Angelblue05 4132 Posted June 24, 2018 Author Posted June 24, 2018 (edited) @@jean-gui Ok I think I managed to fix the formatting. Can you go quickly over the strings you translated and just remove the / and put each entry on a new line? Thank you. I've sent in a ticket to find out how to display the string key instead of some random # since the string key is hidden under the suggestion tab. Edit: There's no way to replace the # with the string key. They said it's because the string key can sometime be really long. Let me know if it's better now. After that, I'll build the Alexa model in French and you can test things out. Edited June 26, 2018 by Angelblue05
jean-gui 2 Posted June 28, 2018 Posted June 28, 2018 Apologies, I haven't had much time to wok on that. I'll try to fix the / thing in the week-end
jean-gui 2 Posted July 1, 2018 Posted July 1, 2018 @@Angelblue05 Done! Note that for 84a5274a045523df14f848cb20b5695d (the last translation) there are still some slashes. I left them in the translation as well as I wasn't sure whether this was intended or not. 1
Angelblue05 4132 Posted July 1, 2018 Author Posted July 1, 2018 (edited) Oh? I'll check. It should not have any slash anywhere. Thanks! Edit: Ok, yes for the devices.txt leave it as is because they represent synonyms of the first word on the line. I have corrected it myself. The rest looks good. I will get that put together and let you know when it's ready for testing. Was it better this way? The way I set it up I mean, with the new lines? Edited July 2, 2018 by Angelblue05
Angelblue05 4132 Posted July 2, 2018 Author Posted July 2, 2018 (edited) @@jean-gui I built the skill in French. Can you give it a test run. Also let me know how I should translate the invocation name: m. b. home Something simple - similar. Have I invited you to beta? If not, pm your amazon email so you can test the skill with your utterances/words If you can't test this week, let me know. Thanks! Edited July 2, 2018 by Angelblue05
jean-gui 2 Posted July 2, 2018 Posted July 2, 2018 That was easier with new lines instead of /, yes. The invocation name is an interesting question. Perhaps something like "èmbi" would work, although I'm not sure how most French people pronounce Emby. I don't know if the word Emby would be problematic in French. I'll PM you my amazon account, although I can't promise I'll have time to test it this week.
Angelblue05 4132 Posted July 9, 2018 Author Posted July 9, 2018 Thanks to @@jean-gui Emby with Alexa is ready for beta testing in French. Send me your amazon alexa email and I'll add you to beta testing.
Angelblue05 4132 Posted July 9, 2018 Author Posted July 9, 2018 @@jhoff80 Sorry to trouble you, would it be possible for you to test Alexa playback that would fail to play previously? I just want to see if my latest modification to player support helps any in your case. Thank you 1
jhoff80 94 Posted July 9, 2018 Posted July 9, 2018 Yes, both albums that I identified as failing previously are working now. 1
chudak 24 Posted December 20, 2018 Posted December 20, 2018 (edited) Check out the advanced server settings. Maybe you can. is https still a requirement to play music via Alexa? Will it be the same in 3.6 release ? Edited December 20, 2018 by chudak
Luke 42239 Posted December 21, 2018 Posted December 21, 2018 It is a requirement to play on the alexa device itself. 1
Mairyj 0 Posted August 13, 2019 Posted August 13, 2019 Hello, it's been over a year that the subject has not updated. Is the Skill still planned for the French blind? Thank you in advance for your answers
Luke 42239 Posted August 13, 2019 Posted August 13, 2019 Hi, yes hopefully we'll be able to pick this up soon. Thanks.
Mairyj 0 Posted August 19, 2019 Posted August 19, 2019 great, thanks for your answer. I would be patient and look forward to it being available
lrachb 0 Posted August 28, 2019 Posted August 28, 2019 Have you got news to the french skill?is it possible to participate on beta skill french?
informaweb 8 Posted September 13, 2019 Posted September 13, 2019 Alexa has been available in France on Fire Stick 4K for a week. Would it be possible to deploy Skill Emby on Amazon Alexa France? 1
Luke 42239 Posted September 14, 2019 Posted September 14, 2019 Alexa has been available in France on Fire Stick 4K for a week. Would it be possible to deploy Skill Emby on Amazon Alexa France? Hopefully we'll have something soon. Thanks.
smosse 1 Posted November 26, 2019 Posted November 26, 2019 Alexa has been available in France on Fire Stick 4K for a week. Would it be possible to deploy Skill Emby on Amazon Alexa France? +1000000
winhacker 0 Posted November 30, 2019 Posted November 30, 2019 Hello,I am interested to participate in the test version of Emby's French skill for AlexaThank you.
studio-jurdan 9 Posted August 4, 2020 Posted August 4, 2020 mm i don't realy understant the topic "alexa FRENCH" but it is in english and NOT on the French ALEXA skill
Luke 42239 Posted August 6, 2020 Posted August 6, 2020 On 8/4/2020 at 3:53 AM, studio-jurdan said: mm i don't realy understant the topic "alexa FRENCH" but it is in english and NOT on the French ALEXA skill Hi, yes we are still working on French support. Thanks for the feedback.
Luke 42239 Posted January 13, 2021 Posted January 13, 2021 On 1/11/2021 at 3:40 PM, thymon said: Need some help to translate ? Hi, yes hopefully soon. Stay tuned.
