johnny_swindle 5 Posted May 27, 2018 Posted May 27, 2018 I had to shut down my emby server and on reboot emby would not start (got the infamous err....connection refused). I tracked down the embyserver.exe and clicked on it and after a couple of seconds it started. Couple of questions: 1. How is the server restarted after a reboot? 2. Should I look for something that is not configured corrected? 3. How do I prevent this in the future? Thanks... Johnny
johnny_swindle 5 Posted May 27, 2018 Author Posted May 27, 2018 Well, I spoke too soon........tried to have one of my Kodi boxes view a movie. It could not. Reboot emby server now it says local host connection refused. Please advise. Johnny
Solution Luke 42210 Posted May 27, 2018 Solution Posted May 27, 2018 Hi, under Advanced did you enable the option to run at startup? 1
johnny_swindle 5 Posted May 28, 2018 Author Posted May 28, 2018 That was the issue.....don't know how I overlooked that option. Thanks..... BTW, I love your avatar.....I have that image on a T-Shirt. Johnny
Luke 42210 Posted May 28, 2018 Posted May 28, 2018 Then why did you think emby was "refusing" to start?
johnny_swindle 5 Posted May 28, 2018 Author Posted May 28, 2018 (edited) When attempting to access Emby either through Kodi or via web page, I would get an error. I guess "refusing" was a poor choice of words....maybe I should have said "not running after reboot." Anyway you resolved the issue and pointed out my oversight. Thanks again. Johnny Then why did you think emby was "refusing" to start? Edited May 28, 2018 by johnny_swindle
