Live TV does not work - error log
airbillion
Any ideas on why I cannot get live tv to work?  It works fine on my xbmc clients, but not with mediabrowser....
OpenLiveStream> stream path returned to client: \\FAMILYROOM\Recorded TV\TempSWMC\LiveTV_MediaBrowser^1_Digital Cable_2_2014_03_28_09_56_28.ts
2014/03/28 09:56:36.407 OpenLiveStream> -----------------done-------------------------
2014/03/28 09:56:36.407 Finished request OpenLiveStream in 7.76s
2014/03/28 09:56:36.417 Received client request: MediaBrowser^@VBOX-MB3-SERVER@1|StreamStartError|\\FAMILYROOM\Recorded TV\TempSWMC\LiveTV_MediaBrowser^1_Digital Cable_2_2014_03_28_09_56_28.ts
2014/03/28 09:56:36.417 StreamStartError> client 'MediaBrowser^1' reports error opening stream, will close stream down
2014/03/28 09:56:36.417 StreamStartError> client 'MediaBrowser^1' path to stream file: '\\FAMILYROOM\Recorded TV\TempSWMC\LiveTV_MediaBrowser^1_Digital Cable_2_2014_03_28_09_56_28.ts'
2014/03/28 09:56:36.417 StreamStartError> client 'MediaBrowser^1' calling CloseStream
2014/03/28 09:56:36.417 Remux::Stop> stop remux called
2014/03/28 09:56:36.417 Pass 'mux2ts':
2014/03/28 09:56:36.417 >  WtvToPesDemuxer::Parse> total guid headers processed: 795
2014/03/28 09:56:36.417 >  WtvToPesDemuxer::Parse> total data packets processed: 94
2014/03/28 09:56:36.422 Remux> ENDED, >>>>>>>>>> Run Time: 0.00 min <<<<<<<<<<
2014/03/28 09:56:36.437 StreamProc::Close> remux stopped successfully
2014/03/28 09:56:36.437 RecordToWTV::Close> isPassive is False => COM recorder will be stopped
2014/03/28 09:56:36.482 StreamProc::Close> wtv closed successfully
2014/03/28 09:56:36.532 StreamProc::Close> wtv file size: 2,359,296
2014/03/28 09:56:36.582 StreamProc::Close> file deleted: D:\Recorded TV\TempSWMC\LiveTV_MediaBrowser^1_Digital Cable_2_2014_03_28_09_56_28.wtv
2014/03/28 09:56:36.632 StreamProc::Close> ts file size: 524,288
2014/03/28 09:56:36.632 StreamProc::Close> file deleted: D:\Recorded TV\TempSWMC\LiveTV_MediaBrowser^1_Digital Cable_2_2014_03_28_09_56_28.ts
2014/03/28 09:56:36.632 StreamProc::Close> closed in 0.22 sec
2014/03/28 09:56:36.632 Close> closed stream for client: MediaBrowser^1
2014/03/28 09:56:36.632 Finished request StreamStartError in 0.22s
krustyreturns
Its hard to say for sure without the rest of the server log, but it looks like the machine mbs is running on cannot access the recorded tv folder on the wmc machine.  To check, type this address into the start button on the mbs machine:
and see if it opens the folder.
airbillion
Hi Thanks for the quick response.
Tried from the MB3 server machine and the folder is accessible.  No issues browsing to the folder.
airbillion
I figured it out...
I had the MB3 service on the machine set to run as a local service.  I changed that to my default login account and it is now working!
That also got rid or the plugin error on the dashboard:  Status: Unavailable (Recorded TV folder ‘\\SPARE1\Public\Recorded TV\’ not accessible. Please make sure the Recorded TV folder used by WMC for new recordings is a shared folder. Once done, the network path to this folder must be set in ServerWMC (see ‘Folders’ tab in ServerWMC).)
All is working now!
Thanks!
  • Like 1
  • 1 year later...
I figured it out...
All is working now!
Thanks!
Woo Hoo! Sorry, thanks. Changing the login account from local to my administrator login (running mb/emby service on windows home server 2011) did the trick.  I've not tested everything but it looks promising for the first time in days.
Bruce
