviceName: Chrome 2018-06-02 21:31:43.694 Info App: App Activity: app: Emby Mobile, version: 3.4.1.0, deviceId: TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5, deviceName: Chrome 2018-06-02 21:31:43.695 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 207ms. http://71.45.99.229:8096/emby/Localization/Options 2018-06-02 21:31:51.291 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:51.292 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 21:31:51.383 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:51.395 Info ServerConfigurationManager: Saving system configuration 2018-06-02 21:31:51.395 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 12ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 21:31:52.089 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/User. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:52.096 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 7ms. http://71.45.99.229:8096/emby/Startup/User 2018-06-02 21:31:59.705 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/User. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:31:59.735 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 30ms. http://71.45.99.229:8096/emby/Startup/User 2018-06-02 21:32:00.252 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:00.281 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 29ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 21:32:02.535 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/cultures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:02.550 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 15ms. http://71.45.99.229:8096/emby/Localization/cultures 2018-06-02 21:32:02.551 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/countries. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:02.559 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 8ms. http://71.45.99.229:8096/emby/Localization/countries 2018-06-02 21:32:02.703 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:02.712 Error HttpServer: Access token is invalid or expired. 2018-06-02 21:32:02.712 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 9ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 21:32:02.758 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:02.759 Error HttpServer: Access token is invalid or expired. 2018-06-02 21:32:02.759 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 21:32:14.058 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:14.059 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 21:32:14.064 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/countries. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:14.064 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/cultures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:14.065 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Localization/cultures 2018-06-02 21:32:14.066 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Localization/countries 2018-06-02 21:32:15.774 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:15.776 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 21:32:15.854 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:15.855 Info ServerConfigurationManager: Saving system configuration 2018-06-02 21:32:15.856 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Startup/Configuration 2018-06-02 21:32:15.971 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Startup/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:15.978 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 7ms. http://71.45.99.229:8096/emby/Startup/Info 2018-06-02 21:32:17.707 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/RemoteAccess. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:17.710 Info ServerConfigurationManager: Saving system configuration 2018-06-02 21:32:17.710 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/Startup/RemoteAccess 2018-06-02 21:32:21.191 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/amazon.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:21.191 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/clients/amazon.png 2018-06-02 21:32:21.198 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/playstore.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:21.198 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/web/css/images/clients/playstore.png 2018-06-02 21:32:21.205 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/ios.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:21.205 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/clients/ios.png 2018-06-02 21:32:21.210 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/roku.jpg. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:21.210 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/web/css/images/clients/roku.jpg 2018-06-02 21:32:21.217 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/windowsphone.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:21.217 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/clients/windowsphone.png 2018-06-02 21:32:21.229 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/windowsrt.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:21.230 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/clients/windowsrt.png 2018-06-02 21:32:21.240 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/mbc.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:21.241 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/web/css/images/clients/mbc.png 2018-06-02 21:32:21.253 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/clients/kodi.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:21.253 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/web/css/images/clients/kodi.png 2018-06-02 21:32:22.660 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Startup/Complete. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:22.663 Info ServerConfigurationManager: Saving system configuration 2018-06-02 21:32:22.664 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/Startup/Complete 2018-06-02 21:32:22.672 Info TaskManager: Queueing task RefreshMediaLibraryTask 2018-06-02 21:32:22.672 Info TaskManager: Executing Scan media library 2018-06-02 21:32:22.684 Info App: Validating media library 2018-06-02 21:32:22.744 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:22.744 Error HttpServer: Access token is invalid or expired. 2018-06-02 21:32:22.745 Info HttpServer: HTTP Response 401 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/ad68974553944d809029932a5e27692d 2018-06-02 21:32:22.837 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:22.838 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 21:32:23.000 Info TaskManager: Scan media library Completed after 0 minute(s) and 0 seconds 2018-06-02 21:32:23.001 Info TaskManager: ExecuteQueuedTasks 2018-06-02 21:32:23.016 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Branding/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:23.016 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/users/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:23.022 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 6ms. http://71.45.99.229:8096/emby/Branding/Configuration 2018-06-02 21:32:23.079 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 63ms. http://71.45.99.229:8096/emby/users/public 2018-06-02 21:32:23.133 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Users/authenticatebyname. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:23.174 Info UserManager: Authentication request for Mike has succeeded. 2018-06-02 21:32:23.176 Info SessionManager: Creating new access token for user f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:32:23.320 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 186ms. http://71.45.99.229:8096/emby/Users/authenticatebyname 2018-06-02 21:32:23.387 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:23.408 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:23.439 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 31ms. http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby 2018-06-02 21:32:23.447 Info HttpServer: WS ws://71.45.99.229:8096/embywebsocket?api_key=05ed981ba1f44dff9510ac7f03c92114&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:23.509 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 122ms. http://71.45.99.229:8096/emby/Sessions/Capabilities/Full 2018-06-02 21:32:23.515 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:23.517 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:32:23.602 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:23.603 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:32:24.206 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Notifications/f090af23bfe040a2b46c4cf9ffa67c6a/Summary. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:24.228 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 22ms. http://71.45.99.229:8096/emby/Notifications/f090af23bfe040a2b46c4cf9ffa67c6a/Summary 2018-06-02 21:32:24.246 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:24.251 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:24.259 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 12ms. http://71.45.99.229:8096/emby/Sessions 2018-06-02 21:32:24.288 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:24.293 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 43ms. http://71.45.99.229:8096/emby/ScheduledTasks 2018-06-02 21:32:24.302 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:24.304 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-02T02%3A32%3A24.315Z. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:24.323 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=f090af23bfe040a2b46c4cf9ffa67c6a&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:24.326 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:24.328 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 26ms. http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4 2018-06-02 21:32:24.339 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 51ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:32:24.344 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 43ms. http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-02T02%3A32%3A24.315Z 2018-06-02 21:32:24.364 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 38ms. http://71.45.99.229:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true 2018-06-02 21:32:24.388 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:24.389 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 66ms. http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=f090af23bfe040a2b46c4cf9ffa67c6a&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2018-06-02 21:32:24.426 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 38ms. http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled 2018-06-02 21:32:24.499 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/logoblack.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:24.500 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/logoblack.png 2018-06-02 21:32:26.788 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:32:26.790 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:32:27.147 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:32:27.149 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:32:27.597 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:27.618 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 21ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:32:27.808 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:27.810 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:32:27.922 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:27.967 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 45ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:32:28.026 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:28.032 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:28.041 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:28.048 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 16ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:32:28.048 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 22ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:32:28.055 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 14ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:32:29.506 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:29.514 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 8ms. http://71.45.99.229:8096/emby/System/Endpoint 2018-06-02 21:32:29.583 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:29.685 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:29.779 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:29.798 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 214ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000 2018-06-02 21:32:31.249 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1564ms (slow). http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000 2018-06-02 21:32:32.931 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3153ms (slow). http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000 2018-06-02 21:32:33.155 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&Ids=2b2bca16aacc8a14d53a11bb829eafa5&MediaTypes=Audio%2CVideo&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:33.188 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 33ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&Ids=2b2bca16aacc8a14d53a11bb829eafa5&MediaTypes=Audio%2CVideo&EnableTotalRecordCount=false 2018-06-02 21:32:33.756 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:33.759 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Sessions 2018-06-02 21:32:33.809 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:33.811 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/ScheduledTasks 2018-06-02 21:32:33.823 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:33.824 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:32:33.831 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:33.833 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4 2018-06-02 21:32:33.843 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-02T02%3A32%3A33.789Z. