lolento 1 Posted March 27, 2014 Posted March 27, 2014 I can seem to find the option to adjust the mobile web client bitrate. Is there a way to do this?
Koleckai Silvestri 1154 Posted March 27, 2014 Posted March 27, 2014 Press the gear icon in the web player while you're playing your item. See the image.
lolento 1 Posted March 27, 2014 Author Posted March 27, 2014 Yes, that is how to do it on full web client. But my question is regarding mobile web client? I dont see that button available...
w84no1 27 Posted March 27, 2014 Posted March 27, 2014 I don't see it on my phone either. After inspecting the code on my pc with chrome, it looks like the button is set to display: none when the width is 640px or smaller. It needs to be changed in the css media query. A dev will have to fix it for the next release. @media all and (max-width: 640px), all and (max-height: 365px) { #mediaPlayer .chaptersButton, #mediaPlayer .audioTracksButton, #mediaPlayer .qualityButton, #mediaPlayer .subtitleButton { display: none!important; } The #mediaPlayer .qualityButton should be removed.
lolento 1 Posted March 27, 2014 Author Posted March 27, 2014 I see. Thanks for looking into this! However, my phone at 1080p in landscape should be way wider than 640px...
Koleckai Silvestri 1154 Posted March 27, 2014 Posted March 27, 2014 Sorry, didn't check on the phone. I use the iOS client on my phone and have never used the webclient there.
