jang430 10 Posted May 20, 2018 Posted May 20, 2018 I'd like to be able to do this after a period of time, or upon restart, select a profile first, so that restrictions, and history can be tracked. Thanks
Angelblue05 4132 Posted May 20, 2018 Posted May 20, 2018 (edited) Which add-on? Emby for kodi functions differently to Embycon. Emby for Kodi: one Kodi profile per Emby user. You'd use the Kodi profile system. Embycon: Launch the add-on, I believe you'll find the option to change user there. Can be changed within the same Kodi profile. Edited May 20, 2018 by Angelblue05
jang430 10 Posted May 20, 2018 Author Posted May 20, 2018 Emby for kodi. How do you switch? Or how do you don't via Kodi? Sent from my iPhone using Tapatalk
Solution Angelblue05 4132 Posted May 20, 2018 Solution Posted May 20, 2018 (edited) Kodi profiles: https://kodi.wiki/view/Profiles Switch profile, make sure the add-on is enabled or enable it on the profile. Then sign in using the user you want. Edited May 20, 2018 by Angelblue05
jang430 10 Posted May 20, 2018 Author Posted May 20, 2018 Kodi profiles: https://kodi.wiki/view/Profiles Switch profile, make sure the add-on is enabled or enable it on the profile. Then sign in using the user you want. Thanks Sent from my iPhone using Tapatalk