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:33.845 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-02T02%3A32%3A33.789Z 2018-06-02 21:32:33.853 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=f090af23bfe040a2b46c4cf9ffa67c6a&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:33.854 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=f090af23bfe040a2b46c4cf9ffa67c6a&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2018-06-02 21:32:33.860 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:33.860 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true 2018-06-02 21:32:33.888 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:33.923 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 36ms. http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled 2018-06-02 21:32:36.663 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Devices?SupportsPersistentIdentifier=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:36.680 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 17ms. http://71.45.99.229:8096/emby/Devices?SupportsPersistentIdentifier=true 2018-06-02 21:32:39.078 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:39.116 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 37ms. http://71.45.99.229:8096/emby/System/Configuration 2018-06-02 21:32:41.118 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:41.118 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/Options. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:41.120 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/System/Configuration 2018-06-02 21:32:41.120 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Localization/Options 2018-06-02 21:32:41.129 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Configuration/branding. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:41.130 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:41.131 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:32:41.132 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/System/Configuration/branding 2018-06-02 21:32:44.125 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:44.127 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:32:44.192 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:44.194 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:32:44.330 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:44.333 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:32:44.570 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:44.573 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:44.574 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:32:44.576 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:32:44.576 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:44.579 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:32:48.763 Info HttpServer: HTTP GET http://71.45.99.229:8096/. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:48.763 Info HttpServer: HTTP Response 302 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/ 2018-06-02 21:32:49.848 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993169871. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:49.848 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/strings/en-US.json?v=1527993169871. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:49.849 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993169871 2018-06-02 21:32:49.849 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/web/strings/en-US.json?v=1527993169871 2018-06-02 21:32:51.216 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:51.216 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 21:32:51.273 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:51.277 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:32:51.336 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:51.338 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Sessions/Capabilities/Full 2018-06-02 21:32:51.342 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:51.343 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby 2018-06-02 21:32:51.344 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:51.345 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:32:51.404 Info HttpServer: WS ws://71.45.99.229:8096/embywebsocket?api_key=05ed981ba1f44dff9510ac7f03c92114&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:51.850 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:51.852 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:32:51.915 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:51.916 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2018-06-02 21:32:52.247 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:52.249 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:32:52.331 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:52.333 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:32:52.420 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:52.424 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:32:52.426 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:52.429 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:32:52.433 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:52.434 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:32:57.364 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:57.365 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/System/Endpoint 2018-06-02 21:32:57.435 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:57.508 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:57.590 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:57.737 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 302ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000 2018-06-02 21:32:58.491 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 983ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000 2018-06-02 21:32:58.940 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:58.942 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:32:59.153 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:59.156 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:32:59.360 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:59.362 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:32:59.367 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:59.370 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:32:59.375 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:32:59.377 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:32:59.494 Info HttpServer: HTTP Response 500 to 97.85.21.21. Time: 1904ms (slow). http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000 2018-06-02 21:33:08.248 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Sync/Jobs?UserId=f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:08.301 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 53ms. http://71.45.99.229:8096/emby/Sync/Jobs?UserId=f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:33:15.259 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:15.260 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:33:15.344 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:15.345 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:33:15.396 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:15.399 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:33:15.403 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:15.405 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:33:15.405 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:15.407 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:33:22.807 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/strings/en-US.json?v=1527993202846. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:22.808 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/strings/en-US.json?v=1527993202846 2018-06-02 21:33:22.819 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993202846. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:22.820 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993202846 2018-06-02 21:33:23.887 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:23.889 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 21:33:23.957 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:23.960 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:33:24.014 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:24.015 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Sessions/Capabilities/Full 2018-06-02 21:33:24.032 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:24.033 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby 2018-06-02 21:33:24.035 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:24.036 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:33:24.070 Info HttpServer: WS ws://71.45.99.229:8096/embywebsocket?api_key=05ed981ba1f44dff9510ac7f03c92114&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:24.091 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:24.093 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:33:24.473 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:24.475 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:33:24.491 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:24.491 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2018-06-02 21:33:24.889 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:24.891 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. Edited June 3, 2018 by mike689
mike689 0 Posted June 3, 2018 Author Posted June 3, 2018 Lg pt 2 of 3 http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:33:24.951 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:24.953 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:33:25.051 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:25.053 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:33:25.057 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:25.060 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:33:25.061 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:25.062 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:33:26.778 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:33:26.780 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:33:26.999 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:33:27.000 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:33:30.030 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:30.031 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Endpoint 2018-06-02 21:33:30.100 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:30.177 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:30.235 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:30.417 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 317ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000 2018-06-02 21:33:30.806 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 630ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000 2018-06-02 21:33:32.535 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2300ms (slow). http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000 2018-06-02 21:33:33.886 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/strings/en-US.json?v=1527993213917. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:33.888 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/strings/en-US.json?v=1527993213917 2018-06-02 21:33:33.894 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993213917. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:33.895 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993213917 2018-06-02 21:33:35.155 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:35.157 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 21:33:35.269 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:35.272 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:33:35.358 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:35.361 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Sessions/Capabilities/Full 2018-06-02 21:33:35.363 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:35.363 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:35.364 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:33:35.364 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby 2018-06-02 21:33:35.403 Info HttpServer: WS ws://71.45.99.229:8096/embywebsocket?api_key=05ed981ba1f44dff9510ac7f03c92114&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:35.442 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:35.444 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:33:35.786 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:35.788 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:33:35.885 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:35.886 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2018-06-02 21:33:36.280 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:36.282 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:33:36.349 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:36.351 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:33:36.422 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:36.424 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:33:36.427 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:36.428 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:36.430 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:33:36.431 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:33:41.395 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:41.397 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Endpoint 2018-06-02 21:33:41.566 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:41.645 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:41.720 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 155ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000 2018-06-02 21:33:41.758 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:33:43.384 Info HttpServer: HTTP Response 500 to 97.85.21.21. Time: 1625ms (slow). http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000 2018-06-02 21:33:43.394 Info HttpServer: HTTP Response 500 to 97.85.21.21. Time: 1749ms (slow). http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000 2018-06-02 21:34:26.768 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:34:26.770 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 2ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:34:26.872 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:34:26.874 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:34:26.979 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:34:26.980 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:34:50.384 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/strings/en-US.json?v=1527993290387. