PrincessClevage 175 Posted March 2, 2019 Author Posted March 2, 2019 (edited) Gee the forum doesn’t like copy and past of Unc paths. Same no osd, when stop playing I also have the screwed colours (probably holding onto HDR colours from true full screen mode and applying to sdr images?) did you have to restart or anything to get the settings to enforce? Edited March 2, 2019 by PrincessClevage
Guest asrequested Posted March 2, 2019 Posted March 2, 2019 mpv.conf in C:\Users\Username\AppData\Roaming\Emby-Theater\system\x64\mpv And also here C:\Users\Username\AppData\Roaming\mpv I meant in the UI, but why do you have two mpv.conf files? Just use one in AppData\Roaming\mpv
Guest asrequested Posted March 2, 2019 Posted March 2, 2019 Gee the forum doesn’t like copy and past of Unc paths. Same no osd, when stop playing I also have the screwed colours (probably holding onto HDR colours from true full screen mode and applying to sdr images?) did you have to restart or anything to get the settings to enforce? Yeah, it screwed with my colors, too. You'll need to reboot.
PrincessClevage 175 Posted March 2, 2019 Author Posted March 2, 2019 (edited) I meant in the UI, but why do you have two mpv.conf files? Just use one in AppData\Roaming\mpvUI is hwa auto and enable OpenGL is ticked, just tried it with it not ticked and still no osd. I wasn’t sure which mpv was active so I kept both updated Edited March 2, 2019 by PrincessClevage
Guest asrequested Posted March 2, 2019 Posted March 2, 2019 UI is hwa auto and enable OpenGL is ticked, just tried it with it not ticked and still no osd Only use one mpv.conf
Guest asrequested Posted March 2, 2019 Posted March 2, 2019 One thing I hadn't considered is that d3d would work better with --icc-profile-auto. Which it just might.
Guest asrequested Posted March 2, 2019 Posted March 2, 2019 Now I was able to do a successful test of refresh rate switching, but the audio is out of sync. Even enabling --video-sync=display-vdrop doesn't correct it.
Guest asrequested Posted March 2, 2019 Posted March 2, 2019 Luke, did you make a change to how hwdec is handled? It appears to defer to my mpv.conf in this build. If so, that's excellent!
Luke 42242 Posted March 3, 2019 Posted March 3, 2019 Luke, did you make a change to how hwdec is handled? It appears to defer to my mpv.conf in this build. If so, that's excellent! No, it should not be any different.
Guest asrequested Posted March 3, 2019 Posted March 3, 2019 No, it should not be any different. Well, it is deferring the mpv.conf. So maybe the juggling act you did with the dual windows was messing with that? I've reconfigured my conf for d3d and all is good, so far. deinterlace=yes appears to be working better, too. So maybe this will finally be all fixed? Not being able to use nvdec, sucks, but may turn out to be a blessing in disguise.
Luke 42242 Posted March 3, 2019 Posted March 3, 2019 I think a possible solution could be to come out of full screen mode when the osd shows. In theory, you should not even notice it if positioned exactly as it was while in full screen mode. On Raspberry Pi we actually have to hide the whole video surface when the OSD shows because the transparency features are not supported.
Guest asrequested Posted March 3, 2019 Posted March 3, 2019 I think a possible solution could be to come out of full screen mode when the osd shows. In theory, you should not even notice it if positioned exactly as it was while in full screen mode. On Raspberry Pi we actually have to hide the whole video surface when the OSD shows because the transparency features are not supported. Ok, maybe you could give us a test build, with that solution?
denz 501 Posted March 4, 2019 Posted March 4, 2019 This may not be related to this issue but if I have video in full screen and switch tv inputs and go back to emby theater I can see few pixels of taskbar. If I switch when no video is playing everything looks ok until I start to play a video then I can see few pixels of the task bar.
serpi 82 Posted March 4, 2019 Posted March 4, 2019 This may not be related to this issue but if I have video in full screen and switch tv inputs and go back to emby theater I can see few pixels of taskbar. If I switch when no video is playing everything looks ok until I start to play a video then I can see few pixels of the task bar. It IS the same issue, it related to any kind of screen mode switching. I have the problem if I wake up my htpc before the TV is on. Even if it has the same resolution, it is another screen mode and so I have to make sure, that the tv is already on, before I wake up the htpc. Similar to your case... Ciao, Alfred
Luke 42242 Posted March 4, 2019 Posted March 4, 2019 Can you guys try the zip i have been posting and see how that compares? thanks.
denz 501 Posted March 5, 2019 Posted March 5, 2019 This one doesn't exhibit the issue that I reported. I tried a number of change inputs to see will the taskbar show up but so far so good.
Diedrich 380 Posted March 5, 2019 Posted March 5, 2019 I see this is an older thread but I see this on my Windows machine as well. It's some sort of issue where the ET window goes into almost a windowed mode. Simply minimizing and then maximizing the window takes care of it. Closing and restarting ET fixes it as well.
Guest asrequested Posted March 5, 2019 Posted March 5, 2019 Did you try this? https://emby.media/community/index.php?/topic/59225-active-video-has-small-gap-on-side-and-bottom-of-screen/page-11&do=findComment&comment=710173 1
nicko84 72 Posted March 5, 2019 Posted March 5, 2019 Hello Luke, After few days testing ET of your zip files, all is ok. Gap problem at the bottom and right side is solved, no artefact on screen, no UI issue. I've just set display refresh rate on, with prefered rates 50;23, and all other settings on "auto".
serpi 82 Posted March 5, 2019 Posted March 5, 2019 Can you guys try the zip i have been posting and see how that compares? thanks. Tried it, works for me, no borders, nice! Neither when waking up the htpc before the tv, nor when activating refresh rate switching. Also found no other problems, remote and overlay work. But I also do not use much special configuration. Most is on auto, in mpv.conf it's only AC3 output for multichannel and I have a lua script for 3d to mono conversation and one script for my i-Buddy activated. It's also only a celeron box (J3455) with no special gfx card and no 4k or HDR tv (but 3d). Ciao, Alfred
daedalus 434 Posted March 6, 2019 Posted March 6, 2019 (edited) gap problem also is fixxed here and no other mentioned bugs with the latest test version Edited March 6, 2019 by daedalus
Luke 42242 Posted March 6, 2019 Posted March 6, 2019 Can you guys try this version and compare: https://www.dropbox.com/s/zj75bqjajgjerey/theater.zip?dl=0 Thanks.
Diedrich 380 Posted March 7, 2019 Posted March 7, 2019 (edited) I am currently running the zip from post #206. It does not show current progress on movies or episodes. I'll try the zip you just posted. Edit: Post #272 fixed the progress bar on the Home screen. I'll continue to monitor for the edge gaps. Edited March 7, 2019 by Diedrich
