MikePlanet 144 Posted November 23, 2018 Posted November 23, 2018 What is still an issue? At least the topic of this post - movies are still shown with each version when selecting a collection/group:
MikePlanet 144 Posted November 24, 2018 Posted November 24, 2018 Hi @@Luke, I just did a test for the other issue in this thread here, this is resolved. It is about movie versions had been shown separately in the latest movies section of the start portal - thanks!
MikePlanet 144 Posted November 26, 2018 Posted November 26, 2018 At least the topic of this post - movies are still shown with each version when selecting a collection/group: collections-nondistinct-movies.JPG fixed in .71 - but was it intentional, that the count of the versions was removed?
Luke 42243 Posted November 26, 2018 Posted November 26, 2018 Do you think it is necessary? We are extremely inconsistent about this, no other app is showing that count.
MikePlanet 144 Posted November 26, 2018 Posted November 26, 2018 Do you think it is necessary? We are extremely inconsistent about this, no other app is showing that count. Good question ;-) ... you are right, we were not consistant - some views had it, some did not. From a user perspective, I think they are not needed, as it doesn't matter if there is multiple versions or not. From admin perspective I found it useful to see that there are multiple versions existing for a movie and how many. I could live without them, we probably have other more important things to care about...
Luke 42243 Posted November 26, 2018 Posted November 26, 2018 thanks, I agree. It always throws me for a loop where i have to remind myself what the count means.
KingCommandoJimmoTheIII 0 Posted September 5, 2019 Posted September 5, 2019 I am currently getting this issue, is there any way to fix this without the files having the exact same name as the folder it is in? I cannot rename the files for various reasons.
Luke 42243 Posted September 5, 2019 Posted September 5, 2019 I am currently getting this issue, is there any way to fix this without the files having the exact same name as the folder it is in? I cannot rename the files for various reasons. Hi there, can you please go over an example? Thanks.
KingCommandoJimmoTheIII 0 Posted September 5, 2019 Posted September 5, 2019 Hi there, can you please go over an example? Thanks. I am trying to convert media so that I have two versions - a high bitrate original and a low bitrate one for mobile. I am converting to the "Original media folder, next to original files". I end up with a folder structure that looks like this: /Movies /xxxx /yyyy /zzzz.mkv /zzzz - mobile.mp4 Instead of having a single item with two versions, I instead end up with two items in a subfolder. Grouping the items manually does not fix this and just makes it so both items have the two versions. Is there any way to force them into a single item or remove the duplicate? Thanks for your help.
Luke 42243 Posted September 15, 2019 Posted September 15, 2019 @@KingCommandoJimmoTheIII In order to group they need to follow our multi-version naming: https://github.com/MediaBrowser/Wiki/wiki/Movie-naming#multi-version-movies When you use the convert feature, the new file will be named this way, but in some cases you may also have to rename your original file. The server currently does not rename your original file for you. Please let us know if this helps. Thanks.
KingCommandoJimmoTheIII 0 Posted September 16, 2019 Posted September 16, 2019 @@KingCommandoJimmoTheIII In order to group they need to follow our multi-version naming: https://github.com/MediaBrowser/Wiki/wiki/Movie-naming#multi-version-movies When you use the convert feature, the new file will be named this way, but in some cases you may also have to rename your original file. The server currently does not rename your original file for you. Please let us know if this helps. Thanks. So does this mean there is no way to have them group when they are not following the naming convention? In that case, I might upgrade my server hardware so that it can handle live transcoding instead. Thanks for helping out.
Luke 42243 Posted September 16, 2019 Posted September 16, 2019 There is a manual grouping feature you can use using the multi select tool with the checkboxes in the upper left.
KingCommandoJimmoTheIII 0 Posted September 16, 2019 Posted September 16, 2019 There is a manual grouping feature you can use using the multi select tool with the checkboxes in the upper left. Yes, I did try that but it didn't work, instead I just end up with two items both with two versions as shown in the original post. An answer above said that the files need to follow the naming convention for it to work. What I was wondering is: Is there was a way to do this without the files following the naming convention?
Luke 42243 Posted September 16, 2019 Posted September 16, 2019 The manual grouping feature will work just fine. What exactly did you do?
KingCommandoJimmoTheIII 0 Posted September 16, 2019 Posted September 16, 2019 The manual grouping feature will work just fine. What exactly did you do? Looks like the reason was because I had the library type set to "Mixed Content" and not "Movies". When I rebuild the library as "Movies" it works fine, and I only get duplicates when I go to the "Folders" tab. Is there a way to make manual grouping work with the "Mixed Content" library type or the "Folders" tab in the "Movies" library type?
Luke 42243 Posted March 9, 2025 Posted March 9, 2025 Automatically merging movies by Movie Db Id will be a built-in feature in the upcoming Emby Server 4.9 release. Thanks. 1
