azawisza 0 Posted March 27, 2014 Posted March 27, 2014 MB3 seems to be scanning for media every few minutes instead of twice daily. Is there something I am missing as a setting that would cause that? Wouldn't be an issue other than it takes up two core while scanning. log.log
Luke 42301 Posted March 27, 2014 Posted March 27, 2014 in that log it's reacting to changes in your recorded tv folder. try turning off the realtime monitor if that bothers you
azawisza 0 Posted March 27, 2014 Author Posted March 27, 2014 Thanks that worked. is their anyway for it to only process what has changed in that folder versus running the entire scan?
Luke 42301 Posted March 27, 2014 Posted March 27, 2014 that's what it does but sometimes it has to go one level up. if that leads to the top of the library it does a whole scan. if twice a day is all you want then i think you're fine with it off.