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:50.385 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/strings/en-US.json?v=1527993290387 2018-06-02 21:34:50.391 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993290387. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:50.392 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993290387 2018-06-02 21:34:51.513 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:51.515 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 21:34:51.626 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:51.632 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 6ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:34:51.699 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:51.701 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:51.702 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Sessions/Capabilities/Full 2018-06-02 21:34:51.702 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:34:51.709 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:51.710 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby 2018-06-02 21:34:51.743 Info HttpServer: WS ws://71.45.99.229:8096/embywebsocket?api_key=05ed981ba1f44dff9510ac7f03c92114&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:52.163 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:52.164 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:34:52.218 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:52.219 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2018-06-02 21:34:52.577 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:52.579 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:34:52.660 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:52.662 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:34:52.745 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:52.748 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:34:52.749 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:52.749 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:52.751 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:34:52.751 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:34:58.363 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:58.364 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Endpoint 2018-06-02 21:34:58.425 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:58.427 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000 2018-06-02 21:34:58.498 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:58.562 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:34:59.137 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 639ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000 2018-06-02 21:34:59.754 Info HttpServer: HTTP Response 500 to 97.85.21.21. Time: 1192ms (slow). http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000 2018-06-02 21:35:26.766 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:35:26.768 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 2ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:35:26.960 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:35:26.961 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:35:27.008 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:35:27.010 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:35:51.196 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Notifications/f090af23bfe040a2b46c4cf9ffa67c6a/Summary. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:51.197 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Notifications/f090af23bfe040a2b46c4cf9ffa67c6a/Summary 2018-06-02 21:35:51.236 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:51.238 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Sessions 2018-06-02 21:35:51.243 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:51.244 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/ScheduledTasks 2018-06-02 21:35:51.248 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:51.249 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:35:51.253 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:51.255 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4 2018-06-02 21:35:51.275 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-02T02%3A35%3A51.282Z. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:51.276 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-02T02%3A35%3A51.282Z 2018-06-02 21:35:51.284 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=f090af23bfe040a2b46c4cf9ffa67c6a&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:51.286 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=f090af23bfe040a2b46c4cf9ffa67c6a&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2018-06-02 21:35:51.290 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:51.290 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 0ms. http://71.45.99.229:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true 2018-06-02 21:35:51.355 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:51.356 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2018-06-02 21:35:51.466 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/logoblack.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:51.467 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/logoblack.png 2018-06-02 21:35:51.589 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 233ms. http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled 2018-06-02 21:35:58.875 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:58.879 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 21:35:58.883 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:35:58.885 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/ScheduledTasks?IsEnabled=true 2018-06-02 21:36:01.708 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/cultures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:01.709 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/countries. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:01.711 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Localization/cultures 2018-06-02 21:36:01.711 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Localization/countries 2018-06-02 21:36:01.886 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:01.990 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 103ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 21:36:02.062 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:02.067 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 5ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 21:36:04.700 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?LibraryContentType=movies&IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:04.710 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 9ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?LibraryContentType=movies&IsNewLibrary=true 2018-06-02 21:36:07.646 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info/Public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:07.647 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Info/Public 2018-06-02 21:36:07.652 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:07.657 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 5ms. http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser 2018-06-02 21:36:07.742 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/Drives. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:07.765 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 23ms. http://71.45.99.229:8096/emby/Environment/Drives 2018-06-02 21:36:12.360 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Fmovies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:12.366 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Fmovies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:12.368 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 8ms. http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Fmovies 2018-06-02 21:36:12.369 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Fmovies 2018-06-02 21:36:14.148 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Environment/ValidatePath. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:14.155 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 7ms. http://71.45.99.229:8096/emby/Environment/ValidatePath 2018-06-02 21:36:26.779 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:36:26.781 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:36:26.904 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:36:26.905 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:36:26.999 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:36:27.001 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:36:29.897 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Library/VirtualFolders?collectionType=movies&refreshLibrary=true&name=Movies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:30.098 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 202ms. http://71.45.99.229:8096/emby/Library/VirtualFolders?collectionType=movies&refreshLibrary=true&name=Movies 2018-06-02 21:36:30.099 Info TaskManager: Queueing task RefreshMediaLibraryTask 2018-06-02 21:36:30.099 Info TaskManager: Executing Scan media library 2018-06-02 21:36:30.115 Info App: Validating media library 2018-06-02 21:36:30.465 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:30.482 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 17ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 21:36:30.635 Info HttpClient: GET https://api.themoviedb.org/3/configuration?api_key=f6bd687ffa63cd282b6ff2c6877f2669 2018-06-02 21:36:30.823 Info App: MovieDbProvider: Finding id for item: 12.Strong 2018-06-02 21:36:30.934 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=12.Strong&language=en 2018-06-02 21:36:31.233 Info HttpClient: GET https://api.themoviedb.org/3/movie/429351?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:31.477 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1413492&plot=short&tomatoes=true&r=json 2018-06-02 21:36:31.664 Info HttpClient: GET https://api.themoviedb.org/3/movie/429351?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:31.797 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/429351?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:32.611 Info App: MovieDbProvider: Finding id for item: A.Wrinkle.in.Time 2018-06-02 21:36:32.611 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=A.Wrinkle.in.Time&language=en 2018-06-02 21:36:32.911 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=A+Wrinkle+in+Time&language=en 2018-06-02 21:36:33.211 Info HttpClient: GET https://api.themoviedb.org/3/movie/407451?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:33.269 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1620680&plot=short&tomatoes=true&r=json 2018-06-02 21:36:33.511 Info HttpClient: GET https://api.themoviedb.org/3/movie/407451?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:33.573 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/407451?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:33.995 Info App: MovieDbProvider: Finding id for item: Animal.House 2018-06-02 21:36:33.995 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Animal.House&language=en 2018-06-02 21:36:34.296 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Animal+House&language=en 2018-06-02 21:36:34.595 Info HttpClient: GET https://api.themoviedb.org/3/movie/8469?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:34.790 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt0077975&plot=short&tomatoes=true&r=json 2018-06-02 21:36:34.895 Info HttpClient: GET https://api.themoviedb.org/3/movie/8469?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:34.973 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/8469?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:35.433 Info App: MovieDbProvider: Finding id for item: Batman.Ninja 2018-06-02 21:36:35.433 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Batman.Ninja&language=en 2018-06-02 21:36:35.734 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Batman+Ninja&language=en 2018-06-02 21:36:36.038 Info HttpClient: GET https://api.themoviedb.org/3/movie/485942?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:36.110 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt7451284&plot=short&tomatoes=true&r=json 2018-06-02 21:36:36.338 Info HttpClient: GET https://api.themoviedb.org/3/movie/485942?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:36.427 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/485942?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:36.741 Info App: MovieDbProvider: Finding id for item: Black.Panther 2018-06-02 21:36:36.741 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Black.Panther&language=en 2018-06-02 21:36:36.954 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.044 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Black+Panther&language=en 2018-06-02 21:36:37.083 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 129ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:36:37.174 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.176 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:36:37.270 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.272 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:36:37.338 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.340 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:36:37.343 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.344 Info HttpClient: GET https://api.themoviedb.org/3/movie/284054?