sluggo 0 Posted May 21, 2018 Posted May 21, 2018 Hello, Sorry if this post does not contain enough info for troubleshooting, I'll do my best. I'm using openmediavault 4.1.6 which is running on Debian 9.4. I've installed emby using the docker container emby/embyserver Emby seems to work but I could hear my server harddrive constantly churning so I looked at the docker info on openmediavault and the status is always something "up 53 seconds" or "up 4 seconds'. It never seems to be up for more than a minute. I've attached a couple of log files from docker. Below is a screenshot showing the environment variables I set in the docker plugin. Here is the output from the container details (from openmediavault): [ { "Id": "sha256:e465d2065cdac2c7f3eccd8fd50ab14d78b7cdf3b29f02f5ab99b0a504050524", "RepoTags": [ "emby/embyserver:latest" ], "RepoDigests": [ "emby/embyserver@sha256:2bf4b76927e541c4790f8cddf6b7511f10680a76491ccbad5292b8a3117c4fd7" ], "Parent": "", "Comment": "", "Created": "2018-05-07T15:58:46.706136952Z", "Container": "b75c48d1923bc68523bbb0872f1634922133f7e15769298ffeac248626e11bcc", "ContainerConfig": { "Hostname": "b75c48d1923b", "Domainname": "", "User": "", "AttachStdin": false, "AttachStdout": false, "AttachStderr": false, "ExposedPorts": { "1900/udp": {}, "7359/udp": {}, "8096/tcp": {}, "8920/tcp": {} }, "Tty": false, "OpenStdin": false, "StdinOnce": false, "Env": [ "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin", "LANG=en_US.UTF-8", "FONTCONFIG_PATH=/etc/fonts", "ICU_DATA=/share/icu/59.1", "LD_LIBRARY_PATH=/lib:/lib/samba:/system", "LIBVA_DRIVERS_PATH=/lib/dri", "UID=2", "GID=2", "GIDLIST=2" ], "Cmd": [ "/bin/sh", "-c", "#(nop) ", "ENTRYPOINT [\"/init\"]" ], "ArgsEscaped": true, "Image": "sha256:5714ca1003aebeea8c63550dc5e30f21f281bebc50fa500baf7c9e1ba179138a", "Volumes": { "/config": {} }, "WorkingDir": "", "Entrypoint": [ "/init" ], "OnBuild": null, "Labels": { "maintainer": "Emby LLC <apps@[member="Emby.media"]>" } }, "DockerVersion": "18.04.0-ce", "Author": "", "Config": { "Hostname": "", "Domainname": "", "User": "", "AttachStdin": false, "AttachStdout": false, "AttachStderr": false, "ExposedPorts": { "1900/udp": {}, "7359/udp": {}, "8096/tcp": {}, "8920/tcp": {} }, "Tty": false, "OpenStdin": false, "StdinOnce": false, "Env": [ "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin", "LANG=en_US.UTF-8", "FONTCONFIG_PATH=/etc/fonts", "ICU_DATA=/share/icu/59.1", "LD_LIBRARY_PATH=/lib:/lib/samba:/system", "LIBVA_DRIVERS_PATH=/lib/dri", "UID=2", "GID=2", "GIDLIST=2" ], "Cmd": null, "ArgsEscaped": true, "Image": "sha256:5714ca1003aebeea8c63550dc5e30f21f281bebc50fa500baf7c9e1ba179138a", "Volumes": { "/config": {} }, "WorkingDir": "", "Entrypoint": [ "/init" ], "OnBuild": null, "Labels": { "maintainer": "Emby LLC <apps@[member="Emby.media"]>" } }, "Architecture": "amd64", "Os": "linux", "Size": 208380077, "VirtualSize": 208380077, "GraphDriver": { "Data": { "LowerDir": "/var/lib/docker/overlay2/20e16cd2d0b7c53da651e0cb896ccd019038f5573cc50b47bfe5b9f248555e8e/diff:/var/lib/docker/overlay2/52002252664d969ed2eb4151d0de4b83c125d5163457b2aaea39ae904fbe2c6e/diff:/var/lib/docker/overlay2/63d17f041a5c28b8240ccbcd57a7ad6f97cbcfd3e8f2315e66f742c436185470/diff:/var/lib/docker/overlay2/317120fd9fe99aaf796ab63158f7b5a8b427b5dc5b72cf3d41d78fa4f4654f0d/diff", "MergedDir": "/var/lib/docker/overlay2/5f5a358dc6e6aa6ebf50e0bd225f16e1883b467da90976d61ed4849adf8e45f0/merged", "UpperDir": "/var/lib/docker/overlay2/5f5a358dc6e6aa6ebf50e0bd225f16e1883b467da90976d61ed4849adf8e45f0/diff", "WorkDir": "/var/lib/docker/overlay2/5f5a358dc6e6aa6ebf50e0bd225f16e1883b467da90976d61ed4849adf8e45f0/work" }, "Name": "overlay2" }, "RootFS": { "Type": "layers", "Layers": [ "sha256:0271b8eebde3fa9a6126b1f2335e170f902731ab4942f9f1914e77016540c7bb", "sha256:4c752d379674f81a579202b7822bd7ea3ddb4af97e1476fea274b27065973d03", "sha256:00fddc56f2aada8d5b80729be6355c2fd613eda198655d83c3f3886061153f7a", "sha256:5b9b2e70291cc7df3650d13852462514c17188b67f73219df59e3c7990d7794d", "sha256:d8d91af87be16ea4fe4fbde416bb48dc1bac06af5925a95ec47e5c52905e2c2a" ] }, "Metadata": { "LastTagTime": "0001-01-01T00:00:00Z" } } ] Any help on this is appreciated, thanks. emby-docker-log.zip
Luke 42246 Posted May 21, 2018 Posted May 21, 2018 Unfortunately the logs don't indicate anything obvious. Does OMV have any system logs that might be useful?
sluggo 0 Posted May 21, 2018 Author Posted May 21, 2018 Ok, I checked the OMV system log which gives some info: May 21 10:24:57 openmediavault monit[635]: 'filesystem_srv_dev-disk-by-label-Disk1' space usage 91.3% matches resource limit [space usage>85.0%] May 21 10:25:07 openmediavault dockerd[31604]: time="2018-05-21T10:25:06-07:00" level=info msg="shim docker-containerd-shim started" address="/containerd-shim/moby/c0c92671fbdf0affd7a87a6c3b0783cf707ffa8e2edeea431d97fe29e72c46f2/shim.sock" debug=false module="containerd/tasks" pid=17579 May 21 10:27:11 openmediavault kernel: [827965.642491] EmbyServer[17845]: segfault at 0 ip 00007fd738a245c0 sp 00007fd6877fa298 error 4 in libc-2.17.so[7fd7389b2000+1aa000] May 21 10:27:16 openmediavault dockerd[31604]: time="2018-05-21T10:27:16-07:00" level=info msg="shim reaped" id=c0c92671fbdf0affd7a87a6c3b0783cf707ffa8e2edeea431d97fe29e72c46f2 module="containerd/tasks" May 21 10:27:16 openmediavault dockerd[31604]: time="2018-05-21T10:27:16.560138156-07:00" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete" May 21 10:27:17 openmediavault dockerd[31604]: time="2018-05-21T10:27:17-07:00" level=info msg="shim docker-containerd-shim started" address="/containerd-shim/moby/c0c92671fbdf0affd7a87a6c3b0783cf707ffa8e2edeea431d97fe29e72c46f2/shim.sock" debug=false module="containerd/tasks" pid=18112
Luke 42246 Posted May 21, 2018 Posted May 21, 2018 Is OMV up to date? I will have to double check but I think we need a higher version of libc than 2.17
sluggo 0 Posted May 21, 2018 Author Posted May 21, 2018 I have a brand new install with the latest build AFAIK. OMV 4.1.6 with Linux kernel 4.14. If there is something newer than that, I'm not sure how to get it. It looks like my libc version is 2.24. root@openmediavault:~# ldd --version ldd (Debian GLIBC 2.24-11+deb9u3) 2.24
Luke 42246 Posted May 28, 2018 Posted May 28, 2018 This looks like a situation similar to what happened on terramaster for a while, a combination of runtime + libc + kernel that doesn't work well together on some hardware. It ultimately ended up resolving itself after updating third party libraries. Your best bet is to try the docker beta with the .NET Core 2.1 runtime, as soon as we've pushed that to Docker beta. And that will hopefully be sometime this week. Thanks.
sluggo 0 Posted June 10, 2018 Author Posted June 10, 2018 Thanks. How do I use the docker beta? I tried to pull from emby/embyserver_beta but that didn't work for me.
