MPC as External player help
{path}
/start
/fullscreen
/play
/close
/start needs a number of ms as addition parameter and that must be in a separate line ( {ms} )
but basically that is useless, cause it only supports resuming something that got played by something else, cause there is still no playback tracking for external players
still don't get why this must be so complicated here and the commadline still has to be a list of commands
@@Luke the explanation text still does not state that each space separated part must be in its own line: 'Place each argument on a separate line'
but anyway it works here normally (mpc-hc and be) if correctly setup
even your setup works, it just ignores /fullscreen cause mpc thinks its the parameter for /start
Edited by daedalus
Hi,
Could you let me know exactly what the list of commands that your are using that works? I have tried many different variants with no success, so would like to try a set that is confirmed to work.
Thanks, Richard
if you want that start included:
{path}
/start
{ms}
/fullscreen
/play
/close
Edited by daedalus
Thanks for the assist, but this still does not work, on either of my PCs. One PC is the Emby host, and the other is on the same local network.
MPC-HC is working correctly on both PCs, but I had this error before I did a rebuild, and it is still with me.
The Player path is "C:\Program Files\MPC-HC\mpc-hc64.exe"
Commandline arguments are
{path}
/start
{ms}
/fullscreen
/play
/close
tried without the " ?
^ tried myself this is your problem solving answer :D  emby in general doesn't like quote enclosed paths
maybe this could also be interesting for @@lightsout
Edited by daedalus
Thanks. I now feel extremely foolish!
This works, including the HDR passthrough with MadVR.
Thanks again.
Richard
no need to feel foolish over quirky implementations of simple things