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:37.346 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:36:37.353 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.355 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.356 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:36:37.409 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 53ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2018-06-02 21:36:37.461 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1825683&plot=short&tomatoes=true&r=json 2018-06-02 21:36:37.492 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/eec4329023077cd9894b6974789ca64a/Images/Primary?maxHeight=636&maxWidth=424&tag=7975726f92929455968e9febf9f72c16&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.500 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/cf236a33415d2f0ffc720f458c30fa9f/Images/Primary?maxHeight=636&maxWidth=424&tag=640700975039dd042ca8eccd042bc7b8&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.504 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/b6489085d7c7262c5ce40fccff2d60d5/Images/Primary?maxHeight=636&maxWidth=424&tag=0a216cc0458096a7584236d6812a5d4a&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.505 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/be5e79466edaf5febee47760b07b1dbe/Images/Primary?maxHeight=636&maxWidth=424&tag=ac04ff0996f552a7805471415fc92022&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:37.544 Info HttpClient: GET https://image.tmdb.org/t/p/original/kZIrg87DiU1xKqCNcEV6LMfj3pS.jpg 2018-06-02 21:36:37.544 Info HttpClient: GET https://image.tmdb.org/t/p/original/j18021qCeRi3yUBtqd2UFj1c0RQ.jpg 2018-06-02 21:36:37.544 Info HttpClient: GET https://image.tmdb.org/t/p/original/fWooBbipMRIKeSRhEzmeaDV0T8H.jpg 2018-06-02 21:36:37.545 Info HttpClient: GET https://image.tmdb.org/t/p/original/yAcb58vipewa1BfNit2RjE6boXA.jpg 2018-06-02 21:36:37.644 Info HttpClient: GET https://api.themoviedb.org/3/movie/284054?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:37.766 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/284054?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:38.141 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 637ms. http://71.45.99.229:8096/emby/Items/b6489085d7c7262c5ce40fccff2d60d5/Images/Primary?maxHeight=636&maxWidth=424&tag=0a216cc0458096a7584236d6812a5d4a&quality=90 2018-06-02 21:36:38.142 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 649ms. http://71.45.99.229:8096/emby/Items/eec4329023077cd9894b6974789ca64a/Images/Primary?maxHeight=636&maxWidth=424&tag=7975726f92929455968e9febf9f72c16&quality=90 2018-06-02 21:36:38.147 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 647ms. http://71.45.99.229:8096/emby/Items/cf236a33415d2f0ffc720f458c30fa9f/Images/Primary?maxHeight=636&maxWidth=424&tag=640700975039dd042ca8eccd042bc7b8&quality=90 2018-06-02 21:36:38.229 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 724ms. http://71.45.99.229:8096/emby/Items/be5e79466edaf5febee47760b07b1dbe/Images/Primary?maxHeight=636&maxWidth=424&tag=ac04ff0996f552a7805471415fc92022&quality=90 2018-06-02 21:36:38.655 Info App: MovieDbProvider: Finding id for item: Dear.Dictator 2018-06-02 21:36:38.655 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Dear.Dictator&language=en 2018-06-02 21:36:38.955 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Dear+Dictator&language=en 2018-06-02 21:36:39.258 Info HttpClient: GET https://api.themoviedb.org/3/movie/418667?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:39.409 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt5779540&plot=short&tomatoes=true&r=json 2018-06-02 21:36:39.558 Info HttpClient: GET https://api.themoviedb.org/3/movie/418667?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:39.616 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/418667?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:40.006 Info App: MovieDbProvider: Finding id for item: den.of.thieves 2018-06-02 21:36:40.006 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=den.of.thieves&language=en 2018-06-02 21:36:40.306 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=den+of+thieves&language=en 2018-06-02 21:36:40.621 Info HttpClient: GET https://api.themoviedb.org/3/movie/449443?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:40.798 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1259528&plot=short&tomatoes=true&r=json 2018-06-02 21:36:40.921 Info HttpClient: GET https://api.themoviedb.org/3/movie/449443?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:41.004 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/449443?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:41.279 Info App: MovieDbProvider: Finding id for item: Future.World 2018-06-02 21:36:41.279 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Future.World&language=en 2018-06-02 21:36:41.578 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Future+World&language=en 2018-06-02 21:36:41.878 Info HttpClient: GET https://api.themoviedb.org/3/movie/411135?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:41.940 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt5737536&plot=short&tomatoes=true&r=json 2018-06-02 21:36:42.178 Info HttpClient: GET https://api.themoviedb.org/3/movie/411135?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:42.238 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/411135?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:42.593 Info App: MovieDbProvider: Finding id for item: Game.Night 2018-06-02 21:36:42.593 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Game.Night&language=en 2018-06-02 21:36:42.895 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Game+Night&language=en 2018-06-02 21:36:43.195 Info HttpClient: GET https://api.themoviedb.org/3/movie/445571?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:43.311 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt2704998&plot=short&tomatoes=true&r=json 2018-06-02 21:36:43.495 Info HttpClient: GET https://api.themoviedb.org/3/movie/445571?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:43.559 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/445571?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:43.878 Info App: MovieDbProvider: Finding id for item: The.15.17.to.Paris 2018-06-02 21:36:43.878 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The.15.17.to.Paris&language=en 2018-06-02 21:36:44.178 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The+15+17+to+Paris&language=en 2018-06-02 21:36:44.478 Info HttpClient: GET https://api.themoviedb.org/3/movie/453201?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:44.587 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt6802308&plot=short&tomatoes=true&r=json 2018-06-02 21:36:44.778 Info HttpClient: GET https://api.themoviedb.org/3/movie/453201?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:44.836 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/453201?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:45.274 Info App: MovieDbProvider: Finding id for item: The.Greatest.Showman 2018-06-02 21:36:45.274 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The.Greatest.Showman&language=en 2018-06-02 21:36:45.574 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The+Greatest+Showman&language=en 2018-06-02 21:36:45.642 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/strings/en-US.json?v=1527993405678. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:45.643 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/strings/en-US.json?v=1527993405678 2018-06-02 21:36:45.652 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993405678. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:45.653 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993405678 2018-06-02 21:36:45.874 Info HttpClient: GET https://api.themoviedb.org/3/movie/316029?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:45.959 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1485796&plot=short&tomatoes=true&r=json 2018-06-02 21:36:46.174 Info HttpClient: GET https://api.themoviedb.org/3/movie/316029?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:46.314 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/316029?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:46.662 Info App: MovieDbProvider: Finding id for item: Wildling 2018-06-02 21:36:46.662 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Wildling&language=en 2018-06-02 21:36:46.671 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:46.672 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 21:36:46.763 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:46.769 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 6ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:36:46.839 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:46.842 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Sessions/Capabilities/Full 2018-06-02 21:36:46.844 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:46.845 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:36:46.858 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:46.859 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby 2018-06-02 21:36:46.901 Info HttpServer: WS ws://71.45.99.229:8096/embywebsocket?api_key=05ed981ba1f44dff9510ac7f03c92114&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:46.962 Info HttpClient: GET https://api.themoviedb.org/3/movie/362826?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:47.030 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt5085924&plot=short&tomatoes=true&r=json 2018-06-02 21:36:47.230 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.232 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:36:47.262 Info HttpClient: GET https://api.themoviedb.org/3/movie/362826?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:47.284 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.284 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2018-06-02 21:36:47.330 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/362826?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:47.621 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.622 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:36:47.695 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.701 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 5ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:36:47.701 Info App: MovieDbProvider: Finding id for item: Solo A Star Wars Story 2018-06-02 21:36:47.701 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Solo+A+Star+Wars+Story&language=en 2018-06-02 21:36:47.802 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.802 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.803 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.806 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.810 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 7ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:36:47.811 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 5ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:36:47.811 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 9ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:36:47.814 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 12ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2018-06-02 21:36:47.957 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/b6489085d7c7262c5ce40fccff2d60d5/Images/Primary?maxHeight=636&maxWidth=424&tag=ed3c332eef6a7da3b7d834740a959581&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.958 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Items/b6489085d7c7262c5ce40fccff2d60d5/Images/Primary?maxHeight=636&maxWidth=424&tag=ed3c332eef6a7da3b7d834740a959581&quality=90 2018-06-02 21:36:47.960 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/aabc51cf4e6b61668f61b4a91347e1b5/Images/Primary?maxHeight=636&maxWidth=424&tag=aed5bb9579b04ce5bd5a71e5d32ecf45&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.960 Info HttpClient: GET https://image.tmdb.org/t/p/original/qxJQ0VBCuJkJhJmuWzxI408ngwd.jpg 2018-06-02 21:36:47.962 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/ff501ac8db77da112ca03ce033b9fd9e/Images/Primary?maxHeight=636&maxWidth=424&tag=2418c66d3a741da16ce88aedbb6579ef&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.963 Info HttpClient: GET https://image.tmdb.org/t/p/original/uxzzxijgPIY7slzFvMotPv8wjKA.jpg 2018-06-02 21:36:47.965 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/b14fd96419081f5b9b78d879839074bf/Images/Primary?maxHeight=636&maxWidth=424&tag=399b920c8611bfe9350b397551e29d51&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.965 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/66ad8a997cd270f6f3400b15e3f9655c/Images/Primary?maxHeight=636&maxWidth=424&tag=1169a776ee1b937784d698e58c2d30b0&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.965 Info HttpClient: GET https://image.tmdb.org/t/p/original/85R8LMyn9f2Lev2YPBF8Nughrkv.jpg 2018-06-02 21:36:47.965 Info HttpClient: GET https://image.tmdb.org/t/p/original/kMA0IalnEEa0PaHRUzzjpTu5xXQ.jpg 2018-06-02 21:36:47.971 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/be5e79466edaf5febee47760b07b1dbe/Images/Primary?maxHeight=636&maxWidth=424&tag=87eedb78f5097a130c408a472c724611&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:47.972 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Items/be5e79466edaf5febee47760b07b1dbe/Images/Primary?maxHeight=636&maxWidth=424&tag=87eedb78f5097a130c408a472c724611&quality=90 2018-06-02 21:36:48.002 Info HttpClient: GET https://api.themoviedb.org/3/movie/348350?