Guest asrequested Posted March 7, 2019 Posted March 7, 2019 (edited) Black window where? The whole thing. I launch, and all I get is a black rectangle. UPDATE: Just launched again, and now I have functionality. Stay tuned.... Edited March 7, 2019 by Doofus
Guest asrequested Posted March 7, 2019 Posted March 7, 2019 Damn it! I thought you had maybe fixed the --gpu-api=opengl issue....
Luke 42242 Posted March 7, 2019 Posted March 7, 2019 Well that's strange because it's not using true fullscreen in this test build. So i guess just consolidating into one window is going to be a problem.
Guest asrequested Posted March 7, 2019 Posted March 7, 2019 (edited) Well that's strange because it's not using true fullscreen in this test build. So i guess just consolidating into one window is going to be a problem. You could just rip out the cuda option from the settings, and continue with how you have adjusted it. I've been using d3d, and it appears to be ok. For those using cuda deinterlacing, cuda-copy should work. I would actually recommend that. Edited March 7, 2019 by Doofus
Guest asrequested Posted March 7, 2019 Posted March 7, 2019 Luke, for the test builds you could make it portable, so it doesn't get affected but an mpv.conf. That's how I tested this last build.
PrincessClevage 175 Posted March 7, 2019 Author Posted March 7, 2019 @@PrincessClevage is that why you had an issue?Even with build 272 and no mpv.conf I have no overlay UI
Guest asrequested Posted March 7, 2019 Posted March 7, 2019 Even with build 272 and no mpv.conf I have no overlay UI Make it portable, to be sure.
PrincessClevage 175 Posted March 7, 2019 Author Posted March 7, 2019 Make it portable, to be sure.by doing?
PrincessClevage 175 Posted March 7, 2019 Author Posted March 7, 2019 I have just been unzipping content to system folder and overwriting files is this correct?
denz 501 Posted March 7, 2019 Posted March 7, 2019 Tried the version from post #272 and have few issues like if i go too quickly move across the tabs in live tv it doesn't update the screen couple of times i had half of guide and half recordings but it is hard to replicate. I will go back to the first one you posted and do more testing however for both it fixed the issue of taskbar appearing when switching inputs. The live tv tunning is so slow when comparing to wmc. I haven't used theater to watch live tv but it is darn slow 4 seconds at least.
Guest asrequested Posted March 7, 2019 Posted March 7, 2019 I have just been unzipping content to system folder and overwriting files is this correct? You should unzip it to it's own folder, then make it portable. In the same folder as mpv.exe, make a folder called portable_config, then move the scripts folder into it. 1
daedalus 434 Posted March 7, 2019 Posted March 7, 2019 (edited) Damn it! I thought you had maybe fixed the --gpu-api=opengl issue.... what issue? the one, that the player is always 1 pixel line smaller at the top than the ET window when using gpu-api=opengl? green line at top is the desktop shining through in fullscreen also present in windowed mode, you can see the shaded line at the top issue not present with gpu-api=vulkan or d3d11 never reported that, cause i didn't see any will in fixing things like this this here also happens with the current release version Edited March 7, 2019 by daedalus
Guest asrequested Posted March 7, 2019 Posted March 7, 2019 When I use the opengl API, I don't get an OSD, and my display coloring gets messed up. I have to reboot to correct it. If I use d3d, it works just fine.
daedalus 434 Posted March 7, 2019 Posted March 7, 2019 (edited) strange thing @ are you using the mpv version included in the new test builds? if yes, try some other version, i got major issuses using my current mpv.conf with that included version Edited March 7, 2019 by daedalus
Guest asrequested Posted March 7, 2019 Posted March 7, 2019 Yeah, it is. I think it may have something to do with Windows being in HDR10. But I can live with d3d.
Guest asrequested Posted March 7, 2019 Posted March 7, 2019 strange thing @ are you using the mpv version included in the new test builds? if yes, try some other version, i got major issuses using my current mpv.conf with that included version I did try one of them with a different build, but it made no difference. What issues did you have with the included build?
daedalus 434 Posted March 7, 2019 Posted March 7, 2019 i got a blue screen on mpv if setting my scalers filesize of mpv.exe also seems suspiciously small, seems not to be the release but a 3 month old non git version but thats no issue cause it runs normaly without my mpv.conf that version just should not be included in any ET release version
Luke 42242 Posted March 7, 2019 Posted March 7, 2019 That's our custom version that we are building now, forgot about that, but if i put out a patch release for this issue then we'll exclude that for now and keep the same mpv version as before.
daedalus 434 Posted March 7, 2019 Posted March 7, 2019 why are you building it by yourself? what changes? and the most important, if we should test it, maybe you should give us a recent version?
Luke 42242 Posted March 7, 2019 Posted March 7, 2019 We've added libzvbi, which the other sources for mpv unfortunately do not include. This is needed in order to be able to handle dvb_teletext subtitles. If the other builds would add this library, then we wouldn't have to build it ourselves anymore. As far as version, I'm generally most comfortable using tagged releases, as opposed to latest master.
Guest asrequested Posted March 7, 2019 Posted March 7, 2019 Is Korey building it? Maybe we could offer some testing for the new builds?
Luke 42242 Posted March 7, 2019 Posted March 7, 2019 No, someone else, but yes, if you could test it that would be helpful. Thanks.
Guest asrequested Posted March 7, 2019 Posted March 7, 2019 (edited) Ok, I'll pull this one out of Theater, and put it through it's paces. Maybe for the new builds, post them in the test area? Edited March 7, 2019 by Doofus
Luke 42242 Posted March 7, 2019 Posted March 7, 2019 This update goes back to the true full screen mode: https://www.dropbox.com/s/zj75bqjajgjerey/theater.zip?dl=0
