snapwing 1 Posted July 17, 2018 Posted July 17, 2018 better finally find & fix the real problem+1 In my case, at least, hitting the maximize button a couple times does not always fix the issue. Additionally, in case it's useful, I applied the reg keys related to the NOEDID as I thought this was promising, given my situation. It did not help with the specific issue of the two small "gaps" at the bottom of the screen. Sent from my Pixel using Tapatalk
serpi 82 Posted July 17, 2018 Posted July 17, 2018 Additionally, in case it's useful, I applied the reg keys related to the NOEDID as I thought this was promising, given my situation. It did not help with the specific issue of the two small "gaps" at the bottom of the screen. No, this doesn't help for this, it's for another problem: if your ET window is much smaller (normally 1024x768) than the screen after waking up the PC, because the PC is up before the TV and so it uses a dummy screen mode. But as mentioned before, besides the small gap at button/right in playback after screen mode/rate changes, I also see a gap at the top of the screen before (auto) logon or right after video plaback, but only for a blink-and-you-miss-it moment. Anyone else can confirm this? Ciao, Alfred
snapwing 1 Posted July 17, 2018 Posted July 17, 2018 No, this doesn't help for this, it's for another problem: if your ET window is much smaller (normally 1024x768) than the screen after waking up the PC, because the PC is up before the TV and so it uses a dummy screen mode. But as mentioned before, besides the small gap at button/right in playback after screen mode/rate changes, I also see a gap at the top of the screen before (auto) logon or right after video plaback, but only for a blink-and-you-miss-it moment. Anyone else can confirm this? Ciao, Alfred Got it. I was seeing both issues, but was hopeful that solving the dummy screen mode would also solve this since it initially seemed like hitting maximize would take care of the gaps. Seemed like it could have been related. But you are correct. Thanks for clarifying. Sent from my Pixel using Tapatalk
Guest asrequested Posted July 18, 2018 Posted July 18, 2018 (edited) Electron 2.0.5 is up, if anyone wants to test? https://github.com/electron/electron/releases/tag/v2.0.5 And 3.0.0 beta 3 https://github.com/electron/electron/releases/tag/v3.0.0-beta.3 Edited July 18, 2018 by Doofus
Luke 42242 Posted July 18, 2018 Posted July 18, 2018 The changelogs suggest there will probably not be any difference.
Guest asrequested Posted July 18, 2018 Posted July 18, 2018 The changelogs suggest there will probably not be any difference. That's what I was thinking, but just thought I'd mention it.
nicko84 72 Posted July 20, 2018 Posted July 20, 2018 Hello, In ET 3.0.1 and when display refresh rate changes to match with video, i've one blue stripe on the right of the screen et one litte blue stripe a t bottom. To hide the desktop and these stripes i've changed desktop color from blue to black and move the taskbar to the top of the screen. It's not the best way but the better i've found ! PS : same issue with Electron 2.0.2 and last MPV release. Hello, Same issue with Electron 2.0.5 and last MPV release (still no video with Electron 3.0.0 beta 3)
ShoutingMan 101 Posted July 21, 2018 Posted July 21, 2018 Goto HKLM\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\Configuration Then you'll see a bunch of sub-keys. One of those keys is for your existing monitor. It should be obvious. One of the keys will have the text NOEDID in it, This is the default monitor key. Open that key and replace the following values in the two 00 sub-keys from your actual monitor: ActiveSize.cx ActiveSize.cy PrimSurfSize.cx PrimSurfSize.cy DwmClipBox.bottom DwmClipBox.right Stride Reboot The existing values will be 400 (hex) and 300 (hex). Just remember to enter the news values as decimals as they default to hex. Did you touch any of the frequency synch registry settings? I'm anxious that changing settings without also changing the listed frequency settings will cause major problems. But no one mentions these parameters in all the how-to's I've seen.
echoxxzz 22 Posted July 23, 2018 Posted July 23, 2018 Did you touch any of the frequency synch registry settings? I'm anxious that changing settings without also changing the listed frequency settings will cause major problems. But no one mentions these parameters in all the how-to's I've seen. At a minimum those are the keys you need to change but I actually duplicate all the keys for my real graphics display into the virtual display. 1
nicko84 72 Posted August 11, 2018 Posted August 11, 2018 Hello, No progress about this issue ? Thanks
mark235 5 Posted August 17, 2018 Posted August 17, 2018 Here also a 3 pixel wide line on the right and bottom, when "Change display refresh rate to match video" is turned on. I've settled for a black Windows background color and taskbar at the top to avoid it for now, but would be nice to see a better fix.
