dual-o 19 Posted June 29, 2018 Posted June 29, 2018 Edit the names of what entries exactly? The Versions you can choose. When I group multiple-versions I can choose between the entries named by the filename. Can I rename these entries without rename the filename? Thanks
dual-o 19 Posted June 29, 2018 Posted June 29, 2018 would be nice to have a field in "edit metadata" or somewhere else
dual-o 19 Posted June 30, 2018 Posted June 30, 2018 (edited) I have found an Issue. When I group over UI I still have two entries in "movie view" Edited June 30, 2018 by dual-o
Luke 42216 Posted June 30, 2018 Posted June 30, 2018 Not all screens group them yet. It's something we're looking into. Thanks.
dual-o 19 Posted July 19, 2018 Posted July 19, 2018 today I have updatet to 3.5.0.0. Same Issue in Movie overview. Thanks
dual-o 19 Posted July 20, 2018 Posted July 20, 2018 when i click on my movie libery called "Filme" I saw double entries of the grouped movies. In "Star Wars" collection too (screenshot above).
Luke 42216 Posted July 26, 2018 Posted July 26, 2018 in normal "Movie View" too @@dual-o, can you show this complete screenshot so that i can see the entire browser tab? thanks.
dual-o 19 Posted July 30, 2018 Posted July 30, 2018 (edited) ... same on 3.5.2.0 edit: @Luke does it help you? Edited August 14, 2018 by dual-o
Luke 42216 Posted September 4, 2018 Posted September 4, 2018 Yes please try again with the next release, thanks.
dual-o 19 Posted September 21, 2018 Posted September 21, 2018 Hello, the Issue still exists. Updatet to 3.5.3.0
Solution Luke 42216 Posted September 21, 2018 Solution Posted September 21, 2018 It is resolved in emby server 3.6. thanks. 2
dual-o 19 Posted September 22, 2018 Posted September 22, 2018 It is resolved in emby server 3.6. thanks. Sounds good. Thanks for the great work.
dual-o 19 Posted January 16, 2019 Posted January 16, 2019 Issue solved with 4.0.0.2 today. Thanks a lot guys!
