MClements130 1 Posted May 29, 2018 Author Posted May 29, 2018 @@Sammy I got it from the official website also did the port opening and still no luck. It ain’t nothing to deal with my computer the installation installer is missing files
MClements130 1 Posted May 29, 2018 Author Posted May 29, 2018 @@Sammy the website I got it from was https://serverwmc.github.io
Sammy 791 Posted May 29, 2018 Posted May 29, 2018 Did you try the 1236 version too? It seems 1244 needs a manual installation which means you need to install the older version first then manually copy the newer executable over it.
Sammy 791 Posted May 29, 2018 Posted May 29, 2018 @@Luke This discussion seems Off Topic. Should it be moved to the ServerWMC sub forum?
MClements130 1 Posted May 31, 2018 Author Posted May 31, 2018 @@MClements130? Im here I was busy getting some stuff done