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:48.135 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt3778644&plot=short&tomatoes=true&r=json 2018-06-02 21:36:48.150 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 190ms. http://71.45.99.229:8096/emby/Items/aabc51cf4e6b61668f61b4a91347e1b5/Images/Primary?maxHeight=636&maxWidth=424&tag=aed5bb9579b04ce5bd5a71e5d32ecf45&quality=90 2018-06-02 21:36:48.302 Info HttpClient: GET https://api.themoviedb.org/3/movie/348350?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:48.380 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/348350?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:48.425 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 460ms. http://71.45.99.229:8096/emby/Items/66ad8a997cd270f6f3400b15e3f9655c/Images/Primary?maxHeight=636&maxWidth=424&tag=1169a776ee1b937784d698e58c2d30b0&quality=90 2018-06-02 21:36:48.433 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 471ms. http://71.45.99.229:8096/emby/Items/ff501ac8db77da112ca03ce033b9fd9e/Images/Primary?maxHeight=636&maxWidth=424&tag=2418c66d3a741da16ce88aedbb6579ef&quality=90 2018-06-02 21:36:48.465 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 500ms. http://71.45.99.229:8096/emby/Items/b14fd96419081f5b9b78d879839074bf/Images/Primary?maxHeight=636&maxWidth=424&tag=399b920c8611bfe9350b397551e29d51&quality=90 2018-06-02 21:36:48.873 Info App: MovieDbProvider: Finding id for item: The Greatest Showman 2018-06-02 21:36:48.873 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The+Greatest+Showman&language=en 2018-06-02 21:36:49.025 Error App: Error in ffprobe *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Exception: ffprobe failed for file:"/mnt/HDD/complete/movies/Annihilation (2018)/Annihilation.2018.1080p.BluRay.x264.Atmos.TrueHD7.1-HDChina.mkv" - streams and format are both null. at Emby.Server.MediaEncoding.Encoder.MediaEncoder.<GetMediaInfoInternal>d__62.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo.<ProbeVideo>d__16`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<RunCustomProvider>d__40.MoveNext() System.Exception at Emby.Server.MediaEncoding.Encoder.MediaEncoder.<GetMediaInfoInternal>d__62.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo.<ProbeVideo>d__16`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<RunCustomProvider>d__40.MoveNext() 2018-06-02 21:36:49.025 Info App: MovieDbProvider: Finding id for item: Annihilation 2018-06-02 21:36:49.173 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Annihilation&language=en 2018-06-02 21:36:49.473 Info HttpClient: GET https://api.themoviedb.org/3/movie/300668?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:49.564 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt2798920&plot=short&tomatoes=true&r=json 2018-06-02 21:36:49.772 Info HttpClient: GET https://api.themoviedb.org/3/movie/300668?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:49.845 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/300668?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:50.137 Info App: MovieDbProvider: Finding id for item: Father Figures 2018-06-02 21:36:50.138 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Father+Figures&language=en 2018-06-02 21:36:50.437 Info HttpClient: GET https://api.themoviedb.org/3/movie/354861?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:50.511 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1966359&plot=short&tomatoes=true&r=json 2018-06-02 21:36:50.737 Info HttpClient: GET https://api.themoviedb.org/3/movie/354861?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:50.800 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/354861?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:51.271 Info App: MovieDbProvider: Finding id for item: Gringo 2018-06-02 21:36:51.271 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Gringo&language=en 2018-06-02 21:36:51.570 Info HttpClient: GET https://api.themoviedb.org/3/movie/340022?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:51.646 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt3721964&plot=short&tomatoes=true&r=json 2018-06-02 21:36:51.870 Info HttpClient: GET https://api.themoviedb.org/3/movie/340022?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:51.938 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/340022?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:52.243 Info App: MovieDbProvider: Finding id for item: Game Night 2018-06-02 21:36:52.243 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Game+Night&language=en 2018-06-02 21:36:52.409 Error App: Error in ffprobe *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Exception: ffprobe failed for file:"/mnt/HDD/complete/movies/The 1517 to Paris (2018)/The.15.17.to.Paris.2018.1080p.BluRay.REMUX.AVC.Atmos-EPSiLON.mkv" - streams and format are both null. at Emby.Server.MediaEncoding.Encoder.MediaEncoder.<GetMediaInfoInternal>d__62.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo.<ProbeVideo>d__16`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<RunCustomProvider>d__40.MoveNext() System.Exception at Emby.Server.MediaEncoding.Encoder.MediaEncoder.<GetMediaInfoInternal>d__62.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo.<ProbeVideo>d__16`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<RunCustomProvider>d__40.MoveNext() 2018-06-02 21:36:52.409 Info App: MovieDbProvider: Finding id for item: The 1517 to Paris 2018-06-02 21:36:52.543 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The+1517+to+Paris&language=en 2018-06-02 21:36:52.601 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2018&t=The+1517+to+Paris&type=movie 2018-06-02 21:36:52.725 Info App: Skipping image extraction due to missing DefaultVideoStreamIndex for /mnt/HDD/complete/movies/The 1517 to Paris (2018)/The.15.17.to.Paris.2018.1080p.BluRay.REMUX.AVC.Atmos-EPSiLON.mkv. 2018-06-02 21:36:52.814 Info App: MovieDbProvider: Finding id for item: Terminal 2018-06-02 21:36:52.846 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Terminal&language=en 2018-06-02 21:36:52.848 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:52.850 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/System/Endpoint 2018-06-02 21:36:52.930 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:52.985 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:53.044 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:53.146 Info HttpClient: GET https://api.themoviedb.org/3/movie/385332?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2018-06-02 21:36:53.230 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt4463816&plot=short&tomatoes=true&r=json 2018-06-02 21:36:53.446 Info HttpClient: GET https://api.themoviedb.org/3/movie/385332?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers 2018-06-02 21:36:53.613 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 627ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000 2018-06-02 21:36:53.629 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/385332?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2018-06-02 21:36:53.851 Info HttpServer: HTTP Response 500 to 97.85.21.21. Time: 807ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000 2018-06-02 21:36:53.855 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/49d00e377f2a4791be14caf704b8ec13.png 2018-06-02 21:36:53.890 Info HttpServer: HTTP Response 500 to 97.85.21.21. Time: 960ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000 2018-06-02 21:36:54.479 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/49d00e377f2a4791be14caf704b8ec13.png 2018-06-02 21:36:54.491 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/92b8d083c6f24e3bbe2ad0192a2c311a.png 2018-06-02 21:36:54.615 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/strings/en-US.json?v=1527993414644. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:54.616 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/strings/en-US.json?v=1527993414644 2018-06-02 21:36:54.623 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993414644. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:54.623 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1527993414644 2018-06-02 21:36:55.276 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/92b8d083c6f24e3bbe2ad0192a2c311a.png 2018-06-02 21:36:55.282 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/aea4892db55c4f41910d6f05e30b9751.png 2018-06-02 21:36:55.610 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/aea4892db55c4f41910d6f05e30b9751.png 2018-06-02 21:36:55.615 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/d0c43121e8064645b33218f48c76cf57.png 2018-06-02 21:36:55.734 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:55.735 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/system/info/public 2018-06-02 21:36:55.796 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:55.798 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:36:55.806 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/d0c43121e8064645b33218f48c76cf57.png 2018-06-02 21:36:55.811 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/e0a2259833d74ae3812ab619b5577667.png 2018-06-02 21:36:55.854 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:55.854 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:55.854 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:55.856 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/DisplayPreferences/usersettings?userId=f090af23bfe040a2b46c4cf9ffa67c6a&client=emby 2018-06-02 21:36:55.857 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:36:55.857 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Sessions/Capabilities/Full 2018-06-02 21:36:55.908 Info HttpServer: WS ws://71.45.99.229:8096/embywebsocket?api_key=05ed981ba1f44dff9510ac7f03c92114&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY2LjAuMzM1OS4xODEgU2FmYXJpLzUzNy4zNnwxNTI3OTgzMjk1NDA5. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:56.276 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:56.278 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:36:56.347 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:56.348 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2018-06-02 21:36:56.578 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/e0a2259833d74ae3812ab619b5577667.png 2018-06-02 21:36:56.588 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/208123abc5504919bf52824f283903fd.png 2018-06-02 21:36:56.697 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:56.699 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:36:56.790 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:56.791 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:36:56.868 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:56.870 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:36:56.872 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:56.873 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:36:56.878 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:56.878 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:56.883 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 5ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:36:56.886 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 8ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2018-06-02 21:36:57.034 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/5aacac5fd88c05a3fc72b6e3473276f6/Images/Primary?maxHeight=636&maxWidth=424&tag=ff6bff6237301a2ab7031d39d3997798&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:57.035 Info HttpClient: GET https://image.tmdb.org/t/p/original/xi7pA3lL6Wb78p6Y6PgWoHDMjrM.jpg 2018-06-02 21:36:57.041 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/46813be28992602e5108b9e140426f10/Images/Primary?maxHeight=636&maxWidth=424&tag=061fa1338ff1757bbe8941294afd58e4&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:57.041 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/ba3253d745af2d717113b3cd56557896/Images/Primary?maxHeight=636&maxWidth=424&tag=c32223cfc5bbdd06814c8ef211cb8b74&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:57.041 Info HttpClient: GET https://image.tmdb.org/t/p/original/4oD6VEccFkorEBTEDXtpLAaz0Rl.jpg 2018-06-02 21:36:57.041 Info HttpClient: GET https://image.tmdb.org/t/p/original/e3P2Ed0sbmQ6RsoS4dcT3aeEPR.jpg 2018-06-02 21:36:57.044 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/dce3cf33a964ff813ea17068cc1291b3/Images/Primary?maxHeight=636&maxWidth=424&tag=e954da73225e2c13cc1fdd0a74652ee7&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:57.045 Info HttpClient: GET https://image.tmdb.org/t/p/original/dxeVPklFwng2IowqRPNI4od6aXv.jpg 2018-06-02 21:36:57.057 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/66ad8a997cd270f6f3400b15e3f9655c/Images/Primary?maxHeight=636&maxWidth=424&tag=37ebee3dc9b6d6480dfaae041b009789&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:36:57.058 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Items/66ad8a997cd270f6f3400b15e3f9655c/Images/Primary?maxHeight=636&maxWidth=424&tag=37ebee3dc9b6d6480dfaae041b009789&quality=90 2018-06-02 21:36:57.242 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/208123abc5504919bf52824f283903fd.png 2018-06-02 21:36:57.250 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/23d4d14d4a4d494e8e27296cd7c8f7cf.png 2018-06-02 21:36:57.299 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 258ms. http://71.45.99.229:8096/emby/Items/46813be28992602e5108b9e140426f10/Images/Primary?maxHeight=636&maxWidth=424&tag=061fa1338ff1757bbe8941294afd58e4&quality=90 2018-06-02 21:36:57.497 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 463ms. http://71.45.99.229:8096/emby/Items/5aacac5fd88c05a3fc72b6e3473276f6/Images/Primary?maxHeight=636&maxWidth=424&tag=ff6bff6237301a2ab7031d39d3997798&quality=90 2018-06-02 21:36:57.548 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 507ms. http://71.45.99.229:8096/emby/Items/ba3253d745af2d717113b3cd56557896/Images/Primary?maxHeight=636&maxWidth=424&tag=c32223cfc5bbdd06814c8ef211cb8b74&quality=90 2018-06-02 21:36:57.726 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 682ms.
