nicko84 72 Posted February 22, 2019 Posted February 22, 2019 Hello Luke, Something new about this issue et requests ? Best regards
daedalus 434 Posted February 27, 2019 Posted February 27, 2019 just some time and this gets its first anniversary its so sad and ridiculous at the same time
nicko84 72 Posted February 27, 2019 Posted February 27, 2019 (edited) Yes...i give up auto refresh rate on ET, i set up TV on 23hz and it's good for most of videos (except European files at 50hz of course !) even it's not for ET UI display itself (not as smooth as 50hz...) Edited February 27, 2019 by nicko84
daedalus 434 Posted February 27, 2019 Posted February 27, 2019 why not running @ 60hz with display sync & interpolation? that's what i am very happy with
lifespeed 42 Posted February 27, 2019 Posted February 27, 2019 (edited) I use refresh rate switching and then manually (F key) switch from windowed then back to full screen as a workaround. Yes, it is a long standing bug. And as with several Emby problems it appears related to software not written by the Emby developers (Electron?). For me using the proper refresh rate is much better than having the PC interpolate to a different rate. Edited February 27, 2019 by lifespeed
Luke 42242 Posted March 1, 2019 Posted March 1, 2019 Can you please try this version: https://www.dropbox.com/s/zj75bqjajgjerey/theater.zip?dl=0 Thanks.
PrincessClevage 175 Posted March 1, 2019 Author Posted March 1, 2019 Gap seems to be fixed with refresh rate switching on, but I do see some video glitching in fast movie video but also could just be my configuration, need more testing
daedalus 434 Posted March 1, 2019 Posted March 1, 2019 you should have an eye if display video sync stays active that could cause this
PrincessClevage 175 Posted March 1, 2019 Author Posted March 1, 2019 (edited) you should have an eye if display video sync stays active that could cause this i don’t enable display video sync, Hdr colours actually look really good with this build Edited March 1, 2019 by PrincessClevage
lifespeed 42 Posted March 1, 2019 Posted March 1, 2019 Can you please try this version: https://www.dropbox.com/s/zj75bqjajgjerey/theater.zip?dl=0 Thanks. Will this fix be in the next release?
Luke 42242 Posted March 1, 2019 Posted March 1, 2019 Don't know. These are changes I tried to make a year ago but then had to revert due to others complaining about black screens at startup. Maybe you guys can help find the threads from last March.
lifespeed 42 Posted March 1, 2019 Posted March 1, 2019 So this is an Emby issue, not third-party software?
Luke 42242 Posted March 1, 2019 Posted March 1, 2019 The changes made here simplify the window management which makes it less likely to run into quirks of other software we are embedding.
Luke 42242 Posted March 1, 2019 Posted March 1, 2019 @ i can't find the recent topic from the guy who mentioned the app not having focus on startup, but these changes are likely to help with that as well. Thanks.
Guest asrequested Posted March 1, 2019 Posted March 1, 2019 You mean this one? https://emby.media/community/index.php?/topic/69946-server-v4xx-external-player-doesnt-start/page-1
Guest asrequested Posted March 2, 2019 Posted March 2, 2019 I don't know what's happening with that test build, but it's jacked up! I don't get an overlay UI when playing something, and it totally messes up my display. It changes the brightness. I have to reboot to correct it.
Luke 42242 Posted March 2, 2019 Posted March 2, 2019 What do you mean that you don't get an overlay UI?
Guest asrequested Posted March 2, 2019 Posted March 2, 2019 What do you mean that you don't get an overlay UI? Only the picture, no play button, progress bar etc. Nothing but the video playback. Something tweaks my display when I start playback. I should add this is not related to refresh rate switching. I haven't tested that. It seems to be messing with the Windows display coloring/brightness. Possibly related to Windows HDR10.
Guest asrequested Posted March 2, 2019 Posted March 2, 2019 (edited) I think I know in part, what is happening. The window isn't locked down. I can resize it while the video is playing. Now I have to reboot my machine, again. Edited March 2, 2019 by Doofus
arrbee99 1836 Posted March 2, 2019 Posted March 2, 2019 Not sure what I'm supposed to try, but just trying Theater on same PC as server, don't get any gaps at edges of screen and all the Play etc controls are there and working playing normal non 4K, non HDR stuff.
Luke 42242 Posted March 2, 2019 Posted March 2, 2019 I think I know in part, what is happening. The window isn't locked down. I can resize it while the video is playing. Now I have to reboot my machine, again. @ Can you try this version as an alternate: https://www.dropbox.com/s/5ays1lha4mmfi0o/theater1.zip?dl=0 At the moment you won't be able to drag the window and move it. I just want to know if you can see the video OSD or not. Thanks.
Luke 42242 Posted March 2, 2019 Posted March 2, 2019 Not sure what I'm supposed to try, but just trying Theater on same PC as server, don't get any gaps at edges of screen and all the Play etc controls are there and working playing normal non 4K, non HDR stuff. That's good because a year ago you were one of the ones who had a problem with these same changes: https://emby.media/community/index.php?/topic/56802-gui-overlay/?p=567455
