Sammy 791 Posted July 24, 2018 Author Posted July 24, 2018 @@Sammy You have 6 TV Series library folders that you would need to check for metadata. Do these 6 TV Series libraries only have series folders in them? The only TV Shows appearing in this Ip Man Series are those recorded by Plex which is the library I'm showing here. All other shows in my library are not having this issue. Could it be the nested TV Series/TV Series folder?
Happy2Play 9802 Posted July 24, 2018 Posted July 24, 2018 The only TV Shows appearing in this Ip Man Series are those recorded by Plex which is the library I'm showing here. All other shows in my library are not having this issue. Could it be the nested TV Series/TV Series folder? That is possible as TV does not play well with nested folders.
Luke 42212 Posted July 24, 2018 Posted July 24, 2018 Yes we plan to be able to accommodate a mish mash in the future, but we're not quite there yet. Thanks.
Sammy 791 Posted July 24, 2018 Author Posted July 24, 2018 Okay. I'm going to move all content in the nested folder up one level and tell Plex to record to that folder too. BTW, Comskip in Emby would solve this!! I prefer Emby. In Plex, to change the Recorded TV folder for future recordings you have to do it in each Show in the Scheduled Recordings rather than just one place in the Server Settings. What is that!!??
Sammy 791 Posted July 24, 2018 Author Posted July 24, 2018 Ip Man no We plan to add comskip in the future. thanks. I know!! Awesome!
Sammy 791 Posted July 24, 2018 Author Posted July 24, 2018 (edited) Ip Man now has no "Episodes" in it which were actually Plex DVR Recordings but it still shows under TV Series in my Library. I have initiated another TV Series Library Scan because I could not "Delete Media" as Emby would give me an error that it couldn't delete the media. Hopefully with another full scan Ip Man will haunt me no more. Thanks for all the help!! Edited July 24, 2018 by Sammy
maegibbons 1287 Posted July 24, 2018 Posted July 24, 2018 We plan to add comskip in the future. thanks. @@Luke This is good news!! I have started using the conversion feature instead of MCEBuddy BUT I do miss the commskip aspect. Will make emby even more awesome. Well done! Krs Mark 1
Sammy 791 Posted July 25, 2018 Author Posted July 25, 2018 I have successfully got of all the series / shows buried in Ip Man but the show still exists albeit with no cover art. How to remove this from my library? I tried Deleting it but got an error. Thanks.
Solution Luke 42212 Posted July 25, 2018 Solution Posted July 25, 2018 Delete the folder it's pointing to, then run a library scan. 1
Sammy 791 Posted July 25, 2018 Author Posted July 25, 2018 Delete the folder it's pointing to, then run a library scan. I can now proclaim Ip Man is DEAD and I killed him (with the help of a few of my friends) So long as he never returns I'm good!