mike689 0 Posted June 3, 2018 Author Posted June 3, 2018 Log Pt 3 of 3 http://71.45.99.229:8096/emby/Items/dce3cf33a964ff813ea17068cc1291b3/Images/Primary?maxHeight=636&maxWidth=424&tag=e954da73225e2c13cc1fdd0a74652ee7&quality=90 2018-06-02 21:36:58.068 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/23d4d14d4a4d494e8e27296cd7c8f7cf.png 2018-06-02 21:36:58.074 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/27d3f215843a4fde91d1605ddbfe3254.png 2018-06-02 21:36:58.864 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/27d3f215843a4fde91d1605ddbfe3254.png 2018-06-02 21:36:58.871 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/464b647e877648e1a72f593055d88c5d.png 2018-06-02 21:36:59.323 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/464b647e877648e1a72f593055d88c5d.png 2018-06-02 21:36:59.334 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/edf887b54c42485fb48ddcf8efd35598.png 2018-06-02 21:36:59.863 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/edf887b54c42485fb48ddcf8efd35598.png 2018-06-02 21:36:59.868 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/083a75a2587d447f93f6b4731d383895.png 2018-06-02 21:37:00.510 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/083a75a2587d447f93f6b4731d383895.png 2018-06-02 21:37:00.519 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/7ce30153621b4b5e921906f562f1a74b.png 2018-06-02 21:37:00.833 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/7ce30153621b4b5e921906f562f1a74b.png 2018-06-02 21:37:00.837 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/04c720ef287240838665de236e792bbb.png 2018-06-02 21:37:01.435 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/04c720ef287240838665de236e792bbb.png 2018-06-02 21:37:01.722 Info TaskManager: Scan media library Completed after 0 minute(s) and 31 seconds 2018-06-02 21:37:01.723 Info ServerManager: Sending web socket message ScheduledTaskEnded 2018-06-02 21:37:01.728 Info LibraryMonitor: Watching directory /mnt/HDD/complete/movies 2018-06-02 21:37:01.729 Info TaskManager: ExecuteQueuedTasks 2018-06-02 21:37:02.444 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:02.447 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/System/Endpoint 2018-06-02 21:37:02.569 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&Ids=a9c5d6c123a328647455d75be31863f0%2Cf137a2dd21bbc1b99aa5c0f6bf02a805%2Cb6489085d7c7262c5ce40fccff2d60d5%2Cbe5e79466edaf5febee47760b07b1dbe%2Ceec4329023077cd9894b6974789ca64a%2Ccf236a33415d2f0ffc720f458c30fa9f%2Cff501ac8db77da112ca03ce033b9fd9e%2Ca7435a48176c5d8acfe6484625766029%2C646fd412b8fb28d9d862e77b82b6f2fd%2C66ad8a997cd270f6f3400b15e3f9655c%2Cb14fd96419081f5b9b78d879839074bf%2Caabc51cf4e6b61668f61b4a91347e1b5&MediaTypes=Audio%2CVideo&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:02.572 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&Ids=a9c5d6c123a328647455d75be31863f0%2Cf137a2dd21bbc1b99aa5c0f6bf02a805%2Cb6489085d7c7262c5ce40fccff2d60d5%2Cbe5e79466edaf5febee47760b07b1dbe%2Ceec4329023077cd9894b6974789ca64a%2Ccf236a33415d2f0ffc720f458c30fa9f%2Cff501ac8db77da112ca03ce033b9fd9e%2Ca7435a48176c5d8acfe6484625766029%2C646fd412b8fb28d9d862e77b82b6f2fd%2C66ad8a997cd270f6f3400b15e3f9655c%2Cb14fd96419081f5b9b78d879839074bf%2Caabc51cf4e6b61668f61b4a91347e1b5&MediaTypes=Audio%2CVideo&EnableTotalRecordCount=false 2018-06-02 21:37:02.649 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/b14fd96419081f5b9b78d879839074bf/Images/Primary?maxHeight=636&maxWidth=424&tag=24b0760521d8337554efd65dad6f1748&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:02.650 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Items/b14fd96419081f5b9b78d879839074bf/Images/Primary?maxHeight=636&maxWidth=424&tag=24b0760521d8337554efd65dad6f1748&quality=90 2018-06-02 21:37:02.658 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/aabc51cf4e6b61668f61b4a91347e1b5/Images/Primary?maxHeight=636&maxWidth=424&tag=887fa5f5709a0c62df90788b60905620&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:02.659 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Items/aabc51cf4e6b61668f61b4a91347e1b5/Images/Primary?maxHeight=636&maxWidth=424&tag=887fa5f5709a0c62df90788b60905620&quality=90 2018-06-02 21:37:02.689 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/ff501ac8db77da112ca03ce033b9fd9e/Images/Primary?maxHeight=636&maxWidth=424&tag=a5c50374ee25f5664be74e38d7786307&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:02.690 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Items/ff501ac8db77da112ca03ce033b9fd9e/Images/Primary?maxHeight=636&maxWidth=424&tag=a5c50374ee25f5664be74e38d7786307&quality=90 2018-06-02 21:37:02.788 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/cf236a33415d2f0ffc720f458c30fa9f/Images/Primary?maxHeight=636&maxWidth=424&tag=4960b8324c1162cb8a08f0a73aa5021a&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:02.790 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Items/cf236a33415d2f0ffc720f458c30fa9f/Images/Primary?maxHeight=636&maxWidth=424&tag=4960b8324c1162cb8a08f0a73aa5021a&quality=90 2018-06-02 21:37:02.796 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:02.843 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/a7435a48176c5d8acfe6484625766029/Images/Primary?maxHeight=636&maxWidth=424&tag=1b6215be551c7c213648d27e89207f38&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:02.844 Info HttpClient: GET https://image.tmdb.org/t/p/original/2YFCAAZUUpj66gLAMqRhwpY1U34.jpg 2018-06-02 21:37:02.867 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:02.963 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:03.079 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 236ms. http://71.45.99.229:8096/emby/Items/a7435a48176c5d8acfe6484625766029/Images/Primary?maxHeight=636&maxWidth=424&tag=1b6215be551c7c213648d27e89207f38&quality=90 2018-06-02 21:37:03.182 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 386ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=500000 2018-06-02 21:37:03.292 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 425ms. http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=1000000 2018-06-02 21:37:03.630 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/0f8cc66d5cd1a730fb20d62db499b5d7/Images/Primary?maxHeight=636&maxWidth=424&tag=399b920c8611bfe9350b397551e29d51&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:03.630 Info HttpClient: GET https://image.tmdb.org/t/p/original/85R8LMyn9f2Lev2YPBF8Nughrkv.jpg 2018-06-02 21:37:03.660 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/646fd412b8fb28d9d862e77b82b6f2fd/Images/Primary?maxHeight=636&maxWidth=424&tag=02579a5696b4ee3b20cf4fabd48142f5&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:03.660 Info HttpClient: GET https://image.tmdb.org/t/p/original/AfybH6GbGFw1F9bcETe2yu25mIE.jpg 2018-06-02 21:37:03.693 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/ae48409401c923f35ede159db3b511c9/Images/Primary?maxHeight=636&maxWidth=424&tag=c0a02950293f95a9460b31fe46531e3d&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:03.694 Info HttpClient: GET https://image.tmdb.org/t/p/original/wZQR6hKRUBqHRL4lfECFES68zGF.jpg 2018-06-02 21:37:03.996 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 365ms. http://71.45.99.229:8096/emby/Items/0f8cc66d5cd1a730fb20d62db499b5d7/Images/Primary?maxHeight=636&maxWidth=424&tag=399b920c8611bfe9350b397551e29d51&quality=90 2018-06-02 21:37:04.061 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 368ms. http://71.45.99.229:8096/emby/Items/ae48409401c923f35ede159db3b511c9/Images/Primary?maxHeight=636&maxWidth=424&tag=c0a02950293f95a9460b31fe46531e3d&quality=90 2018-06-02 21:37:04.116 Info HttpServer: HTTP Response 500 to 97.85.21.21. Time: 1154ms (slow). http://71.45.99.229:8096/emby/Playback/BitrateTest?Size=3000000 2018-06-02 21:37:04.160 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 501ms. http://71.45.99.229:8096/emby/Items/646fd412b8fb28d9d862e77b82b6f2fd/Images/Primary?maxHeight=636&maxWidth=424&tag=02579a5696b4ee3b20cf4fabd48142f5&quality=90 2018-06-02 21:37:12.555 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:12.558 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:37:12.563 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:12.564 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:12.566 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:37:12.567 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:37:12.600 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:12.612 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 12ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2018-06-02 21:37:26.214 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.216 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:37:26.270 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.272 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:37:26.328 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.332 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 4ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:37:26.335 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.338 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.338 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:37:26.340 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:37:26.377 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.387 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 10ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2018-06-02 21:37:26.495 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/5aacac5fd88c05a3fc72b6e3473276f6/Images/Primary?maxHeight=630&maxWidth=420&tag=df46cd8be5a78925d82dfebbe2cd8ba3&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.502 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/46813be28992602e5108b9e140426f10/Images/Primary?maxHeight=630&maxWidth=420&tag=02d32115f424704b7701526c600cb188&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.512 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/dce3cf33a964ff813ea17068cc1291b3/Images/Primary?maxHeight=630&maxWidth=420&tag=bec9fab40a2460ac16c91dfe8ef6b093&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.518 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/ba3253d745af2d717113b3cd56557896/Images/Primary?maxHeight=630&maxWidth=420&tag=1a2cafb717c980a610ff89326e7855a3&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.579 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/66ad8a997cd270f6f3400b15e3f9655c/Images/Primary?maxHeight=630&maxWidth=420&tag=37ebee3dc9b6d6480dfaae041b009789&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.584 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/be5e79466edaf5febee47760b07b1dbe/Images/Primary?maxHeight=630&maxWidth=420&tag=87eedb78f5097a130c408a472c724611&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:26.673 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 171ms. http://71.45.99.229:8096/emby/Items/46813be28992602e5108b9e140426f10/Images/Primary?maxHeight=630&maxWidth=420&tag=02d32115f424704b7701526c600cb188&quality=90 2018-06-02 21:37:26.768 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:37:26.769 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:37:26.871 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:37:26.872 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:37:26.881 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 302ms. http://71.45.99.229:8096/emby/Items/66ad8a997cd270f6f3400b15e3f9655c/Images/Primary?maxHeight=630&maxWidth=420&tag=37ebee3dc9b6d6480dfaae041b009789&quality=90 2018-06-02 21:37:26.941 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 430ms. http://71.45.99.229:8096/emby/Items/dce3cf33a964ff813ea17068cc1291b3/Images/Primary?maxHeight=630&maxWidth=420&tag=bec9fab40a2460ac16c91dfe8ef6b093&quality=90 2018-06-02 21:37:27.008 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 513ms. http://71.45.99.229:8096/emby/Items/5aacac5fd88c05a3fc72b6e3473276f6/Images/Primary?maxHeight=630&maxWidth=420&tag=df46cd8be5a78925d82dfebbe2cd8ba3&quality=90 2018-06-02 21:37:27.030 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:37:27.031 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:37:27.050 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 532ms. http://71.45.99.229:8096/emby/Items/ba3253d745af2d717113b3cd56557896/Images/Primary?maxHeight=630&maxWidth=420&tag=1a2cafb717c980a610ff89326e7855a3&quality=90 2018-06-02 21:37:27.055 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 472ms. http://71.45.99.229:8096/emby/Items/be5e79466edaf5febee47760b07b1dbe/Images/Primary?maxHeight=630&maxWidth=420&tag=87eedb78f5097a130c408a472c724611&quality=90 2018-06-02 21:37:49.078 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Movie. