rtigd2 8 Posted May 23, 2018 Posted May 23, 2018 I tried controlling Emby Theater on my laptop with 'Remote Mouse' on my phone. Everything is fine except for the arrows to scroll sideways through lists doesn't work (and it's a shame that horizontal mouse scrolling isn't implemented) - Does anyone have a work-around or fix that I can try please? Currently I've just had to go back to launching in a Firefox browser and, well, I quite like Theater (and it's a long way + effort to get off my lazy arse to control on the laptop directly)
Luke 42243 Posted May 23, 2018 Posted May 23, 2018 Hi, if the app is in TV display mode then the primary input method is considered a remote control. You can scroll horizontally with the mousewheel in this situation. If you switch the app to desktop display mode then you'll get scrolling arrows.
rtigd2 8 Posted May 23, 2018 Author Posted May 23, 2018 I've got the 'latest' (as in, downloaded on Monday) Emby Theare for Windows installed on this laptop and in 'Windowed' mode, no arrows and horizontal scrolling with the mouse pad isn't working, vertical works as expected.
rtigd2 8 Posted May 23, 2018 Author Posted May 23, 2018 Ahh, after wondering what you meant by TV Display Mode, I've just taken a look at the settings. In Home Screen: Horizontal I can scroll without worries or issues, all is good. In Home Screen: Vertical No matter what, I can scroll up and down but can't find a way at all to scroll left and right, meaning you are very limited to what you can watch