AdrianW 1058 Posted August 23, 2018 Posted August 23, 2018 (edited) Looks like there was an update to ET (mine is now 3.0.2). It's updated electron again, which has brought back the gaps at the RHS and bottom. I had to copy back the old electron version again! The update also defaulted the theme back to that blue radiance thing. It would be preferable if updates kept all preferences intact. I played around in ET before switching electron back, and navigation scrolling was significant smoother, but I'd rather put up with janky scrolling than have gaps at the side of the video. @@Luke are you any closer at finding a fix for this gap problem? Edited August 23, 2018 by AdrianW 2
Luke 42242 Posted August 23, 2018 Posted August 23, 2018 I asked a question on one of the previous pages. Can you see what you think? Thanks.
daedalus 434 Posted August 23, 2018 Posted August 23, 2018 I asked a question on one of the previous pages. Can you see what you think? Thanks. answered half a year ago, called to mind two months ago, please over 2 month ago video settings work @ new build other observations first it finally maintains its window size after refresh rate change, but now the whole window gets shifted some pixel to the up left after refresh rate change and comes back to its normal position when you exit playback and it switches refresh rate back Unbenannt.png ^ (original resolution is 1920x1080) the blue pixels on bottom & right are my wallpaper that gets visible after refresh rate change second once started in fullscreen, windowed also stays at the fullscreen size, this and the fact that it can only resized by dragging the bottom or left makes it very hard to ever resize again
AdrianW 1058 Posted August 24, 2018 Posted August 24, 2018 (edited) Is it possible to tell which of these situations is occurring: the video window width/height are slightly smaller than before. or it's the same size but is shifted up and to the left by a few pixels. If we know the answer to that, then maybe i can figure out a temporary hack. OK - so I took some screenshots of a test video - and the newer version of electron is resizing the image rather than just offsetting it. Here's the normal one: And here's the one with the gaps at the right & bottom: Here's the two combined: Edited August 24, 2018 by AdrianW
daedalus 434 Posted August 24, 2018 Posted August 24, 2018 autoit package eg provides a tool called "active window info" which can return exact numbers for window size/postion may be usefull to track this down AU3_Spy.exe.txt
ShoutingMan 101 Posted August 28, 2018 Posted August 28, 2018 Yep, still hoping for news this is fixed so I can return to current version of Electron. 1
pclausen 44 Posted September 7, 2018 Posted September 7, 2018 Any update? I too have resorted to a black desktop and moving the task bar to the top of the desktop. I don't mind that on my HTPC since it launches into ET on boot, but since all my other computers log in using the same Microsoft account, that theme has now propagated to all my other Windows machines. I'll look into creating another account on the HTPC I suppose, so the desktops don't sync across machines. I'll probably have to grant that new account access to the media that is shared from the server, which is currently restricted to my primary Microsoft account. Alternatively, I might just go back to an earlier version of Electron. What is the latest version that does not have this issue, and where do I download it from? And do I just copy the executable on top of what I currently have installed?
AdrianW 1058 Posted September 7, 2018 Posted September 7, 2018 (edited) Alternatively, I might just go back to an earlier version of Electron. What is the latest version that does not have this issue, and where do I download it from? And do I just copy the executable on top of what I currently have installed? Get the one mentioned in this post (from way back in May). That's the one I'm using and I don't get the gaps. You're much better off getting the old electron version than just having black wallpaper - because the gaps are caused by the video being resized, so you're losing resolution and probably introducing artefacts. You'll need to unzip it into: %AppData%\Emby-Theater\system\x64\electron The downside to using the old electron version is that the scrolling in the UI isn't as smooth. Edited September 7, 2018 by AdrianW 1
nicko84 72 Posted September 8, 2018 Posted September 8, 2018 Hoping for an update soon...last Electron and no issue with task bar gap...best of both worlds would be great !
AdrianW 1058 Posted September 9, 2018 Posted September 9, 2018 Got another update today, and I had to copy the older electron version back to get rid of the gaps again. It's annoying as I also have to reset ALL of my settings (audio & video as well as language, display and general settings for every user.) 1
ShoutingMan 101 Posted September 9, 2018 Posted September 9, 2018 (edited) Got another update today, and I had to copy the older electron version back to get rid of the gaps again. It's annoying as I also have to reset ALL of my settings (audio & video as well as language, display and general settings for every user.) The white line is back for me. I guess I have to manually revert Electron again? Yep: Electron updated yesterday to v 2.0.8 for unknown reasons. ET is at 3.0.3. Reverted to 1.8.7 by copying all the files into the folder: C:\Users\[uSER]\AppData\Roaming\Emby-Theater\system\x64\electron Reboot the PC Reset all Emby Theater settings And it's working correctly again Edited September 9, 2018 by ShoutingMan
PrincessClevage 175 Posted September 18, 2018 Author Posted September 18, 2018 (edited) The white line is back for me. I guess I have to manually revert Electron again? Yep: Electron updated yesterday to v 2.0.8 for unknown reasons. ET is at 3.0.3. Reverted to 1.8.7 by copying all the files into the folder: C:\Users\[uSER]\AppData\Roaming\Emby-Theater\system\x64\electron Reboot the PC Reset all Emby Theater settings And it's working correctly again Hi Shoutingman, would you please be able to share were I can download the old electron ver on and required file?Edit: I have found the old electron version and it indeed does fix the pixel issue but creates many dropped frames when playing 4K content Edited September 18, 2018 by PrincessClevage
Guest asrequested Posted September 18, 2018 Posted September 18, 2018 Hi Shoutingman, would you please be able to share were I can download the old electron ver on and required file? Edit: I have found the old electron version and it indeed does fix the pixel issue but creates many dropped frames when playing 4K content Make sure the profiles aren't causing a conflict. Disable your mpv.conf, and test again.