Luke 42246 Posted June 12, 2018 Posted June 12, 2018 Thanks. How do I use the docker beta? I tried to pull from emby/embyserver_beta but that didn't work for me. beta is actually one of the available tags on the emby/embyserver container. please let us know if this helps. thanks.
Strutzi 0 Posted June 12, 2018 Posted June 12, 2018 Hey Guys, Ive got the same Problem on the same OS. Everything worked fine until the recent updates in the docker images. I had to downgrade the Image to 3.4.0.4 to get it working again... All above that ends in an endless restart of the container either latest or beta. There is an error in my docker log that caused the failure and i will post that log as soon as I get home. When i googled the error I came to corefx in github saying the error will be fixed in 2.0.3... Anyways I upload the log as soon as I can! Thanks for the help.
Luke 42246 Posted June 12, 2018 Posted June 12, 2018 Hey Guys, Ive got the same Problem on the same OS. Everything worked fine until the recent updates in the docker images. I had to downgrade the Image to 3.4.0.4 to get it working again... All above that ends in an endless restart of the container either latest or beta. There is an error in my docker log that caused the failure and i will post that log as soon as I get home. When i googled the error I came to corefx in github saying the error will be fixed in 2.0.3... Anyways I upload the log as soon as I can! Thanks for the help. Please see how to report a problem. thanks.
Strutzi 0 Posted June 16, 2018 Posted June 16, 2018 (edited) So this is the actual Docker log. The docker-container keeps crashing infinitely. My last working image version is 3.4.0.4. Thank You! emby docker log.txt Edited June 16, 2018 by Strutzi
sluggo 0 Posted June 16, 2018 Author Posted June 16, 2018 beta is actually one of the available tags on the emby/embyserver container. please let us know if this helps. thanks. Okay, I tried running the beta. Both emby/embyserver:latest and beta are crashing Jun 16 16:15:24 openmediavault kernel: [1805672.622592] EmbyServer[11834]: segfault at 0 ip 00007f5f564345c0 sp 00007f5edaaad298 error 4 in libc-2.17.so[7f5f563c2000+1aa000] embyserver.zip emby docker log.zip
sluggo 0 Posted June 18, 2018 Author Posted June 18, 2018 I don't see any specific updates to libc. I have the updated openmediavault package. ldd --version returns: (Debian GLIBC 2.24-11+deb9u3) 2.24
sluggo 0 Posted June 25, 2018 Author Posted June 25, 2018 Although I have compiled kernels in the past, I don't feel comfortable with doing this for OMV. They have not released an updated kernel (4.17?) for OMV. I will wait for the kernel update and try again and update this thread - although I don't know how often they update the kernel for OMV....
Luke 42246 Posted June 25, 2018 Posted June 25, 2018 Yea these segfaults are unfortunately very difficult to chase down.
ojessie 4 Posted April 19, 2021 Posted April 19, 2021 Hi, unfortunately, I've to bring up this issue again. I'm having the same problem. Running emby on OMV 5.6.4.1 on portainer 2.1.1. Now and then there is a complete reset of emby. Meaning starting from scratch. Anyone have an idea how to fix it. Thanks.
Luke 42246 Posted April 19, 2021 Posted April 19, 2021 7 hours ago, ojessie said: Hi, unfortunately, I've to bring up this issue again. I'm having the same problem. Running emby on OMV 5.6.4.1 on portainer 2.1.1. Now and then there is a complete reset of emby. Meaning starting from scratch. Anyone have an idea how to fix it. Thanks. Hi there, please attach the emby server log from when this happens. Thanks
ojessie 4 Posted April 20, 2021 Posted April 20, 2021 @Luke Thanks will do so when it happens again. In the meantime, I disabled watchtower ...will see. Best
ojessie 4 Posted May 2, 2021 Posted May 2, 2021 @Luke Update ... no further resetting's since deactivating watchtower ... I think that caused the problem. Best