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:49.081 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Series. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:49.091 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 13ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Movie 2018-06-02 21:37:49.092 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 11ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Series 2018-06-02 21:37:49.095 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Episode. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:49.097 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Episode 2018-06-02 21:37:49.110 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:49.110 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Playlist. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:49.112 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Video 2018-06-02 21:37:49.112 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Playlist 2018-06-02 21:37:49.113 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=BoxSet. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:49.118 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 5ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=BoxSet 2018-06-02 21:37:49.154 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Artists?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&userId=f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:49.159 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=MusicAlbum. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:49.162 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=MusicAlbum 2018-06-02 21:37:49.175 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:49.178 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Audio 2018-06-02 21:37:49.186 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 32ms. http://71.45.99.229:8096/emby/Artists?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&userId=f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:37:49.193 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Game. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:49.195 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&EnableTotalRecordCount=false&Limit=20&IncludeItemTypes=Game 2018-06-02 21:37:54.117 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Notifications/f090af23bfe040a2b46c4cf9ffa67c6a/Summary. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:54.119 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Notifications/f090af23bfe040a2b46c4cf9ffa67c6a/Summary 2018-06-02 21:37:54.133 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:54.136 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:54.136 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/ScheduledTasks 2018-06-02 21:37:54.137 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Sessions 2018-06-02 21:37:54.148 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:54.149 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Info 2018-06-02 21:37:54.154 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:54.156 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/News/Product?StartIndex=0&Limit=4 2018-06-02 21:37:54.176 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-02T02%3A37%3A54.186Z. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:54.178 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-06-02T02%3A37%3A54.186Z 2018-06-02 21:37:54.180 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=f090af23bfe040a2b46c4cf9ffa67c6a&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:54.181 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/LiveTv/Recordings?UserId=f090af23bfe040a2b46c4cf9ffa67c6a&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2018-06-02 21:37:54.196 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:54.196 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true 2018-06-02 21:37:54.265 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:54.287 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 22ms. http://71.45.99.229:8096/emby/Packages/Updates?PackageType=UserInstalled 2018-06-02 21:37:54.395 Info HttpServer: HTTP GET http://71.45.99.229:8096/web/css/images/logoblack.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:54.396 Info HttpServer: HTTP Response 304 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/web/css/images/logoblack.png 2018-06-02 21:37:58.818 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:58.820 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 21:37:58.847 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:37:58.849 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/ScheduledTasks?IsEnabled=true 2018-06-02 21:38:02.551 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/cultures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:02.553 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Localization/cultures 2018-06-02 21:38:02.554 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/countries. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:02.556 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Localization/countries 2018-06-02 21:38:02.730 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:02.738 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 8ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 21:38:02.816 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:02.824 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 8ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?IsNewLibrary=true 2018-06-02 21:38:17.344 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:17.359 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 14ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/f137a2dd21bbc1b99aa5c0f6bf02a805 2018-06-02 21:38:17.463 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/RemoteImages/Providers. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:17.474 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 11ms. http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/RemoteImages/Providers 2018-06-02 21:38:17.545 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Images. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:17.562 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 18ms. http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Images 2018-06-02 21:38:23.980 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:23.983 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/f137a2dd21bbc1b99aa5c0f6bf02a805 2018-06-02 21:38:24.109 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/RemoteImages/Providers. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:24.111 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/RemoteImages/Providers 2018-06-02 21:38:24.193 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Images. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:24.195 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Images 2018-06-02 21:38:26.780 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:38:26.781 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:38:26.896 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:38:26.897 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:38:30.646 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:30.647 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 21:38:30.738 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/cultures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:30.740 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Localization/cultures 2018-06-02 21:38:30.741 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Localization/countries. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:30.742 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Localization/countries 2018-06-02 21:38:30.931 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Libraries/AvailableOptions?LibraryContentType=movies&IsNewLibrary=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:30.941 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 11ms. http://71.45.99.229:8096/emby/Libraries/AvailableOptions?LibraryContentType=movies&IsNewLibrary=false 2018-06-02 21:38:44.789 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:44.791 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Environment/DefaultDirectoryBrowser 2018-06-02 21:38:44.791 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/System/Info/Public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:44.792 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/System/Info/Public 2018-06-02 21:38:44.880 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/Drives. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:44.883 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Environment/Drives 2018-06-02 21:38:51.343 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Fmovies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:51.344 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Fmovies 2018-06-02 21:38:51.346 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Fmovies. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:51.347 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Environment/ParentPath?path=%2Fmnt%2FHDD%2Fcomplete%2Ftorrents%2Fmovies 2018-06-02 21:38:54.448 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Environment/ValidatePath. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:54.450 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Environment/ValidatePath 2018-06-02 21:38:54.532 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Library/VirtualFolders/Paths?refreshLibrary=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:54.542 Info LibraryMonitor: Stopping directory watching for path /mnt/HDD/complete/movies 2018-06-02 21:38:54.545 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 13ms. http://71.45.99.229:8096/emby/Library/VirtualFolders/Paths?refreshLibrary=true 2018-06-02 21:38:54.546 Info TaskManager: Queueing task RefreshMediaLibraryTask 2018-06-02 21:38:54.546 Info TaskManager: Executing Scan media library 2018-06-02 21:38:54.547 Info App: Validating media library 2018-06-02 21:38:54.562 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/7229c21a6aa745da958753ed59716496.png 2018-06-02 21:38:54.623 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:38:54.624 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 21:38:55.281 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/7229c21a6aa745da958753ed59716496.png 2018-06-02 21:38:55.295 Error App: Error resolving path /mnt/HDD/complete/torrents/movies/Annihilation.2018.1080p.BluRay.x264.Atmos.TrueHD7.1-HDChina *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/Annihilation.2018.1080p.BluRay.x264.Atmos.TrueHD7.1-HDChina' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 21:38:55.298 Error App: Error resolving path /mnt/HDD/complete/torrents/movies/A.Quiet.Place.2018.720p.HC.HDRip.X264.AC3-EVO *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/A.Quiet.Place.2018.720p.HC.HDRip.X264.AC3-EVO' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 21:38:55.299 Error App: Error resolving path /mnt/HDD/complete/torrents/movies/Avengers.Infinity.War.2018.NEW.720p.HD-TS.X264-CPG *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/Avengers.Infinity.War.2018.NEW.720p.HD-TS.X264-CPG' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 21:38:55.301 Error App: Error resolving path /mnt/HDD/complete/torrents/movies/Deadpool.2.2018.720p.TS.ENG.X264.1xbit *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/Deadpool.2.2018.720p.TS.ENG.X264.1xbit' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 21:38:55.302 Error App: Error resolving path /mnt/HDD/complete/torrents/movies/Tomb Raider 2018 1080p WEB-DL DD5 1 H264-CMRG *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/Tomb Raider 2018 1080p WEB-DL DD5 1 H264-CMRG' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) System.UnauthorizedAccessException at System.IO.UnixFileSystem.FileSystemEnumerable`1.OpenDirectory(String fullPath) at System.IO.UnixFileSystem.FileSystemEnumerable`1.Enumerate() at System.IO.UnixFileSystem.FileSystemEnumerable`1..ctor(String userPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget, Func`3 translateResult) at System.IO.UnixFileSystem.EnumerateFileSystemInfos(String fullPath, String searchPattern, SearchOption searchOption, SearchTarget searchTarget) at System.IO.DirectoryInfo.InternalEnumerateDirectories(String searchPattern, SearchOption searchOption) at System.IO.DirectoryInfo.EnumerateDirectories(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries(IDirectoryService directoryService, String path, IFileSystem fileSystem, ILogger logger, ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) at Emby.Server.Implementations.Library.LibraryManager.ResolvePath(FileSystemMetadata fileInfo, IDirectoryService directoryService, IItemResolver[] resolvers, Folder parent, String collectionType, LibraryOptions libraryOptions) at Emby.Server.Implementations.Library.LibraryManager.