matt_ttam123 6 Posted May 31, 2018 Posted May 31, 2018 (edited) Just wondering if this is normal or is this something not yet implemented where live tv auto grabs the fanart for things that are currently on? See attached image Edited May 31, 2018 by matt_ttam123
gtmnyc 12 Posted May 31, 2018 Posted May 31, 2018 I have found the only way to get thumbnails is to use schedules direct
Luke 42244 Posted May 31, 2018 Posted May 31, 2018 The guide data needs to have the images, so if you're using XML and it doesn't have images then that would explain this.
matt_ttam123 6 Posted June 1, 2018 Author Posted June 1, 2018 The guide data needs to have the images, so if you're using XML and it doesn't have images then that would explain this. Perfect this was the answer I was looking for, it might be time to invest in guide data that includes images then I think.
cyberbuzz23 0 Posted June 13, 2018 Posted June 13, 2018 (edited) Hi Luke, I'm using XMLTV with zap2xml WITH programs image " -I " option. That put the image of aech programs web link in the XML file. The problem is emby don't seem to download them or have sort of a problem to grab them because when i select a program, it show a little broken link icon instead of the image itself. More strange, when i copy the url from the xml file and paste it on a browser... no problem to see it. Also, what file(s) emby server need to incorporate these icons/pictures, only the .XML or it need cache or icons folder? By the way, the Channel logo doesn't work either, i had to put it manually with metadata manager Thanks for helping me out. Regards, Edited June 13, 2018 by cyberbuzz23
Luke 42244 Posted June 13, 2018 Posted June 13, 2018 Please attach the information requested in how to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
cyberbuzz23 0 Posted June 13, 2018 Posted June 13, 2018 Please attach the information requested in how to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks. Hi Luke, I'm using XMLTV with zap2xml WITH programs image " -I " option. That put the image of aech programs web link in the XML file. The problem is emby don't seem to download them or have sort of a problem to grab them because when i select a program, it show a little broken link icon instead of the image itself. More strange, when i copy the url from the xml file and paste it on a browser... no problem to see it. You can see the error message it give when i right click on broken logo (see show.png) and click on open picture on another tab. (See error.png for error message) As an Exemple: <icon src="https://zap2it.tmsimg.com/h3/NowShowing/72986/s16371_h3_aa.png"/> <icon src="https://zap2it.tmsimg.com/assets/p186054_b_v5_at.jpg"/> Those two lines are in the XMLTV.XML file. Copying/pasting it on a web browser will work but Emby will not grab them.-First is for a Channel logo and second line is for an episode Also, what file(s) emby server need to incorporate these icons/pictures, only the .XML or it need cache or icons folder? By the way, the Channel logo doesn't work either, i had to put it manually with metadata manager I attached the log file, the XMLTV file and some screenshot Hope you have enough information!! Thanks for helping me out. Regards, Log.txt xmltv.xml
Solution Luke 42244 Posted June 13, 2018 Solution Posted June 13, 2018 the server is trying to download the images but is unable to contact the domain: 2018-06-13 07:52:31.365 Error HttpClient: Error NameResolutionFailure getting response from https://zap2it.tmsimg.com/assets/p3101576_e_v5_ab.jpg It sounds like there is either a problem with the network connection in your jail or something external is just blocking it altogether. 1
cyberbuzz23 0 Posted June 13, 2018 Posted June 13, 2018 Hi again, you were right, in my jail plugin in freenas i didn't put any default gateway... My bad. Now that this is resolve, I've another error instead. Joining the log file but mostly the error is now about Securechannelfailure 2018-06-13 14:44:12.582 Error HttpClient: Error SecureChannelFailure getting response from https://zap2it.tmsimg.com/h3/NowShowing/72879/s16367_h3_aa.png Thx Log.txt
Luke 42244 Posted June 15, 2018 Posted June 15, 2018 Hi again, you were right, in my jail plugin in freenas i didn't put any default gateway... My bad. Now that this is resolve, I've another error instead. Joining the log file but mostly the error is now about Securechannelfailure 2018-06-13 14:44:12.582 Error HttpClient: Error SecureChannelFailure getting response from https://zap2it.tmsimg.com/h3/NowShowing/72879/s16367_h3_aa.png Thx @@cyberbuzz23, this is due to an issue on FreeBSD that we're currently stuck waiting on, unfortunately. We need the mono runtime in FreeBSD ports to get updated. You can follow this issue here: https://emby.media/community/index.php?/topic/56481-securechannelfailure-on-freenas/ Please see my most recent comment from yesterday. Thanks.
cyberbuzz23 0 Posted July 26, 2018 Posted July 26, 2018 Hi Luke, I updated to the 11.2 freenas and installed "manually" the lastest version of Emby (great by the way).. I still have some live tv guide issue.. it strange because i can see shows (pictures/names) on "programs" tabs. but nothing on guide tab... Here is my log and xml file Thx for your help again Dan xmltv.xml embyserver.txt
Luke 42244 Posted July 26, 2018 Posted July 26, 2018 Hi, what do you mean by nothing on the guide tab? No shows, or no images?
cyberbuzz23 0 Posted July 27, 2018 Posted July 27, 2018 Both, i only have channels.listing it's totaly blank on the left side
cyberbuzz23 0 Posted July 27, 2018 Posted July 27, 2018 Ho man, sorry Luke, i just saw that i have show starting only the 4 of august...???
cyberbuzz23 0 Posted July 27, 2018 Posted July 27, 2018 update, this is because of my zap2xml so dont worry everythings fine thanks Luke!
