Tr3bor 0 Posted May 21, 2018 Posted May 21, 2018 Every show we record has no metadata, file names are date/time format. I've looked through all the settings, refreshed epg xml. We have guide data, don't know why that isn't being pulled through when recording. Cheers.
Tr3bor 0 Posted May 21, 2018 Author Posted May 21, 2018 Hi, what guide data are you using? XML provided by my IPTV source.
Luke 42210 Posted May 21, 2018 Posted May 21, 2018 Ok so what data is in the xml that is missing from Emby? can you please go over an example? thanks.
Tr3bor 0 Posted May 21, 2018 Author Posted May 21, 2018 (edited) Ok so what data is in the xml that is missing from Emby? can you please go over an example? thanks. In the program guide everything is there. When I DVR something, the data isn't there & gives me a generic time/date file name. Edited May 21, 2018 by Tr3bor
Tr3bor 0 Posted May 21, 2018 Author Posted May 21, 2018 OK, Say HBO is showing John Oliver, the DVR will record that but will not pull any guide data for it. It names the file like this. Show Name 2018_05_21_04_00_00
Luke 42210 Posted May 21, 2018 Posted May 21, 2018 So if the file name is "John Oliver_2018_05_21_04_00_00" ...then that matches what is in the guide data, right? Can you please show a screenshot of what it looks like in the guide? thanks.
Tr3bor 0 Posted May 22, 2018 Author Posted May 22, 2018 (edited) So if the file name is "John Oliver_2018_05_21_04_00_00" ...then that matches what is in the guide data, right? Can you please show a screenshot of what it looks like in the guide? thanks. No, it's only matching the name with zero episode data being pulled. There's nothing wrong with the guide, my recorded episodes are not getting info from the guide (Season/Episode) when they are done recording, I get 0 episode information. Edited May 22, 2018 by Tr3bor
Luke 42210 Posted May 22, 2018 Posted May 22, 2018 I'm not suggesting there's anything wrong with your guide, I'm simply trying to collect information from you that I can use to improve the recording process. Can you please show a screenshot from Emby? That is not our software. Thanks !
Tr3bor 0 Posted May 22, 2018 Author Posted May 22, 2018 (edited) I'm not suggesting there's anything wrong with your guide, I'm simply trying to collect information from you that I can use to improve the recording process. Can you please show a screenshot from Emby? That is not our software. Thanks ! . It seems like that the recordings in Emby are getting some data, but no season/ep data. When I first used Emby to record an episode of Vice, all the correct Season/EP data was there. Is this a matter of my providers XML having that data only for certain shows? And shouldn't that basic data be encoded in the file? It's not embedded into the file, just shows up the basic EP data in Emby. Edited May 23, 2018 by Tr3bor
Tr3bor 0 Posted May 22, 2018 Author Posted May 22, 2018 Here is my last DVR log. {"Protocol":"Http","Id":"5da045e9d4f644798a8714032779ad57_599a87a9e0fe358bec62cc0db7870d38","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/00a348ee85be4382b6e205964d3f219a/stream.ts","Type":"Default","IsRemote":true,"ReadAtNativeFramerate":false,"IgnoreDts":true,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"VideoRange":"SDR","DisplayTitle":"","IsInterlaced":true,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"DisplayTitle":"","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"Formats":[],"RequiredHttpHeaders":{"User-Agent":"Mozilla/5.0(Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.85 Safari/537.36"}} C:\Users\sande\AppData\Roaming\Emby-Server\system\ffmpeg.exe -async 1 -vsync -1 -fflags +igndts -analyzeduration 5000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/00a348ee85be4382b6e205964d3f219a/stream.ts"-t 00:15:56.880 -codec:v:0 copy -fflags +genpts -map_metadata -1 -threads 0 -codec:a:0 copy -sn -y "C:\TV\Teen Titans Go!\Teen Titans Go! 2018_05_21_02_30_00.ts" ffmpeg version 3.4.2 Copyright © 2000-2018 the FFmpeg developersbuilt with gcc 7.3.0 (GCC)configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libmfx --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynthlibavutil 55. 78.100 / 55. 78.100libavcodec 57.107.100 / 57.107.100libavformat 57. 83.100 / 57. 83.100libavdevice 57. 10.100 / 57. 10.100libavfilter 6.107.100 / 6.107.100libswscale 4. 8.100 / 4. 8.100libswresample 2. 9.100 / 2. 9.100libpostproc 54. 7.100 / 54. 7.100[h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame![h264 @ 000002099ac25820] non-existing PPS 0 referencedLast message repeated 1 times[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] non-existing PPS 0 referenced[h264 @ 000002099ac25820] decode_slice_header error[h264 @ 000002099ac25820] no frame!Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/00a348ee85be4382b6e205964d3f219a/stream.ts':Duration: N/A, start: 43342.249878, bitrate: N/AProgram 1Metadata:service_name : Service01service_provider: FFmpegStream #0:0[0x100]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(progressive), 528x352 [sAR 40:33 DAR 20:11], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbcStream #0:1[0x101]: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 201 kb/sOutput #0, mpegts, to 'C:\TV\Teen Titans Go!\Teen Titans Go! 2018_05_21_02_30_00.ts':Metadata:encoder : Lavf57.83.100Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(progressive), 528x352 [sAR 40:33 DAR 20:11], q=2-31, 29.97 fps, 29.97 tbr, 90k tbn, 90k tbcStream #0:1: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 201 kb/sStream mapping:Stream #0:0 -> #0:0 (copy)Stream #0:1 -> #0:1 (copy)Press [q] to stop, [?] for helpframe= 336 fps=185 q=-1.0 size= 3328kB time=00:00:15.70 bitrate=1736.3kbits/s speed=8.67xframe= 386 fps=100 q=-1.0 size= 3840kB time=00:00:17.79 bitrate=1768.1kbits/s speed=4.59xframe= 409 fps= 85 q=-1.0 size= 4096kB time=00:00:18.75 bitrate=1789.4kbits/s speed= 3.9xframe= 420 fps= 73 q=-1.0 size= 4096kB time=00:00:19.22 bitrate=1745.7kbits/s speed=3.32xframe= 442 fps= 65 q=-1.0 size= 4352kB time=00:00:20.10 bitrate=1773.5kbits/s speed=2.96xframe= 489 fps= 67 q=-1.0 size= 4864kB time=00:00:22.08 bitrate=1804.6kbits/s speed=3.03xframe= 498 fps= 64 q=-1.0 size= 4864kB time=00:00:22.50 bitrate=1770.4kbits/s speed=2.87xframe= 528 fps= 60 q=-1.0 size= 5120kB time=00:00:23.70 bitrate=1769.3kbits/s speed= 2.7xframe= 547 fps= 56 q=-1.0 size= 5376kB time=00:00:24.51 bitrate=1796.7kbits/s speed=2.51xframe= 592 fps= 55 q=-1.0 size= 5888kB time=00:00:26.34 bitrate=1830.8kbits/s speed=2.45xframe= 611 fps= 52 q=-1.0 size= 6144kB time=00:00:27.14 bitrate=1854.3kbits/s speed=2.31xframe= 631 fps= 49 q=-1.0 size= 6400kB time=00:00:27.97 bitrate=1874.0kbits/s speed=2.19xframe= 660 fps= 48 q=-1.0 size= 6912kB time=00:00:29.20 bitrate=1938.8kbits/s speed=2.12xframe= 674 fps= 45 q=-1.0 size= 7168kB time=00:00:29.78 bitrate=1971.7kbits/s speed=2.01xframe= 691 fps= 44 q=-1.0 size= 7424kB time=00:00:30.48 bitrate=1995.0kbits/s speed=1.93xframe= 712 fps= 42 q=-1.0 size= 7680kB time=00:00:31.34 bitrate=2007.0kbits/s speed=1.87xframe= 730 fps= 41 q=-1.0 size= 7936kB time=00:00:32.12 bitrate=2023.5kbits/s speed= 1.8xframe= 769 fps= 41 q=-1.0 size= 8448kB time=00:00:33.74 bitrate=2050.6kbits/s speed= 1.8xframe= 788 fps= 40 q=-1.0 size= 8704kB time=00:00:34.51 bitrate=2065.7kbits/s speed=1.74xframe= 809 fps= 39 q=-1.0 size= 8960kB time=00:00:35.41 bitrate=2072.7kbits/s speed= 1.7xframe= 832 fps= 36 q=-1.0 size= 9216kB time=00:00:36.37 bitrate=2075.6kbits/s speed=1.59xframe= 851 fps= 32 q=-1.0 size= 9472kB time=00:00:37.16 bitrate=2088.0kbits/s speed=1.39xframe= 854 fps= 31 q=-1.0 size= 9472kB time=00:00:37.25 bitrate=2082.9kbits/s speed=1.36xframe= 876 fps= 31 q=-1.0 size= 9728kB time=00:00:38.20 bitrate=2085.7kbits/s speed=1.37xframe= 898 fps= 29 q=-1.0 size= 9984kB time=00:00:39.14 bitrate=2089.3kbits/s speed=1.27xframe= 925 fps= 27 q=-1.0 size= 10240kB time=00:00:40.25 bitrate=2083.8kbits/s speed=1.19xframe= 959 fps= 26 q=-1.0 size= 10496kB time=00:00:41.52 bitrate=2070.7kbits/s speed=1.13xframe= 966 fps= 26 q=-1.0 size= 10496kB time=00:00:41.75 bitrate=2059.1kbits/s speed= 1.1xframe= 1124 fps= 28 q=-1.0 size= 11008kB time=00:00:47.02 bitrate=1917.5kbits/s speed=1.16xframe= 1200 fps= 29 q=-1.0 size= 11264kB time=00:00:49.57 bitrate=1861.2kbits/s speed=1.19xframe= 1284 fps= 29 q=-1.0 size= 11520kB time=00:00:52.36 bitrate=1802.1kbits/s speed=1.18x
Tr3bor 0 Posted May 23, 2018 Author Posted May 23, 2018 @@Luke Is it my epg provider or the app integration of that metadata? Cheers.
Luke 42210 Posted May 31, 2018 Posted May 31, 2018 @@Tr3bor, This will happen if your xml data does not have season and episode numbers. If you look in the xml data you can verify this. However - usually this is OK because we can retrieve that information from tvdb after the recording has completed. This will work as long as: You have tvdb fetching enabled for the library the recordings are being saved to (which it is by default) And, tvdb has a record of an episode that matches the date of the filename I would verify this myself for those particular episodes, however, the tvdb website is currently offline for maintenance: http://tvdb.com/ The API is still up so it will not affect Emby's use of TVDB. For kicks I can look at MovieDB, which might not be as accurate as tvdb: https://www.themoviedb.org/tv/37606-the-amazing-world-of-gumball?language=en-US And according to them at least, there was no episode that aired on 2018-05-21. So basically what happened is, your xml data does not have the season and episode numbers, and we're unable to use the date of the recording to match it with internet metadata. If you can create this situation again with a new recording and then post a copy of your xmltv data, then we can look at it together to see exactly what data is available. Please let us know if this helps. Thanks.