<>c__DisplayClass81_0.<ResolveFileList>b__0(FileSystemMetadata f) InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 21:38:55.451 Info App: MovieDbProvider: Finding id for item: Gringo 2018-06-02 21:38:55.451 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Gringo&language=en 2018-06-02 21:38:56.149 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/fe2dfa1fd73a40ecbf6346c0a3adada1.png 2018-06-02 21:38:56.719 Info ImageProcessor: Completed creation of image collage and saved to /var/lib/emby/cache/temp/fe2dfa1fd73a40ecbf6346c0a3adada1.png 2018-06-02 21:38:56.755 Info TaskManager: Scan media library Completed after 0 minute(s) and 2 seconds 2018-06-02 21:38:56.756 Info ServerManager: Sending web socket message ScheduledTaskEnded 2018-06-02 21:38:56.756 Info TaskManager: ExecuteQueuedTasks 2018-06-02 21:38:56.778 Info LibraryMonitor: Watching directory /mnt/HDD/complete/movies 2018-06-02 21:38:56.779 Error LibraryMonitor: Error in Directory watcher for: /mnt/HDD/complete/torrents/movies *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.13.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/torrents/movies/Annihilation.2018.1080p.BluRay.x264.Atmos.TrueHD7.1-HDChina' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- System.UnauthorizedAccessException No Stack Trace Available InnerException: System.IO.IOException System.IO.IOException: Permission denied 2018-06-02 21:38:56.779 Info LibraryMonitor: Stopping directory watching for path /mnt/HDD/complete/torrents/movies 2018-06-02 21:38:56.780 Info LibraryMonitor: Watching directory /mnt/HDD/complete/torrents/movies 2018-06-02 21:39:00.779 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&Ids=af8308796635c84c9a02da120684bd15%2C6ca1e757cf2920fc2ec8647606847cc1&MediaTypes=Audio%2CVideo&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:39:00.782 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 3ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&Ids=af8308796635c84c9a02da120684bd15%2C6ca1e757cf2920fc2ec8647606847cc1&MediaTypes=Audio%2CVideo&EnableTotalRecordCount=false 2018-06-02 21:39:26.768 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:39:26.769 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 2ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:39:26.889 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:39:26.890 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:39:27.003 Info HttpServer: HTTP GET http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml. UserAgent: 2018-06-02 21:39:27.004 Info HttpServer: HTTP Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.145:8096/dlna/e179ae65512e428783510cc8eca1629b/description.xml 2018-06-02 21:40:11.418 Info HttpServer: HTTP POST http://71.45.99.229:8096/emby/Library/VirtualFolders/LibraryOptions. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:11.432 Info HttpServer: HTTP Response 204 to 97.85.21.21. Time: 14ms. http://71.45.99.229:8096/emby/Library/VirtualFolders/LibraryOptions 2018-06-02 21:40:11.646 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:11.648 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Library/VirtualFolders 2018-06-02 21:40:11.716 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Images/Primary?quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:12.292 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 576ms. http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Images/Primary?quality=90 2018-06-02 21:40:15.817 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:15.818 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:40:15.871 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:15.873 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 1ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a 2018-06-02 21:40:15.952 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:15.955 Info ImageProcessor: Getting image size for item CollectionFolder /var/lib/emby/metadata/library/f1/f137a2dd21bbc1b99aa5c0f6bf02a805/poster.png 2018-06-02 21:40:15.974 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 22ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:40:16.041 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:16.044 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Views 2018-06-02 21:40:16.127 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:16.129 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/LiveTv/Programs/Recommended?userId=f090af23bfe040a2b46c4cf9ffa67c6a&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-06-02 21:40:16.133 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Images/Primary?maxHeight=256&maxWidth=456&tag=c6b66adaf3ca281ccc6df17f0d5f602c&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:16.193 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 60ms. http://71.45.99.229:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Images/Primary?maxHeight=256&maxWidth=456&tag=c6b66adaf3ca281ccc6df17f0d5f602c&quality=90 2018-06-02 21:40:16.203 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:16.205 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-06-02 21:40:16.208 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:16.210 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-06-02 21:40:16.226 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:16.228 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 2ms. http://71.45.99.229:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=f090af23bfe040a2b46c4cf9ffa67c6a&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-06-02 21:40:16.245 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:16.255 Info HttpServer: HTTP Response 200 to 97.85.21.21. Time: 10ms. http://71.45.99.229:8096/emby/Users/f090af23bfe040a2b46c4cf9ffa67c6a/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2018-06-02 21:40:16.363 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/dce3cf33a964ff813ea17068cc1291b3/Images/Primary?maxHeight=636&maxWidth=424&tag=bec9fab40a2460ac16c91dfe8ef6b093&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36 2018-06-02 21:40:16.363 Info HttpServer: HTTP GET http://71.45.99.229:8096/emby/Items/46813be28992602e5108b9e140426f10/Images/Primary?maxHeight=636&maxWidth=424&tag=02d32115f424704b7701526c600cb188&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
mike689 0 Posted June 3, 2018 Author Posted June 3, 2018 (edited) It's got me borderline wanting to just scrap my whole server and start fresh That's just such a pain in the ass :-/ EDIT: Perhaps I'll just update install 18.04 and hope it fixes something hah Edited June 3, 2018 by mike689
mike689 0 Posted June 3, 2018 Author Posted June 3, 2018 It's a bit of an old machine my server is running on, but not terribly old. It's got an i3 processor, I don't recall the exact one. Could it just be being overloaded by commands when it's trying to sync the library?
Luke 42246 Posted June 3, 2018 Posted June 3, 2018 You could try moving up to the beta install and see if that helps. Thanks.
mike689 0 Posted June 4, 2018 Author Posted June 4, 2018 Yeah I tried the beta, same results and also made the UI extremely slow. Currently doing a fresh install of Ubuntu 18 server, I'll let you know how it goes with emby.
mike689 0 Posted June 4, 2018 Author Posted June 4, 2018 (edited) Nope, same results on a fresh install of 18. I'm starting to think it's hardware related... Guess I'm stuck with Plex EDIT: Well maybe not hardware related, Plex sure doesn't have any issue syncing all my media at once Edited June 4, 2018 by mike689
mike689 0 Posted June 4, 2018 Author Posted June 4, 2018 Lol, I'm so confused. Oddly enough, I restarted the emby-server service today and it seems to be holding. Did another sync and it's finishing grabbing the rest of my TV shows. No idea what was going on there...
Luke 42246 Posted June 5, 2018 Posted June 5, 2018 Does the whole server stop, or do you just have trouble connecting from one instance of the web interface?
mike689 0 Posted June 5, 2018 Author Posted June 5, 2018 I didn't actually test that, but it seems like the whole emby-server process stops, because it was not fully synced when I finally restarted it and got it working. So I doubt it would be just breaking the interface if it stopped the sync process in it's tracks.
mike689 0 Posted June 5, 2018 Author Posted June 5, 2018 Doesn't look like it, it's held strong since and with adding media, etc. It's got my whole library doing just fine now. Only issue I'm having now is Real Time Monitoring. I've got it set for both my TV and Movie libraries but it still won't add new media to my library unless I manually do "Scan All Libraries". Do you think this could be a permissions issue? The directories are owned by me, I added the emby user to my group. Seems I'm missing something though because it doesn't add new things automatically to the library.
Luke 42246 Posted June 5, 2018 Posted June 5, 2018 Why do you feel that it won't add new media to your library?
mike689 0 Posted June 5, 2018 Author Posted June 5, 2018 It does add new content to my emby library, but only when I manually do a scan. Not automatically when content is added to the specified folders, as it should. I have all libraries set to real time monitoring, so if something downloads and is transferred to one of the set folders it should automatically sync it to the emby library, no?
mike689 0 Posted June 5, 2018 Author Posted June 5, 2018 (edited) I just downloaded a show and it auto moved to the relevant folder, the library did not auto update. Here are the relevant logs (most recently modified embyserver-63663676500.txt, and the regular emby-server.txt) https://pastebin.com/N4VE7eFA https://pastebin.com/gR08rKqF <- I believe this should be the relevant one. EDIT: "System.UnauthorizedAccessException: Access to the path '/mnt/HDD/complete/tv/Media.File.S08E05.Doesnt.Matter.x264' is denied. ---> System.IO.IOException: Permission denied" I figured it had to be some sort of permission issue. Any idea how I go about fixing this with the proper permissions? Edited June 5, 2018 by mike689
mastrmind11 722 Posted June 5, 2018 Posted June 5, 2018 (edited) deleted Edited June 5, 2018 by mastrmind11
mike689 0 Posted June 5, 2018 Author Posted June 5, 2018 Welp, maybe I'll get lucky and this will fix it. Even though I SWEAR i already changed this, it seems the top directory was owned by mike:plex. It's now changed recursively to mike:emby... fingers crossed that fixes it.
Luke 42246 Posted June 5, 2018 Posted June 5, 2018 Well yes your logs did show a lot of file access errors. I didn't bring them up before because it really shouldn't affect web app connectivity.
